Upgrade to Premium
Polaris: AXYS 2016 AXYS chassis
Reply
  #1
Old 09-05-2018, 09:12 PM
alt's Avatar
alt alt is offline
Currently: Not set.
alt has a reputation beyond reputealt has a reputation beyond reputealt has a reputation beyond reputealt has a reputation beyond reputealt has a reputation beyond reputealt has a reputation beyond reputealt has a reputation beyond reputealt has a reputation beyond reputealt has a reputation beyond reputealt has a reputation beyond reputealt has a reputation beyond repute
Default NEW Alternative Impact "TRUE" clearance a arms
New for this season we have the "TRUE" ground clearance arms. These are truly arched arm at both the front and rear tubes. Pictured are for the 36-38" adjustable ski stance. They are a direct stock replacement with benefits. Same geometry as the 850, will also be available for the 2013-18. Save and reuse your expensive aftermarket shocks from your 2016-18 axys, these will maintain the same ride height and geometry as the stock 2019 36". We haven't been able to post everything yet on the website, but we will have a lower only kit for $449.00. Complete kit is $595.00. Both kits come with absolutely everything to direct bolt on (reuse bulkhead axles). Standard colors as always, red, black and working on the lime squeeze when we get the color dialed in. Thanks for looking!
Dan
__________________
www.alternativeimpact.com
406-222-2586
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following 4 Users Say Thank You to alt For This Useful Post:
hamlin (10-05-2018), mountainhorse (10-05-2018), no_uh (09-05-2018), sledhed (09-05-2018)
  #2
Old 09-05-2018, 10:41 PM
goridedoo's Avatar
goridedoo goridedoo is online now
Currently: Not set.
goridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond repute
Default
So I am guessing the lowers can be used with factory uppers on the 2019?
  #3
Old 09-05-2018, 11:01 PM
no_uh no_uh is online now
Currently: Not set.
Basic Member
no_uh has a reputation beyond reputeno_uh has a reputation beyond reputeno_uh has a reputation beyond reputeno_uh has a reputation beyond reputeno_uh has a reputation beyond reputeno_uh has a reputation beyond reputeno_uh has a reputation beyond reputeno_uh has a reputation beyond reputeno_uh has a reputation beyond reputeno_uh has a reputation beyond reputeno_uh has a reputation beyond repute
Default
Nice. Let's see some installed pics!
  #4
Old 09-06-2018, 01:02 AM
Jona$ Jona$ is online now
Currently: sks800 -16
Jona$ has a reputation beyond reputeJona$ has a reputation beyond reputeJona$ has a reputation beyond reputeJona$ has a reputation beyond reputeJona$ has a reputation beyond reputeJona$ has a reputation beyond reputeJona$ has a reputation beyond reputeJona$ has a reputation beyond reputeJona$ has a reputation beyond reputeJona$ has a reputation beyond reputeJona$ has a reputation beyond repute
Default
Will they come in any "heavy duty" version ?
The Following User Says Thank You to Jona$ For This Useful Post:
Sheetmetalfab (09-06-2018)
  #5
Old 09-06-2018, 08:42 AM
Teth-Air's Avatar
Teth-Air Teth-Air is offline
Currently: sourceinnovations.ca
Teth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond repute
Default
Weight savings?
__________________
Home of the "Cordless Teth-Air" and NEW "Phantom Teth-Air"
http://www.sourceinnovations.ca
We also have TKI Belt Drives, Arm Candy A-Arm Braces, Oil Tank Inserts, Reversible Scratchers, Polaris Suspension Couplers, Track Clips, Clutching and more.
  #6
Old 09-06-2018, 10:53 AM
alt's Avatar
alt alt is offline
Currently: Not set.
Default
Correct, they absolutely can be used in conjunction with the stock rmk 2019 uppers, actually a better route imo. Obviously no weight savings with the cromoly so that way going with the lower kit a guy can utilize the weight savings of the stock uppers unless you want the whole kit and have a complete look or spare parts. They are all in the heavy duty version, we also added some strength to the titanium arms which added VERY little as far as weight. I'll get some weight savings numbers later for the Ti kit.
__________________
406-222-2586
The Following 2 Users Say Thank You to alt For This Useful Post:
goridedoo (09-06-2018), Teth-Air (09-06-2018)
  #7
Old 09-08-2018, 11:16 AM
alt's Avatar
alt alt is offline
Currently: Not set.
Default
So the lower moly kit adds 1.42#
Ti kit is 2.42# savings
Again this would be for the 19 rmk, so we're comparing apples to apples.
I haven't gotten to it yet but because people jump from sections, we do have these for the Doo 36" as well. Just waiting for arms to get back from powder coat to post.
Thanks guys
Dan
__________________
406-222-2586
The Following User Says Thank You to alt For This Useful Post:
ak (09-09-2018)
  #8
Old 10-05-2018, 10:10 AM
pauly815 pauly815 is online now
Currently: Not set.
pauly815 has a reputation beyond reputepauly815 has a reputation beyond reputepauly815 has a reputation beyond reputepauly815 has a reputation beyond reputepauly815 has a reputation beyond reputepauly815 has a reputation beyond reputepauly815 has a reputation beyond reputepauly815 has a reputation beyond reputepauly815 has a reputation beyond reputepauly815 has a reputation beyond reputepauly815 has a reputation beyond repute
Default
Anyone have thoughts on witch Alt 36'' kit to go with on a new 18 Axys 163 2.6? Is the new 19 geometry that much better? Had an Alt 36'' on my Pro and loved it.
__________________
pc pauly
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Axys: new Alternative Impact 36" A-arms Thread Starter — nregistered Forum — Suspension/Shocks (Swapmeet) Replies — 0 Last Post — 10-12-2017 09:35 AM
Thread — 36" alternative impact a arms Thread Starter — shortstuff Forum — Suspension/Shocks (Swapmeet) Replies — 4 Last Post — 09-13-2016 07:31 AM
Thread — Alternative Impact 36" A arms for Pro Thread Starter — hd4rob Forum — Suspension/Shocks (Swapmeet) Replies — 1 Last Post — 03-02-2016 10:03 AM
Thread — 38" Alternative impact A-Arms Thread Starter — no fear Forum — Arctic Cat: Proclimb M Replies — 6 Last Post — 02-26-2014 05:13 PM
Thread — Alternative Impact 38" a-arms Thread Starter — alt Forum — Arctic Cat: Proclimb M Replies — 4 Last Post — 09-17-2013 08:12 PM
no new posts
