I am having a new problem with my 05 900 rmk. It seems to load up and run real rich and it barely idles. It is stock except for SLP can and gutted airbox. It only idles at about 1000 rpm. When riding it will load up and it will only go to about 4500 or so at WOT. then if you pump the throttle it will eventually clean out and run good at about full throttle or a little under. But when you let off it will sometimes quit or it will barely idle. Also Reverse is not working any more either. It all happened around the same time.
No lights blink or flash to indicate DET or any other sensors. Also the compression checks out good. The plugs are very rich and look fouled, both look the same. Could this be a TPS issue, ECU, any ideas.
Thanks for any help
Thanks for any help
