Upgrade to Premium
Reply
  #1
Old 09-11-2018, 12:52 PM
Yaeger34 Yaeger34 is offline
Currently: Not set.
Yaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond repute
Default g2 proclimb 7 skis
Figured I would just make a quick topic on this as info is scattered in many topics. Want to put a set on the 18. From what I gather it requires
2 skis
2 dampeners
2 bolts/nuts
8 spacers
4 bearings
2 spindle bushings all off the 19, correct?
If so I show it being $245.
I can't find a new set or good used set of carbiders of gripper pros for that either so is this the way to go?
Rate this post: Yes | No
  #2
Old 09-11-2018, 03:50 PM
Marble Marble is offline
Currently: Not set.
Basic Member
Marble has a reputation beyond reputeMarble has a reputation beyond reputeMarble has a reputation beyond reputeMarble has a reputation beyond reputeMarble has a reputation beyond reputeMarble has a reputation beyond reputeMarble has a reputation beyond reputeMarble has a reputation beyond reputeMarble has a reputation beyond reputeMarble has a reputation beyond reputeMarble has a reputation beyond repute
Default
I currently does the mod
2 g2 proclimb skis
2 dampers
2 spindle axle bolts
You can reuse
- 2 spindle axle nuts
- spacers
- spindle axle (cut it)
- carbides
- handles with bolts
- sleeves on skis for spindle axle bolts
  #3
Old 09-11-2018, 04:11 PM
Currently: Not set.
Default
Like it? Big difference?
  #4
Old 09-11-2018, 04:28 PM
Currently: Not set.
Basic Member
Default
I will try to take a time for upload a pictures but yes, more balanced, better keel and more stronger than my g1. New gen skis are very similar to Gripper and stronger than my grippers (grippers like to eat a damper( 2 per ride, and after 1000miles my gripper are like a banana because it flex alot)
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to Marble For This Useful Post:
summ8rmk (09-12-2018)
  #5
Old 09-11-2018, 04:44 PM
Currently: Not set.
Basic Member
Default
20180910_113503 20180910_113435 20180910_113354 20180910_113345
  #6
Old 09-12-2018, 07:25 PM
jdsauter jdsauter is offline
Currently: Not set.
Basic Member
jdsauter is an unknown quantity at this point
Default
Is the 2019 axle longer, and do you need the new dampers and axle bolts? I just order the ski bottoms, just figures all parts from 2017 would fit?
JD
  #7
Old 09-14-2018, 01:25 PM
Currently: Not set.
Default
Got it all ordered. Seems it is all on back order until the middle of november
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Proclimb 7 Skis Thread Starter — MountainCat1 Forum — Arctic Cat: Proclimb M Replies — 0 Last Post — 02-12-2018 09:53 PM
Thread — ProClimb take-off skis Thread Starter — TNTCOPP Forum — Skis (Swapmeet) Replies — 10 Last Post — 10-18-2015 04:08 PM
Thread — Proclimb skis Thread Starter — rattlehead121 Forum — Skis (Swapmeet) Replies — 1 Last Post — 01-10-2014 10:55 PM
Thread — Simmons Gen III skis with Arctic Cat Proclimb Mounts - Skis Sold Thread Starter — WFOWA Forum — Skis (Swapmeet) Replies — 2 Last Post — 04-03-2013 05:28 PM
Thread — m skis on proclimb ??? Thread Starter — akwakely Forum — Arctic Cat: Proclimb M Replies — 5 Last Post — 11-12-2012 08:42 AM
no new posts
