D
16’ Axys EV actuator
Been awhile since I posted on the forum but I have a new and bizarre issue with my axys and I hope someone can help. Sled has 4K hard mountain miles, everything has been replaced at some point haha.
So the long story goes like this. Sled lost rpm, would only pull 6500, no codes etc. Turned out that the T-bar for the exhaust valve had broken allowing the steel bushing/seat to fall out and eventually the valve. Replaced the complete assembly with a used unit, got a entire days ride in and same problem it seemed. Turned out the actuator to valve cable snapped. Installed a spare and it made it 2hrs and snapped (both pulled out at the crimp on the ev side.)
I do now have a code 520335-5.
I have heard about actuators requiring a re learn, which I would think is my problem but I’m not seeing a actuator pulling too little, it’s pulling too hard.
I thought potentially I did not adjust the cable correctly but looking at it I don’t see any way to adjust the cable? It seems that the cable is in spec or out of spec?
Due to the damage to the first exhaust valve set and now these cables I would say actuator has failed, but what are your thoughts?
Can I install a new actuator with a good cable and go?
Thanks
Thanks
