Upgrade to Premium
Reply
  #1
Old 09-11-2018, 02:52 PM
wwillf01's Avatar
wwillf01 wwillf01 is online now
Currently: Praying for snow
wwillf01 has a reputation beyond reputewwillf01 has a reputation beyond reputewwillf01 has a reputation beyond reputewwillf01 has a reputation beyond reputewwillf01 has a reputation beyond reputewwillf01 has a reputation beyond reputewwillf01 has a reputation beyond reputewwillf01 has a reputation beyond reputewwillf01 has a reputation beyond reputewwillf01 has a reputation beyond reputewwillf01 has a reputation beyond repute
Default New Yeti Suggestions
Picking up an 18 ....... So far I am going to pull every bolt and piece and red loctite them in along with checking them regularly. Any other suggestions on prep?
Rate this post: Yes | No
  #2
Old 09-11-2018, 08:06 PM
needpowder's Avatar
needpowder needpowder is offline
Currently: dreaming of global cooling
needpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond repute
Default Talk to toby
He seems to have them dialed.
__________________
2016 YZ450fx w/16 TS LT
The Following User Says Thank You to needpowder For This Useful Post:
wwillf01 (09-11-2018)
  #3
Old 09-11-2018, 08:29 PM
Misha Subo Misha Subo is online now
Currently: 2 x('18Camso/'08KTM300 XCW)
Basic Member
Misha Subo has a reputation beyond reputeMisha Subo has a reputation beyond reputeMisha Subo has a reputation beyond reputeMisha Subo has a reputation beyond reputeMisha Subo has a reputation beyond reputeMisha Subo has a reputation beyond reputeMisha Subo has a reputation beyond reputeMisha Subo has a reputation beyond reputeMisha Subo has a reputation beyond reputeMisha Subo has a reputation beyond reputeMisha Subo has a reputation beyond repute
Default
Isn't red Loctite a little too strong for that...blue?
The Following User Says Thank You to Misha Subo For This Useful Post:
  #4
Old 09-11-2018, 08:39 PM
wwillf01's Avatar
Default
Quote:
Agreed .. but I keep reading where they keep coming out... I know I ended up using red loctite on the 15 timbersled with the cr500 but the bolts we're not titanium.
  #5
Old 09-12-2018, 08:21 AM
M5- M5- is online now
Currently: Planning a build
Basic Member
M5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond repute
Default
I'm not sure any color of Loctite can stand up to a CR500, it is the ultimate test bed for thread lockers.
M5
  #6
Old 09-12-2018, 08:28 AM
tillbuilt's Avatar
tillbuilt tillbuilt is offline
Currently: Let there be SNOW!!!
tillbuilt has a reputation beyond reputetillbuilt has a reputation beyond reputetillbuilt has a reputation beyond reputetillbuilt has a reputation beyond reputetillbuilt has a reputation beyond reputetillbuilt has a reputation beyond reputetillbuilt has a reputation beyond reputetillbuilt has a reputation beyond reputetillbuilt has a reputation beyond reputetillbuilt has a reputation beyond reputetillbuilt has a reputation beyond repute
Default
Quote:
What model are you getting?
__________________
Toby Till
http://rockymountainsnowmx.com/
Dealer for Yeti, and Camso
Denver, Co. Ph: 720-263-7533. Email: toby@rockymountainsnowmx.com
18' Yamaha YZ450F 19' Yeti 137 (Blue Ranger), 17' KTM 350 SX-F 18' Yeti 129 SS (The Flash), 17' Yamaha YZ250 18' Yeti 129 SS (Wonder Woman)
  #7
Old 09-12-2018, 09:06 AM
wwillf01's Avatar
Default
18 129ss......
Sent from my Pixel 2 XL using Tapatalk
  #8
Old 09-12-2018, 01:55 PM
Excalibur's Avatar
Excalibur Excalibur is online now
Currently: Need snow!!!!
Excalibur has a reputation beyond reputeExcalibur has a reputation beyond reputeExcalibur has a reputation beyond reputeExcalibur has a reputation beyond reputeExcalibur has a reputation beyond reputeExcalibur has a reputation beyond reputeExcalibur has a reputation beyond reputeExcalibur has a reputation beyond reputeExcalibur has a reputation beyond reputeExcalibur has a reputation beyond reputeExcalibur has a reputation beyond repute
Default
They are a good unit! I have a 2018 129 SS I ran last season. No broken parts, no lost bolts. Very little belt stretch or bolts that needed re torqued.
After each ride - Check the belt tension. Check torque on all bolts including ski/spindle. Dry, lube and check drive chain. Inspect the complete unit including ski and spindle assy. Check the track tension.
Very happy with it! I have a 2019 129 SS on the way. Just not sure I want to let the 18 go. Hope the 19 is as dependable! Had good success with two ARO 120s also. (My daughters ride them).
The Following User Says Thank You to Excalibur For This Useful Post:
wwillf01 (09-12-2018)
  #9
Old 09-12-2018, 02:47 PM
tillbuilt's Avatar
Default
18 129ss......
No need to get crazy with the Red Locktite. Blue is factory spec. Even with Red the 8 suspension arm bolts will still work their way loose. Just get in a habit of torquing the 12 bolts in the suspension every other ride and you will be fine.
Make sure TSB's have been preformed. Jack Shaft bearing shaft alignment (129SS only), and the brake caliper bolt torq and re-Locktite.
__________________
Toby Till
The Following User Says Thank You to tillbuilt For This Useful Post:
  #10
Old 09-13-2018, 10:34 AM
byeatts byeatts is online now
Currently: Not set.
byeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond repute
The Following User Says Thank You to byeatts For This Useful Post:
wwillf01 (09-13-2018)
  #11
Old 10-04-2018, 08:13 AM
wwillf01's Avatar
Click Here to Register
  #12
Old 10-04-2018, 08:27 AM
wwillf01's Avatar
  #13
Old 10-04-2018, 08:56 AM
Basic Member
The Following User Says Thank You to M5- For This Useful Post:
wwillf01 (10-04-2018)
  #14
Old 10-04-2018, 08:59 AM
wwillf01's Avatar
  #15
Old 10-04-2018, 09:04 AM
Basic Member
  #16
Old 10-04-2018, 09:25 AM
wwillf01's Avatar
  #17
Old 10-04-2018, 09:36 AM
wwillf01's Avatar
  #18
Old 10-04-2018, 09:39 AM
ChrisNeibauer ChrisNeibauer is offline
Currently: Not set.
ChrisNeibauer has a reputation beyond reputeChrisNeibauer has a reputation beyond reputeChrisNeibauer has a reputation beyond reputeChrisNeibauer has a reputation beyond reputeChrisNeibauer has a reputation beyond reputeChrisNeibauer has a reputation beyond reputeChrisNeibauer has a reputation beyond reputeChrisNeibauer has a reputation beyond reputeChrisNeibauer has a reputation beyond reputeChrisNeibauer has a reputation beyond reputeChrisNeibauer has a reputation beyond repute
  #19
Old 10-04-2018, 10:24 AM
Currently: Not set.
  #20
Old 10-04-2018, 11:45 AM
Basic Member
  #21
Old 10-04-2018, 12:30 PM
Currently: Not set.
  #22
Old 10-04-2018, 02:45 PM
Sheetmetalfab's Avatar
Sheetmetalfab Sheetmetalfab is online now
Currently: Riding the R6 TS LT and building the ZX6R 636
Sheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — New never used Yeti Can Thread Starter — SNOW JW Forum — Snowbikes & Parts (Swapmeet) Replies — 0 Last Post — 03-09-2017 02:35 PM
Thread — Yeti Ski and Yeti Wheel Kit For Timbersled Thread Starter — ArgyllMotorsports Forum — Snowbikes & Parts (Swapmeet) Replies — 0 Last Post — 02-04-2016 09:44 AM
Thread — Yeti:) Thread Starter — yukondood Forum — Snow bikes Replies — 1 Last Post — 01-03-2016 01:01 AM
Thread — YETI for sale Thread Starter — ROZZY MX Forum — Snowbikes & Parts (Swapmeet) Replies — 1 Last Post — 12-09-2015 09:37 AM
Thread — WHO WANTS A YETI!!! Thread Starter — WKR Forum — Snowbikes & Parts (Swapmeet) Replies — 2 Last Post — 04-06-2015 08:01 PM
no new posts
