Upgrade to Premium
Reply
  #1
Old 09-04-2018, 05:36 AM
Jibblerson Jibblerson is offline
Currently: Not set.
Basic Member
Jibblerson is an unknown quantity at this point
Default Y pipe 800cc C-Tec2
Hello!
I´m thinking of changing out my Y pipe for an aftermarket one and have some questions.
Is it true that the stock Y pipe manifold is 2mm smaller than the outlet of the cylinder? if so does anyone knows why?
Is it true that you don´t need a power commander if you only change the Y pipe?
Does only changing the Y pipe makes a difference? I do understand that changing the whole exhaust system is going to make a lot more. I live in Sweden and during the last couple of years a lot of complains have been made due to the increase in sound level (for most part) an aftermarket exhaust makes. so I want the look and sound as close to stock as possible
Feel free to post your thoughts, pros and cons on different Y pipe brands and so on
Rate this post: Yes | No
  #2
Old 09-05-2018, 08:49 PM
thump426er's Avatar
thump426er thump426er is offline
Currently: Not set.
thump426er has a reputation beyond reputethump426er has a reputation beyond reputethump426er has a reputation beyond reputethump426er has a reputation beyond reputethump426er has a reputation beyond reputethump426er has a reputation beyond reputethump426er has a reputation beyond reputethump426er has a reputation beyond reputethump426er has a reputation beyond reputethump426er has a reputation beyond reputethump426er has a reputation beyond repute
Default
I’m quite curious about this as well for my new sled purchase.
__________________
"short, fat, and stupid is no way to go through life son..."
  #3
Old 09-05-2018, 11:00 PM
Pol72 Pol72 is offline
Currently: 2018 Mountain Cat 162
Pol72 has a reputation beyond reputePol72 has a reputation beyond reputePol72 has a reputation beyond reputePol72 has a reputation beyond reputePol72 has a reputation beyond reputePol72 has a reputation beyond reputePol72 has a reputation beyond reputePol72 has a reputation beyond reputePol72 has a reputation beyond reputePol72 has a reputation beyond reputePol72 has a reputation beyond repute
Default
I spoke with Eric from Speed Shop Inc on the phone yesterday. He said they had great results with the Y pipe. 5-7hp overall with 9hp in the midrange with just bolting it on. No fuel controller needed. The stock mapping will adjust for this and Reeds if you wanted to add those also. Bang for your buck that is very cheap HP on a bolt on and ride item. I believe there is a dyno video of this ypipe I found on YouTube also showing these results on a live dyno run. I am ordering ypipe and boysen reeds for my sled. Just thought I would pass on the info I received on my call.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following 3 Users Say Thank You to Pol72 For This Useful Post:
Jibblerson (10-17-2018), kanedog (09-19-2018), thump426er (09-06-2018)
  #4
Old 09-06-2018, 09:46 AM
sno*jet sno*jet is offline
Currently: Not set.
sno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond repute
Default
not sure on the ctech, but on the zuke model the tubes are a little fatter than stock whereas the stock y is matched to the port size, not smaller. I believe that adds the better low-mid snap but am skeptical on what that does to top end. welds are not so smooth on these unless things have changed, spend a little time inside it with your Dremel. thread lock your manifold bolts and keep an eye on them, I lost half of mine in 500 miles.
The Following User Says Thank You to sno*jet For This Useful Post:
  #5
Old 09-06-2018, 08:27 PM
SledGuru's Avatar
SledGuru SledGuru is offline
Currently: watching sled porn becoming a better rider
SledGuru has a reputation beyond reputeSledGuru has a reputation beyond reputeSledGuru has a reputation beyond reputeSledGuru has a reputation beyond reputeSledGuru has a reputation beyond reputeSledGuru has a reputation beyond reputeSledGuru has a reputation beyond reputeSledGuru has a reputation beyond reputeSledGuru has a reputation beyond reputeSledGuru has a reputation beyond reputeSledGuru has a reputation beyond repute
Default
I know speedwerx claims no significant gain and will not sell separate. Hard to believe just y pipe makes that much hp.
Hoss
__________________
HOSS 307
  #6
Old 09-06-2018, 11:12 PM
Default
https://youtu.be/Kf1jSzVyAvw
Sorry that was a BMP YouTube video with the same claimed gain numbers. Hopefully this link works
  #7
Old 09-08-2018, 09:00 AM
JMCX's Avatar
JMCX JMCX is offline
Currently: somewhere
JMCX has a reputation beyond reputeJMCX has a reputation beyond reputeJMCX has a reputation beyond reputeJMCX has a reputation beyond reputeJMCX has a reputation beyond reputeJMCX has a reputation beyond reputeJMCX has a reputation beyond reputeJMCX has a reputation beyond reputeJMCX has a reputation beyond reputeJMCX has a reputation beyond reputeJMCX has a reputation beyond repute
Default
Can't find the Y pipe on BMP website.
  #8
Old 09-09-2018, 06:08 AM
Old & slow Old & slow is offline
Currently: Not set.
Old & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond repute
Default
Quote:
Hoss
The Speedwerx y may not gain as much don't know, but I do know guys that have added SSI bolt on parts and have see decent gains.
  #9
Old 09-14-2018, 03:18 PM
BD-Xtreme's Avatar
BD-Xtreme BD-Xtreme is offline
Currently: Not set.
BD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond repute
Default SSI Y pipe ctec 8000
Quote:
Originally Posted by Jibblerson View Post
Hello!
Yes, the stock manifold is 48mm i.d. and the stock outlet on the cylinder is 50mm.
I don't know what other companies results are or aren't, but we picked up a pile of power in the mid range 8-9, and a solid 4-5 lb/ft of torque. And 5 more peak hp. We recommend adding more weight to the clutch with our Y pipe to harness the extra power.
__________________
http://www.bd-xtreme.com
www.BD-XREME.com
http://www.speedshopinc.com
www.SPEEDSHOPINC.com
The Following 2 Users Say Thank You to BD-Xtreme For This Useful Post:
Jibblerson (10-17-2018), Old & slow (09-15-2018)
  #10
Old 09-19-2018, 08:14 PM
Fish10782 Fish10782 is online now
Currently: Trolling P-Hub
Basic Member
Fish10782 has a reputation beyond reputeFish10782 has a reputation beyond reputeFish10782 has a reputation beyond reputeFish10782 has a reputation beyond reputeFish10782 has a reputation beyond reputeFish10782 has a reputation beyond reputeFish10782 has a reputation beyond reputeFish10782 has a reputation beyond reputeFish10782 has a reputation beyond reputeFish10782 has a reputation beyond reputeFish10782 has a reputation beyond repute
Default
Is there a dyno video of this?
Hot engine doing long pulls ect? I'd like the pulls to be like dynoport's pulls showing the "claimed" hp on the skidoo 850s
The video is on YouTube.
The Following User Says Thank You to Fish10782 For This Useful Post:
  #11
Old 09-21-2018, 12:05 PM
BD-Xtreme's Avatar
Currently: Not set.
Click Here to Register
The Following User Says Thank You to BD-Xtreme For This Useful Post:
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — C-tec2 oil? Thread Starter — summ8rmk Forum — 2018 Ascender Replies — 20 Last Post — 01-04-2018 08:36 PM
Thread — WTB SLP single pipe for 09 800cc Dragon Thread Starter — dude Forum — Pipes/Cans (Swapmeet) Replies — 0 Last Post — 10-16-2010 09:49 PM
Thread — FOR SALE, 2009 800cc DRAGON STOCK PIPE. 0 MILES ON PIPE. Thread Starter — dude Forum — Pipes/Cans (Swapmeet) Replies — 0 Last Post — 10-16-2010 09:33 PM
Thread — NEW! Arctic Cat 2010 800cc Adjustable Single Pipe from SW...who knows anything? Thread Starter — blackcloud2k Forum — Arctic Cat: M Series Replies — 8 Last Post — 09-04-2009 07:48 AM
Thread — D&D pipe and can set 07,08,09 800cc Crossfire or M8 Thread Starter — volonau Forum — Pipes/Cans (Swapmeet) Replies — 0 Last Post — 01-14-2009 08:21 PM
no new posts
