04 king cat jetting question
4
Oregon
I just picked up a 04 1m king cat 900 carbed. Just trying to make sure my jetting is good before i destroy a cylinder. Currently its running a 360main and a 50 pilot in both carbs. I havent checked needle position yet. My riding area is central Oregon. My. Bachelor, cresent lake, east lake area. Elevation verries from around 4500 feet up to around 8 or 9k ft.
Any help is much appreciated. Everything is stock minus the can.
R
4500- 9000 feet is a pretty big range. With 360s and 50 pilot, you should be rich. Needle can be dropped one or stay in the middle for sure. You will be able to find a manual online also to check your jetting as a guide line. You should have the TMs. There would be a sticker also on the sled as a guide line, depending. If you are too rich, it will run like a pig at rpm and elevation..
Easy to check plugs, so check often. Real pain in the butt to change jets, but performance wins!!
4
Oregon
Well rode this weekend and this is my results. 34deg, elevation around 4300 to 4800' was boggy off the line loaded up a bit had great response at 1/3 to half throttle. Would not get anymore revs after 1/2 and would not go over40mph
