Upgrade to Premium
Reply
  #1
Old 09-05-2018, 08:33 PM
Chewy22's Avatar
Chewy22 Chewy22 is online now
Currently: Not set.
Chewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond repute
Default Iceage ELEVATE kit - interesting!!!
Who all has seen this? Looks interesting.
Post on Instagram
Rate this post: Yes | No
  #2
Old 09-05-2018, 09:15 PM
summ8rmk's Avatar
summ8rmk summ8rmk is online now
Currently: Snow angels in dog parks
summ8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond repute
Default
iceageperformanceTake your riding to the next level with the ELEVATE kit by IceAge Performance. Starting with the already powerful platform of the Arctic Cat, we built a spindle / rail combination that drastically improves the agility, handling, and deep snow performance by lifting the chassis to a height similar to it's OEM counterparts. This increase in height allows the sled to glide over the snow with ease and reduces running board and side panel drag. The ELEVATE kit turns your Arctic Cat into a machine capable of dominating the gnarliest terrain the mountains can throw at you. The kit includes spindles, rails, and all the hardware necessary to install.
  #3
Old 09-05-2018, 10:50 PM
boondocker97 boondocker97 is online now
Currently: working for the man
boondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond repute
Default
Raises front end 2" and rear 3/4" with spindles and rail kit.
http://www.iceageperformance.com/arc...r-chassis.html
Wonder if they'd sell me just the front end parts since I'm already an inch or more higher in the rear with my kmod?
__________________
Current Sleds:
2014-2018ish BDX Pro-Lite 900, 2005 M7 with upgrades - Ol' Reliable, 1974 Cheetah
Still in the Family:
2009 M1300, 2001 Mountain Cat 800 LE, 1972 Kitty Cat
Gone but not Forgotten:
1999 Powder Special 600 LE, 1998 Powder Special 600, 1993 EXT 550, 1980 JAG 340
  #4
Old 09-05-2018, 10:57 PM
Suzzy-Q Suzzy-Q is online now
Currently: Not set.
Suzzy-Q has a reputation beyond reputeSuzzy-Q has a reputation beyond reputeSuzzy-Q has a reputation beyond reputeSuzzy-Q has a reputation beyond reputeSuzzy-Q has a reputation beyond reputeSuzzy-Q has a reputation beyond reputeSuzzy-Q has a reputation beyond reputeSuzzy-Q has a reputation beyond reputeSuzzy-Q has a reputation beyond reputeSuzzy-Q has a reputation beyond reputeSuzzy-Q has a reputation beyond repute
Default
I too would be interested in just spindles, i put a 38” front end on my 2012 with non shortened shocks and liked the slightly taller front end
__________________
2017 mountain cat 153; SSI stainless can/y-pipe, SSI pipe mod, pro-cool head, boysen rage cages, Mohawks
2012 sp, 38" front, 162x3, slp stage 2,PCV with timing, mountain fit hood, C3 Belt Drive 2.52, WRP seat, BDX boards(SOLD)
The Following User Says Thank You to Suzzy-Q For This Useful Post:
Hewhospends (10-13-2018)
  #5
Old 09-06-2018, 04:33 AM
ultrasks700 ultrasks700 is offline
Currently: twisting wrenches
ultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond repute
Default
Great!...another expensive part I really really want
__________________
2018 Mountain Cat ES
Mechanical Engineer
Maine Rider
The Following User Says Thank You to ultrasks700 For This Useful Post:
sno*jet (09-06-2018)
  #6
Old 09-06-2018, 07:01 AM
Yaeger34 Yaeger34 is offline
Currently: Not set.
Yaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond repute
Default
Couple things. One is this suppose to make this comparable to the axys, is that kind of the goal as far as approach angle and lifting it? I only got to ride an 18 on a 2ft pow day that quickly turned to 55 degree concrete but it was getting hung up a lot.
Second when you go to the new g2 ski for the 19 cats, does this spingle set up work for that or ?
3rd how do replacement spindles and cost work
4, shock length and all that the same?
  #7
Old 09-06-2018, 07:15 AM
summ8rmk's Avatar
Default
Quote:
Second when you go to the new g2 ski for the 19 cats, does this spingle set up work for that or ? Spindles are the same from 2016-2019 so, there is no reason it won't work with 19 skis.
4, shock length and all that the same? The front shocks mount to the A-arm, the spindle is 2in longer below the A-arm so, same shocks.
In their pics, the rear rail is taller and they lowered the front mount in the tunnel so, that doesn't effect the shock length.....
  #8
Old 09-06-2018, 07:33 AM
summ8rmk's Avatar
Default
Wonder if lowering the tunnel mount is necessary?
$1,795 seems high for rails($600) and spindles($1,195)...?
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to summ8rmk For This Useful Post:
DDECKER (09-06-2018)
  #9
Old 09-06-2018, 07:52 AM
jakey-boy jakey-boy is online now
Currently: Not set.
jakey-boy has a reputation beyond reputejakey-boy has a reputation beyond reputejakey-boy has a reputation beyond reputejakey-boy has a reputation beyond reputejakey-boy has a reputation beyond reputejakey-boy has a reputation beyond reputejakey-boy has a reputation beyond reputejakey-boy has a reputation beyond reputejakey-boy has a reputation beyond reputejakey-boy has a reputation beyond reputejakey-boy has a reputation beyond repute
Garage
Default
Shut up and run my card.
__________________
TheJKYboy
Click here for Awesome Sled Pics!!!
3 out of 3 members found this post helpful. Rate this post: Yes | No
The Following 2 Users Say Thank You to jakey-boy For This Useful Post:
BLITZKRIEG (09-06-2018), DDECKER (09-06-2018)
  #10
Old 09-06-2018, 08:54 AM
Default
Apparently they're charging $900 for a set of "custom" 156 rails for a Cat now. So these are probably more like $1000 rails and $800 spindles
Regardless I intend to call after Haydays to get some info on what all is included, thinking behind the design/geometry, and hopefully some part weights. Curious what the deal with the steering stop is.
__________________
Current Sleds:
  #11
Old 09-06-2018, 07:59 PM
Chewy22's Avatar
Currently: Not set.
Click Here to Register
  #12
Old 09-06-2018, 10:16 PM
Currently: Not set.
  #13
Old 09-06-2018, 10:20 PM
summ8rmk's Avatar
fudge313 (09-07-2018)
  #14
Old 09-07-2018, 07:14 AM
Currently: Not set.
Garage
DDECKER (09-10-2018), Shortcut (11-11-2018)
  #15
Old 09-07-2018, 08:05 AM
Currently: Not set.
  #16
Old 09-07-2018, 09:46 AM
CO 2.0's Avatar
CO 2.0 CO 2.0 is online now
Currently: Needs to snow
CO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond repute
  #17
Old 09-07-2018, 09:54 AM
goridedoo's Avatar
goridedoo goridedoo is online now
Currently: Not set.
goridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond repute
  #18
Old 09-07-2018, 11:24 AM
  #19
Old 09-07-2018, 11:33 AM
summ8rmk's Avatar
Anylizer (01-11-2019)
  #20
Old 09-07-2018, 11:50 AM
Chewy22's Avatar
Currently: Not set.
  #21
Old 09-07-2018, 07:16 PM
sno*jet sno*jet is online now
Currently: Not set.
sno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond repute
  #22
Old 09-08-2018, 12:40 PM
whittaker727's Avatar
whittaker727 whittaker727 is online now
Currently: waiting to ride my new build
whittaker727 has a reputation beyond reputewhittaker727 has a reputation beyond reputewhittaker727 has a reputation beyond reputewhittaker727 has a reputation beyond reputewhittaker727 has a reputation beyond reputewhittaker727 has a reputation beyond reputewhittaker727 has a reputation beyond reputewhittaker727 has a reputation beyond reputewhittaker727 has a reputation beyond reputewhittaker727 has a reputation beyond reputewhittaker727 has a reputation beyond repute
  #23
Old 09-09-2018, 12:39 AM
richardderkevorkian richardderkevorkian is online now
Currently: ...
richardderkevorkian has a reputation beyond reputerichardderkevorkian has a reputation beyond reputerichardderkevorkian has a reputation beyond reputerichardderkevorkian has a reputation beyond reputerichardderkevorkian has a reputation beyond reputerichardderkevorkian has a reputation beyond reputerichardderkevorkian has a reputation beyond reputerichardderkevorkian has a reputation beyond reputerichardderkevorkian has a reputation beyond reputerichardderkevorkian has a reputation beyond reputerichardderkevorkian has a reputation beyond repute
The Following User Says Thank You to richardderkevorkian For This Useful Post:
  #24
Old 09-09-2018, 07:57 PM
Currently: Not set.
  #25
Old 09-10-2018, 09:06 AM
madmax's Avatar
madmax madmax is online now
Currently: Not set.
madmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond repute
The Following User Says Thank You to madmax For This Useful Post:
Sunvang (09-10-2018)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Iceage PRO Motion Kit Black Anodized Thread Starter — Angermangement890 Forum — Suspension/Shocks (Swapmeet) Replies — 0 Last Post — 01-13-2015 06:58 AM
Thread — Brand new IceAge Ice Age 2 wheel kit Thread Starter — digdug Forum — Suspension/Shocks (Swapmeet) Replies — 3 Last Post — 09-23-2011 07:45 PM
Thread — Polaris - IceAge 2 wheel kit - new Thread Starter — AgentRmk Forum — Suspension/Shocks (Swapmeet) Replies — 1 Last Post — 11-28-2010 07:03 PM
Thread — ski/track kit for sport quads. Interesting. Thread Starter — Flakey Forum — General Snowmobiling Replies — 9 Last Post — 07-10-2008 07:38 PM
Thread — tested RKT torsional kit... interesting results. Thread Starter — MTm7 Forum — Arctic Cat Replies — 25 Last Post — 03-31-2008 08:27 AM
no new posts
