09 RMK600 NO POWER
Oct 14, 2019
5
When I pull the pull cord on my sled nothing is getting power, sled wont start, dash doesn't light up, headlights don't light up... nothing. I replaced the regulator (part #4011114) and still nothing. Any ideas on what to look at next? The battery is dead, but when I jump the sled's battery I still have the same issue.
Thanks! Any advice would be much appreciated.
Oct 14, 2019
5
One thing I forgot to mention, I can get the sled started if I dump fuel down the cylinders. Once its running it runs great and everything works. If I shut the sled down after its been running and wait 5 minutes, it will start again, but if it sits overnight I run into the issue above.
Super Dave3
1,095
346
61
Klamath Falls OR
Stator or chassis relay
Nov 17, 2008
127
I've ran into issues with the tether switch if you have one id try bypassing that also
If when you do have it running and it seems to idle a little high you might look for a cracked carb to engine boot !! I had one of those on a 08 700 that made it real hard to start but ran okay after it got started, I would idle a couple of hundred rpm higher then normal.
Nov 17, 2008
127
If when you do have it running and it seems to idle a little high you might look for a cracked carb to engine boot !! I had one of those on a 08 700 that made it real hard to start but ran okay after it got started, It would idle a couple of hundred rpm higher then normal with the crack.
