  • I've received emails and PM's asking me about "Group Buys" and promotions.
    A Group Buy here on SnoWestOnline.com would be a situation where a normal member (non vendor or mfg) personally collects orders from other members. That member then uses those orders to negotiate a better price with the Vendor/Mfg for HIS/HER "Group" of buyers.
    Here is an example of a viable "Group Buy"
    http://www.snowestonline.com/forum/showthread.php?t=269222
    A promotion that has the words "Group Buy" in the title is still a promotion, and from the rules that were handed down to me by Harris Publications is that non-advertisers cannot run promotions or open sales programs on the forums outside of the swapmeet.
    If a members wants to become a group buy manager, maintain a thread and collect the funds and negotiate a group buy... as a member, you are welcome to do that as long as you are not attached to the business of the vendor or Mfg.
    If you are a vendor/MFG and you want to offer an EXCLUSIVE "SnoWestOnline ONLY" promotion that is exclusive to snowest readers, please contact me and you'll be able to put it up in the Polaris forums.
    Also, before any vendors/mfgs get all "riled up" over this know that the moderators are strictly volunteers and do not receive a dime from any advertising $$ spent on this site.
    As ALWAYS, since DAY ONE of me becoming a moderator, I have pioneered, supported and encouraged vendors and mfgs in getting the word out to our readers with "New Product Announcements.
    Have a great season.
    From this point on, all vendors/mfg's promoting Pre-Season tiered sales programs, in the Polaris Forums, that are not paid advertisers will be appropriately moved to the swapmeet section of the forums.
    MH
08 D700 BD none inter cooled 3000ish feet base line tuning
Oct 31, 2019
9
Hey dudes. Im building a d700 turbo as an all around fun sled. But...i need help with tuning and base line numbers. As said, its a full boondocker kit with the BD box.
Clutch weights? Thinkin 76ish? Anyone got some base line numbers? Low boost. Even 6-8 pounds will be fine.
Its a dinosaur but someone has to have so.e numbers scribbled down.
ez-ryder
31
Dawson Creek B.C.
boondocker baseline numbers will be rich at 3000 feet. they will work at 5000 alright.
do you have an o2 sensor?
baseline from BD was
psi high 42 60 56
6700 low +2
that should be close at 5000 feet.
because your fighting the Stock ecu changing the tune. it will tune backwards to what your used to. go up in elevation add fuel, go down pull fuel out.
on the low end 3000-5000#s which will be pre boost, it will tune more to what is normal. drop elevation add fuel go up take it away.
boondocking in the trees at elevation often requires going into the -#s in the 3000-5000 screens to make it run decent.
once your trail riding again you'll need to richen up the 3000-5000 screens.
76 will be too much weight more than likely. 8lbs with no timing key is probably almost straight Av gas situation at 3000 feet.
just slowly take fuel out till it pulls and is "on the pipe". at that point it wil be around 11.5 to 1. run it at 12-12.5 to 1
super rich conditions can show super lean on the o2. always make sure your too rich before you take fuel out.
it's pretty easy to tune at WOT.
welcome to the world of watching o2 sensors and play computer games as you ride.
Oct 31, 2019
9
psi high 42 60 56
6700 low +2
Thanks for the info/reply. 8 lbs is probably the max i will run. Just going to keep it super conservative. And probably grab a 3*timing ekey to be able to hopefully run pump gas....or to be able to run av if i start deciding to upthe boost.
Dose anyone make a better tuner for the 700/800 anymore. Something a bit less hands on that you dont have to tune every half hour?haha
ez-ryder
31
Dawson Creek B.C.
you should be able to find a power commander v
it will work better once tuned. far more parameters to work with and map sensors to fix the issues the boondocker box has. I've never used it.
a friend has on rzr 800.
it needs a computer.
you can make some changes with a Android cell phone app.
Jan 3, 2008
659
246
Northern Utah
Dang does that bring back memories....mostly bad ones.. haha. This was initially a bd kit but ended up changing a bunch of stuff and changed over to a dobeck box. Made insane amounts of power but I would of liked to have just kept it how BD intending in the end.
ez-ryder
31
Dawson Creek B.C.
you would want to check if your box has the "air density advantage"
I never ran without it. but I would say it's a good thing. I never noticed having to adjust for temp. so it must work.
