Upgrade to Premium
Reply
  #1
Old 02-19-2008, 06:38 PM
B_DIDDY_SHOEY B_DIDDY_SHOEY is offline
Currently: SNOWREALLY?
Basic Member
B_DIDDY_SHOEY has a reputation beyond reputeB_DIDDY_SHOEY has a reputation beyond reputeB_DIDDY_SHOEY has a reputation beyond reputeB_DIDDY_SHOEY has a reputation beyond reputeB_DIDDY_SHOEY has a reputation beyond reputeB_DIDDY_SHOEY has a reputation beyond reputeB_DIDDY_SHOEY has a reputation beyond reputeB_DIDDY_SHOEY has a reputation beyond reputeB_DIDDY_SHOEY has a reputation beyond reputeB_DIDDY_SHOEY has a reputation beyond reputeB_DIDDY_SHOEY has a reputation beyond repute
Default 1999 MXZ-X 440 Excellent Cond. N-Idaho $1750
FOR SALE: Excellent Running sled that has been converted into a high performance trail sled. Has lower compression heads installed to run regular pump gas now. Factory it was setup w/high comp heads to run race fuel. It was a Skidoo sponsore sled, which our friends wife raced four races in 99 before breaking her leg. It was then rode by their younger daughter and garaged until we purchased it in 2005.
I purchased my wife a new sled this year and we were going to keep this for a spare but since have changed our minds. Especially since it has sat in the garage all winter and only been rode a couple times around the house.
Condition:
Engine - Refreshed in 2000, very strong running sled, three pull starts cold.
Clutches - Good condition, Professionally built. I installed new aluminum TRA arms, weights, pins, rollers two years ago when we purchased the sled and replaced the titanium arms that were setup more for racing then mountain trail riding. Still have titanium arms that will go w/sled.
Track - Excellent, no tears, fraying, missing lugs, etc. Is drilled for studs.
Suspension - Excellent has high performance race suspension on rear that was refreshed in 2000 and stills all rides very well.
Hifax - Good shape
Ski's Skags - Good Condition
Overall sled condition is an 8 of 10 as it is in great shape w/no damaged, other then what is stated. The hood, seat, tunnel, console, bumpers, etc is all in perfect condition and overall you won't find another 440 mxzx that looks this good and runs this strong!
Damage:
Small Belly pan crack - brake side
Small ding on trailing arm - throttle side, seen in photos. It is from another sled ski hitting it and is just on the flat surface area so it has not weakened the arm. It has been rode like that for the past 7 years.
Specs:
440 Liquid Cooled Motor
Machined, Balanced Team Primary Clutch by Kinetic
Kinetic Race Roller Secondary Clutch
GP Racing Rear Suspension
Pro Taper 2" Riser
Answer Alumilite 2 Handlebars
Power Madd Hand Guards
Steel extended Brake Line
Rear Drag Wheel Blocks on rails
Running Board traction/strengthen boards
Hole Shot Skid Plate
Cobra Windshield - low
Stripped of all graphics
10.5 Gallon Clear Trail Fuel Tank
Hand Warmers
Primer starter
Liquid Cooled Motor
Sled will outrun most stock 600's on hardpack snow!
Sled is a factory race sled so it does not have a speedo or mileage guage. Mileage would be under 1500miles I would guess
It would make a great sled for anyone and be better off getting used then sitting in my garage.
Contact Info:
Bucky Shoemaker
Phone # 208-413-2205
Email:buckyshoemaker@yahoo.com
Sled Location: St.Maries, Idaho (50miles from Couerdalene ID; or Spokane Wa)
Rate this post: Yes | No
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
no new posts
