  • I've received emails and PM's asking me about "Group Buys" and promotions.
    A Group Buy here on SnoWestOnline.com would be a situation where a normal member (non vendor or mfg) personally collects orders from other members. That member then uses those orders to negotiate a better price with the Vendor/Mfg for HIS/HER "Group" of buyers.
    Here is an example of a viable "Group Buy"
    http://www.snowestonline.com/forum/showthread.php?t=269222
    A promotion that has the words "Group Buy" in the title is still a promotion, and from the rules that were handed down to me by Harris Publications is that non-advertisers cannot run promotions or open sales programs on the forums outside of the swapmeet.
    If a members wants to become a group buy manager, maintain a thread and collect the funds and negotiate a group buy... as a member, you are welcome to do that as long as you are not attached to the business of the vendor or Mfg.
    If you are a vendor/MFG and you want to offer an EXCLUSIVE "SnoWestOnline ONLY" promotion that is exclusive to snowest readers, please contact me and you'll be able to put it up in the Polaris forums.
    Also, before any vendors/mfgs get all "riled up" over this know that the moderators are strictly volunteers and do not receive a dime from any advertising $$ spent on this site.
    As ALWAYS, since DAY ONE of me becoming a moderator, I have pioneered, supported and encouraged vendors and mfgs in getting the word out to our readers with "New Product Announcements.
    Have a great season.
    From this point on, all vendors/mfg's promoting Pre-Season tiered sales programs, in the Polaris Forums, that are not paid advertisers will be appropriately moved to the swapmeet section of the forums.
    MH
13 rmk turbo low end bog
I've been dealing with this bog/ hesitation recently and i have tried everything you could possibly think of, also i have been getting DET codes some times while i'm in this rpm range which is below 5500. the A/F is spot on, compression is good. i'm running 6.5 to 8 psi with av gas. next i was gonna make sure my TPS is within spec and make sure my reeds aren't gone. i'm pretty much at a loss right now. i did notice that my control box said that it seen 21.8 psi of boost go though so maybe the waste gate is done? ill link a video of what it sounds like.
1madbird
216
21
18
West Bountiful, Utah
It looks like this is a boondocker kit? Is this a new issue or has it always done this? I doubt its your TPS unless you are seeing RPM fluctuations at Idle and low RPM at WOT. Reeds are a possibility. What clutching are you running? I would check your reeds, Check fuel pressure possibly change fuel filter, Also check your clutching to make sure you don't have any wear or rollers that are out on the primary clutch.
[/ thanks for the reply, yes this is a boon docker kit. i have a fuel pressure gauge on it and it hold's a consistent 60 psi brand new fuel filter, i haven't checked the reeds but i will this weekend. i have figured out that my adjustable actuator was way out of wack so i changed that. my control box still reads that it is seeing 10.5 pounds of boost at WOT and around 7.5 at 7900 rpm but i have the actuator almost backed all the way off and the control box set to 6.8. so i'm assuming that's why i'm getting DET codes cause its not fueling it properly?. clutching is the spring sent with boon docker kit and 70 gram adjustable weights, took the clutch apart cleaned it and it was all good. i know that the head of the actuator can adjust the throw of the arm on the waste gate so maybe that's out of wack? i did notice that sometimes my idle is a little bit low.
