Upgrade to Premium
Reply
  #1
Old 02-29-2008, 11:31 PM
RACINSTATION's Avatar
RACINSTATION RACINSTATION is offline
Currently: Working on 2018 Proclimb mods
RACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond repute
Default Nytro Reverse Bolt Breakage Issue Update
We have seen every one of the Nytros with reverse that we have pulled apart have the broken bolt issue that was posted on here a while ago. There is an updated bolt available. We have them in stock. Yamaha is going to warranty them.
From what I have found the bolt is too long. Even the updated bolt is too long. At the factory during assembly it appears that they bottom out against the driveshaft and then break as soon as the machine goes into use. This is indicated on every one that I have seen by a sheer break. They are shiny which indicates that the two halves of the bolt have been bouncing against each other for quite some time even on low mileage sleds. We are taking 2-3 threads off the new bolt and then installing them.
Have your dealer log all warranties possible. This is the only way to get problems fixed on the assembly line.
Rate this post: Yes | No
  #2
Old 03-01-2008, 08:32 AM
mmaxcarver mmaxcarver is offline
Currently: Not set.
Basic Member
mmaxcarver has a reputation beyond reputemmaxcarver has a reputation beyond reputemmaxcarver has a reputation beyond reputemmaxcarver has a reputation beyond reputemmaxcarver has a reputation beyond reputemmaxcarver has a reputation beyond reputemmaxcarver has a reputation beyond reputemmaxcarver has a reputation beyond reputemmaxcarver has a reputation beyond reputemmaxcarver has a reputation beyond reputemmaxcarver has a reputation beyond repute
Default
So how difficult is it to work on this "reverse" chain case? I've never worked on one containing the reverse option.
  #3
Old 03-01-2008, 09:02 AM
lucky13 lucky13 is offline
Currently: hating all social programs
lucky13 has a reputation beyond reputelucky13 has a reputation beyond reputelucky13 has a reputation beyond reputelucky13 has a reputation beyond reputelucky13 has a reputation beyond reputelucky13 has a reputation beyond reputelucky13 has a reputation beyond reputelucky13 has a reputation beyond reputelucky13 has a reputation beyond reputelucky13 has a reputation beyond reputelucky13 has a reputation beyond repute
Default
i had mine apart last week for a track change the bolt was ok, as for the chaincase its not bad just set everything in a line and place them all up as they come out, pay attention on reassembly to the reverse fork, and test it with the sled in the air by spining the track, also the 2 green bolts need to be removed to get the case off
  #4
Old 03-01-2008, 04:04 PM
Default
Lucky: is yours a reverse model? I ask because EVERY one of the sleds I have been into the bolt was broken. If your bolt is not broken, pull it out and shorten it.
  #5
Old 03-01-2008, 04:08 PM
switchback switchback is offline
Currently: Colorado backcountry fanatic
Basic Member
switchback has a reputation beyond reputeswitchback has a reputation beyond reputeswitchback has a reputation beyond reputeswitchback has a reputation beyond reputeswitchback has a reputation beyond reputeswitchback has a reputation beyond reputeswitchback has a reputation beyond reputeswitchback has a reputation beyond reputeswitchback has a reputation beyond reputeswitchback has a reputation beyond reputeswitchback has a reputation beyond repute
Default
Are there any signs or symptoms of the bolt being broken? Have almost 700 on it with no issues. Did have it apart when I installed the Timbersled and spun the track around and all was fine.
  #6
Old 03-01-2008, 04:11 PM
Default
yes mine is the reverse modle i didnt learn of the problem until i had completed the track switch, one guy did tell me to check it looked good so i just put it back, the new ones that you have are they anything special or just shortened versions. id rather do it myself if possible rather then haul it to the dealer
  #7
Old 03-01-2008, 04:19 PM
Default
NO, the new ones are the same length and from what I can see will break just like the old ones. They need shortened, new or old.
  #8
Old 03-01-2008, 06:55 PM
0007 0007 is offline
Currently: wanting one more good ride
Basic Member
0007 has a reputation beyond repute0007 has a reputation beyond repute0007 has a reputation beyond repute0007 has a reputation beyond repute0007 has a reputation beyond repute0007 has a reputation beyond repute0007 has a reputation beyond repute0007 has a reputation beyond repute0007 has a reputation beyond repute0007 has a reputation beyond repute0007 has a reputation beyond repute
Default
Racinstation, i'm not sure I get it, if the bolt is torqued to 40lbs and bottomed into the driveshaft, how easy was yours to get out?
I cant see an easy out pulling a bolt that is crushed into the bottom of the hole
Also if the bolt can take 40lbs torque then what caused it to break?, there would have been no load on the head
No arguing, just dont see how?
  #9
Old 03-02-2008, 10:11 PM
Nytroman Nytroman is offline
Currently: Not set.
Basic Member
Nytroman is an unknown quantity at this point
Default
Pulled mine apart tonight, broke as well. I measured the depth of the threads into the shaft and there was still 1/2" of thread left behind the broken bolt.Don't see how it would have been bottomed.Drilled it out and used an 8mm wrench to back it out, maybe 5ft/lbs which was probably just the resistance of the loctite. What's breaking it? The thing works with out the bolt so what kind of force would be present to break it. I will try the 2-3 threads off,but not convinced, but also no better solution or explanation!
  #10
Old 03-03-2008, 10:08 AM
Thistledoo's Avatar
Thistledoo Thistledoo is offline
Currently: Bring on the POW!! and dont be shy!!!
Thistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond repute
  #11
Old 03-03-2008, 10:43 AM
ruffryder's Avatar
ruffryder ruffryder is offline
Currently: Not set.
ruffryder has disabled reputation
Click Here to Register
  #12
Old 03-03-2008, 12:45 PM
modsledr modsledr is offline
Currently: Not set.
modsledr has a reputation beyond reputemodsledr has a reputation beyond reputemodsledr has a reputation beyond reputemodsledr has a reputation beyond reputemodsledr has a reputation beyond reputemodsledr has a reputation beyond reputemodsledr has a reputation beyond reputemodsledr has a reputation beyond reputemodsledr has a reputation beyond reputemodsledr has a reputation beyond reputemodsledr has a reputation beyond repute
  #13
Old 03-03-2008, 02:34 PM
Basic Member
  #14
Old 03-03-2008, 02:37 PM
Stlhead Stlhead is offline
Currently: workin
Basic Member
Stlhead is on a distinguished roadStlhead is on a distinguished roadStlhead is on a distinguished roadStlhead is on a distinguished roadStlhead is on a distinguished roadStlhead is on a distinguished road
  #15
Old 03-03-2008, 08:35 PM
  #16
Old 03-03-2008, 08:41 PM
rednytro rednytro is offline
Currently: Not set.
Basic Member
rednytro will become famous soon enoughrednytro will become famous soon enoughrednytro will become famous soon enoughrednytro will become famous soon enoughrednytro will become famous soon enoughrednytro will become famous soon enoughrednytro will become famous soon enoughrednytro will become famous soon enoughrednytro will become famous soon enough
  #17
Old 03-03-2008, 09:39 PM
  #18
Old 03-03-2008, 09:46 PM
Currently: Not set.
  #19
Old 03-03-2008, 10:24 PM
  #20
Old 03-03-2008, 10:50 PM
redsnake3 redsnake3 is offline
Currently: Not set.
Basic Member
redsnake3 is just really niceredsnake3 is just really niceredsnake3 is just really niceredsnake3 is just really niceredsnake3 is just really niceredsnake3 is just really niceredsnake3 is just really niceredsnake3 is just really niceredsnake3 is just really niceredsnake3 is just really niceredsnake3 is just really nice
  #21
Old 03-03-2008, 10:52 PM
Currently: Not set.
Basic Member
  #22
Old 03-03-2008, 10:54 PM
  #23
Old 03-04-2008, 03:34 AM
firecat99 firecat99 is offline
Currently: Not set.
Basic Member
firecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond repute
Garage
  #24
Old 03-04-2008, 08:29 AM
  #25
Old 03-04-2008, 08:44 AM
lightening800's Avatar
lightening800 lightening800 is offline
Currently: building my 174x
lightening800 has disabled reputation
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
