Upgrade to Premium
Reply
  #1
Old 12-30-2007, 04:01 AM
golfsnownut golfsnownut is offline
Currently: Not set.
Basic Member
golfsnownut has a reputation beyond reputegolfsnownut has a reputation beyond reputegolfsnownut has a reputation beyond reputegolfsnownut has a reputation beyond reputegolfsnownut has a reputation beyond reputegolfsnownut has a reputation beyond reputegolfsnownut has a reputation beyond reputegolfsnownut has a reputation beyond reputegolfsnownut has a reputation beyond reputegolfsnownut has a reputation beyond reputegolfsnownut has a reputation beyond repute
Default Help!!!!! Zr600 Efi
My sled has little hard starting time, takes more than few pulls to start then it wouldn't idle for long once it starts up. It would idle at very low rpm under 500 for like 10 seconds before it dies. It would start up again after one or two pulls but still idles very low under 500 rpm before it dies again. After 3 or 4 times then it will finally idle up around 2000 rpm fine. It did same thing before rebuild engine and replaced stator during rebuilding as preventative maintanence and that doesnt change anything with idle issues. One more added note, during very low rpm idle, it would dies immediately if I try to blip the throttle a bit to rev up. Bad sensor? Where do I start looking for?
Rate this post: Yes | No
  #2
Old 12-30-2007, 09:14 AM
mountainguy mountainguy is offline
Currently: Not set.
Basic Member
mountainguy has a brilliant futuremountainguy has a brilliant futuremountainguy has a brilliant futuremountainguy has a brilliant futuremountainguy has a brilliant futuremountainguy has a brilliant futuremountainguy has a brilliant futuremountainguy has a brilliant futuremountainguy has a brilliant futuremountainguy has a brilliant futuremountainguy has a brilliant future
Default
You may want to check fuel pressure. Also check all elect connections loose or dirty a little die electric is a good thing to use. Maybe even check the stator is timed correctly . Good luck
  #3
Old 12-30-2007, 09:30 AM
SaberKitty's Avatar
SaberKitty SaberKitty is offline
Currently: Waiting for the new 800 engine...
SaberKitty has a reputation beyond reputeSaberKitty has a reputation beyond reputeSaberKitty has a reputation beyond reputeSaberKitty has a reputation beyond reputeSaberKitty has a reputation beyond reputeSaberKitty has a reputation beyond reputeSaberKitty has a reputation beyond reputeSaberKitty has a reputation beyond reputeSaberKitty has a reputation beyond reputeSaberKitty has a reputation beyond reputeSaberKitty has a reputation beyond repute
Default
Sounds like bad, old gasoline in the tank.
__________________
2013 M800 Sno Pro Limited Black 153 w/o ES
2012 M800 Sno Pro 153 Vader makeover
And a retired pair of sequential serial number 2008 M8 Nightfire Sno Pros
Black - It's the new green
Away from internet riding for
  #4
Old 12-30-2007, 09:37 AM
tivoklr tivoklr is offline
Currently: watching the snow fall
Basic Member
tivoklr has a reputation beyond reputetivoklr has a reputation beyond reputetivoklr has a reputation beyond reputetivoklr has a reputation beyond reputetivoklr has a reputation beyond reputetivoklr has a reputation beyond reputetivoklr has a reputation beyond reputetivoklr has a reputation beyond reputetivoklr has a reputation beyond reputetivoklr has a reputation beyond reputetivoklr has a reputation beyond repute
Default Mine has done this forever
My 99 600efi has done this since I got it, I would get it to start on the 3rd pull and it would sit there and idle really low and if you give it any throttle it dies.
Pull again and all is well, at least it has been in the past.
However, now mine doesn't spark...it did a month ago, but not anymore. Still getting power to the lights and gauges and such...
I would love to resolve the weird low idle problem once I get it to run...I don't think it's fuel as mine has idled like this forever with good fuel and bad...
Hopefully someone can shed some light on this for us.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
no new posts
