H
2009 m1000 SnoPro - 162 PC - SLP y/pipe/can - PCV box - 3degree timing key - softer engagement primary spring - CR 38/36 secondary helix - 83 gram weights (supposedly) - 046 belt - BMP feul pressure regulator - AFR gauge - koso dual egts
So since I bought the sled 1.5 years ago it had a speedwerx ypipe and jaws can and no other mods. Powervalves have been cleaned and adjusted to 35mm and cables checked. I have done all the other mods as listed above. So where I am at not (minus a broken telescopic steering post as of yesterday:frusty is that I spin up to 7550-7600 rpm at WOT (need to adjust weight on clutches) and I have a random bog off idle. I added the AFR gauge and BMP feul pressure regulator to try and see what is happening. When the bog happens, the AFR gauge jumps to 17 and just dashes appear on the display and the feul pressure drops from 42 psi (where its set) to 36 psi. It isn't apparent first thing in the morning but as the day goes on it happens more and more. The bog is hard enough to shut the sled off. If I just did a run and come down to turn around and let it idle down it will do it again...I thought it was tuning until I saw the gauges. Now it makes me think either ECU, stator, or feul pump. Could it be the stator because when I get it revved up it rips awesome...but I have not off idle throttle response, making it hard to ride it deep snow in the trees. Any ideas or solutions?
Other question is what EGT temps are guys running in different RPMs approx. Running down the trail I run damn near 1000 degrees at the 4000-5000 rpm. I also have the left cylinder always being hotter by 200-300 degrees when it starts to heat up.
Any one have these issue? what was it? thoughts? thanks.
