T
Team Snyder
New member
Ok, I took my 07 m1000 out for it's maiden voyage today and it has a few issues. I sent this question to SLP too, but they won't be back until monday. Thought I'd pick the snowest minds.
I bought the full SLP setup for my 07 M1000 (hopefully with the 09 ECU update). I put on the Y-pipe, Pipe, Silencer, with the high flow intake, and PCV. Used 77 MTX weights with their green/yellow spring and a 36/44 helix. This is on a new 3 post clutch with new 46 belt.
Now on to the issue.
It's clutched for 8-1000 feet, and I was below that and right on that with this issue. When I go along the trail between 4000 - 5100 RPMs for a while, then I full throttle it, it feels like it bogs right down and will only go about 6000 RPMs max. I don't know if it's getting too much or too little fuel. BUT, if I have it reved up at 5300 RPM's or greater and ride for a bit, I can full throttle it every time and it hits the power band no problem. It seems like the fuel map might be too rich at the lower RPM's. But I wondered what you techies would think.
I tested this out a lot today, I would be going around 5000 RPMs for about 10 seconds then hammer down the throttle and it would bog and max out about 6000 RPMS.. I would then bring it back down to around 5300 RPMs and ride that for about 4 seconds, then all the power would be back and I'd shoot up to my target of about 7700 RPMs. Almost seems like I burn the excess fuel in the system at the higher RPMs then it's good to go..
Ideas?
Ideas?
