Upgrade to Premium
Reply
  #1
Old 09-11-2018, 08:54 AM
ultrasks700 ultrasks700 is offline
Currently: twisting wrenches
ultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond repute
Default Ctec Preseason Maintenance
Whats the protocall for the preseason maintenance on these engines? Besides the typical chassis stuff(chaincase oil change, greasing, etc). From what i hear the powervalve cleaning is a very lengthy procedure, should it be done every year? Anything else specific to look at?
__________________
2018 Mountain Cat ES
Mechanical Engineer
Maine Rider
Rate this post: Yes | No
  #2
Old 09-11-2018, 09:18 PM
bdcat162 bdcat162 is offline
Currently: Not set.
Basic Member
bdcat162 has a brilliant futurebdcat162 has a brilliant futurebdcat162 has a brilliant futurebdcat162 has a brilliant futurebdcat162 has a brilliant futurebdcat162 has a brilliant futurebdcat162 has a brilliant futurebdcat162 has a brilliant futurebdcat162 has a brilliant futurebdcat162 has a brilliant futurebdcat162 has a brilliant future
Default
In addition to those things checking plugs wouldn't be a bad idea either. I didn't even realize the pull cord was frayed and just about frayed through(damn routing from factory).Might not be a bad idea to look that over. Cobra is what I'm replacing mine with.
  #3
Old 09-12-2018, 02:10 PM
Uncle Bob Uncle Bob is offline
Currently: Not set.
Uncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond reputeUncle Bob has a reputation beyond repute
Default
I hate to be that guy but cant help it, The pre season list should include fill with fresh fuel, pull the rope and go. All that stuff mentioned is actually called post season maintenance done in the spring. LOL
I realize i deserve a couple of thumbs down for this one HEHEHE
2 out of 2 members found this post helpful. Rate this post: Yes | No
  #4
Old 09-13-2018, 06:07 AM
Old & slow Old & slow is offline
Currently: Not set.
Old & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond repute
Default
Quote:
The service manual says to check the pv cable every 2600 miles and clean the valves periodically. Personally I would check the cable length and ride it, the only reason i would check the cable is a few were poorly adjusted from the factory/dealer and I drive 6 hours to ride. The valves I have never touched on any of my Cat sleds. To clean the valves on a C-Tec the cylinder needs to be removed from the crankcase.
  #5
Old 09-13-2018, 08:36 AM
summ8rmk's Avatar
summ8rmk summ8rmk is online now
Currently: Alpha Hawk!
summ8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond repute
Default
U don't need to remove the cylinders to clean the valves.
Remove the outside side-valve and pull the rod out then pull the main valve like a zuke.
The Following User Says Thank You to summ8rmk For This Useful Post:
fudge313 (09-13-2018)
  #6
Old 09-14-2018, 05:47 AM
Currently: Not set.
Default
Just going by the service manual,I personally have not done one yet. Thanks for the info.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — ctec 2 exhaust Thread Starter — dw8 Forum — 2018 Ascender Replies — 18 Last Post — 11-14-2018 02:25 PM
Thread — Flutter ctec Thread Starter — powder79 Forum — 2018 Ascender Replies — 16 Last Post — 05-09-2018 09:06 PM
Thread — Ctec bog Thread Starter — SnoPro1000 Forum — 2018 Ascender Replies — 10 Last Post — 01-25-2018 09:48 PM
Thread — Preseason maintenance Thread Starter — 0neoldfart Forum — Arctic Cat: 1100 ProClimb Replies — 4 Last Post — 09-12-2014 10:08 PM
Thread — Sled Maintenance. What maintenance needs to be performed and how often? Thread Starter — Schwartz Forum — Polaris Replies — 9 Last Post — 03-17-2009 08:42 AM
no new posts
