Just for your records. 07 800ho top gun 144
here is my clutch setups so far and still trying for better results. Went to the big horns 2 weeks ago. 8000ft primary clutch 160-290 spring 10.5 gram pin weight stock 417 ramps clicker 3 and stock secondary. results 150 rpm over rev on trail about right in pow but not getting full shift out on primary clutch.
My new setup is same spring 13.5 grams pin weight and 415 ramps
changed secondary to straight 44degree cam with black spring from brp. My brother is testing out this week in the black hills SD. around 5k feet I think. Will post results.
Ps. I modified the air box with screen to let it breath some good air.
If anyone has any suggestions feel free to share the info.
