163 RMK Weight Distribution | Suspension Setup
Snowman.PRO.
275
47
MN
Front shocks: 5 clicks
FTS: 5 clicks
RTS: 5 Clicks
I am going to try running the RTS compression much softer. May even turn it down to the first click, so 1, and then see if its just blows through the travel, I just want to feel it weight transfer like my 15 SBA 144x2" did. Maybe that's not possible?
I still am looking for a way to make the front end lighter, and more playful. I have added a Indy specialties clutch kit turbo3, so that should make it more responsive on the silber turbo @ 7lbs.
7,910
6,671
FTS: 5 clicks
RTS: 5 Clicks
silber @7#
stock 16SC clicker shocks
162 3” PC
36” front end.
stock length shocks
Pro spindles
Stock front and FTS springs at stock settings.
progressive rear rear spring 180-450#
Longest spring length without losing the retainer.
light and playful, bottoming and wheelie resistance.
7,910
6,671
silber @7#
162 3” PC
36” front end.
stock length shocks
Pro spindles
A49EFE7A-48D6-40C1-89C4-70F21371AFAD.jpeg77A5DA7A-F2A2-45D5-B06D-1C6F20385E53.jpeg1C9B2F13-A38F-4C28-B95B-963A7471884C.jpeg
frntflp
403
150
Plymouth, MN
FTS: 5 clicks
RTS: 5 Clicks
My 15 SBA 144 has a very different (heavier duty, trail minded) rear suspension than my 18 Axys RMK. Granted, neither of them are coupled (like most current Pol trail sleds, and I'm not sure if the geometry is the same). Yes, the weight transfer of the SBA is really nice, not sure if the RMK will even do that. Curious to hear what you find ! Ultimately, I want my RMK to be set up for deep snow and I will put up with what ever trail characteristics come with it.
FTS: 5 clicks
RTS: 5 Clicks
Is this 5 clicks starting from full soft or full hard?
wonderxc600
106
MN
Looking at getting a set of rear raptor shocks. Did the shocks help, it be a little more playful. Obviously it's not a 155, I'm so use to a 155, I'm struggling a little to get use to my 1
I'm having a hard time getting use to my 163, I've always had a 155. I know that there is a difference and shocks can help a lot. I was thinking about adding better rear shocks than stock. Can adding better shocks "thinking Raptors" to the rear make a big enough difference to the handling. Looking for the best place to start spending my money on to help with the handling. I'm also going to add a 36" front at some point.
7,910
6,671
adding power or increasing transfer will help it feel shorter.
adjust your rear springs.
looser rear rear and tighter center.
