Upgrade to Premium
Reply
  #1
Old 09-02-2018, 04:06 PM
Lwood Lwood is offline
Currently: Not set.
Basic Member
Lwood has a reputation beyond reputeLwood has a reputation beyond reputeLwood has a reputation beyond reputeLwood has a reputation beyond reputeLwood has a reputation beyond reputeLwood has a reputation beyond reputeLwood has a reputation beyond reputeLwood has a reputation beyond reputeLwood has a reputation beyond reputeLwood has a reputation beyond reputeLwood has a reputation beyond repute
Default AER 48 for snowbike?
Has anyone run the AER yet?
Rate this post: Yes | No
  #2
Old 09-02-2018, 06:25 PM
byeatts byeatts is online now
Currently: Not set.
byeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond repute
Default
Quote:
all the 17 seals will fail. All the 18 were rock solid no failures, they have different seals
The Following User Says Thank You to byeatts For This Useful Post:
Lwood (09-02-2018)
  #3
Old 09-02-2018, 06:54 PM
KTM_FREERIDER KTM_FREERIDER is online now
Currently: Not set.
Basic Member
KTM_FREERIDER has a reputation beyond reputeKTM_FREERIDER has a reputation beyond reputeKTM_FREERIDER has a reputation beyond reputeKTM_FREERIDER has a reputation beyond reputeKTM_FREERIDER has a reputation beyond reputeKTM_FREERIDER has a reputation beyond reputeKTM_FREERIDER has a reputation beyond reputeKTM_FREERIDER has a reputation beyond reputeKTM_FREERIDER has a reputation beyond reputeKTM_FREERIDER has a reputation beyond reputeKTM_FREERIDER has a reputation beyond repute
Default
Quote:
I just bought a 2018 KTM 450 and the dealer that I bought my Timbersled from said that I will need the Trio shock due to all the failures. I am not questioning your statement, just want to make sure I don’t need a $900 shock.
  #4
Old 09-02-2018, 08:17 PM
Currently: Not set.
Basic Member
Default
I have a new, left over 17. Are the seals interchangeable with the 18's? I have a Trio as well. I was planning on taking the 4CS off my 16' 450 and swapping around with the AER to the 17'. Little longer but that is no big deal to figure out. The 4CS is modified and valved up to my specs, so I hate to use it on a snowbike where that does not matter.
Do the seals fail because the pressure is pumped way up on the 17' AER for snowbike duty?
  #5
Old 09-02-2018, 08:52 PM
Sheetmetalfab's Avatar
Sheetmetalfab Sheetmetalfab is online now
Currently: Riding the R6 TS LT and building the ZX6R 636
Sheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond repute
Default
Seals fail due to the cold. (They roll up)
Use the 4cs and trio.
Aer work really well on dirt.
__________________
Try again
The Following User Says Thank You to Sheetmetalfab For This Useful Post:
Lwood (09-02-2018)
  #6
Old 09-04-2018, 02:32 PM
Currently: Not set.
Default
Quote:
I build snow bikes , Not one failure on the 18,s, All the 17,s failed, I run 200psi
The Following 3 Users Say Thank You to byeatts For This Useful Post:
Grape Taxi (01-14-2019), KTM_FREERIDER (09-04-2018), Lwood (09-04-2018)
  #7
Old 09-05-2018, 05:41 PM
Jaynelson Jaynelson is online now
Currently: Not set.
Jaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond repute
Default
As said - we had issues with the 2017 AER, nothing on 2018 so far.
**That said if you have a bike with AER forks and don't want them for winter use, I'm SURE you can find someone with a 4CS or Xplor who would swap you no problem. The AER is awesome for summer use.
  #8
Old 09-05-2018, 07:12 PM
boondocker97 boondocker97 is online now
Currently: working for the man
boondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond repute
Default
If your '16 4CS is setup for dirt I wouldn't bother swapping it as the snowbike setups are much firmer. I'd run the AER with upgraded seals and you can at least bump up the air pressure. '18 seals fit the '17 forks. I do like my AER on dirt too.
__________________
Current Sleds:
2014-2018ish BDX Pro-Lite 900, 2005 M7 with upgrades - Ol' Reliable, 1974 Cheetah
Still in the Family:
2009 M1300, 2001 Mountain Cat 800 LE, 1972 Kitty Cat
Gone but not Forgotten:
1999 Powder Special 600 LE, 1998 Powder Special 600, 1993 EXT 550, 1980 JAG 340
The Following User Says Thank You to boondocker97 For This Useful Post:
Lwood (09-08-2018)
  #9
Old 09-06-2018, 10:33 AM
Currently: Not set.
Default
Quote:
yes Spring forks add noticeable front end weight on a snow bike. The AER really work, just assure 18 seals.
Lwood (09-08-2018)
  #10
Old 09-07-2018, 07:48 AM
MountainRider05 MountainRider05 is offline
Currently: Not set.
MountainRider05 has a reputation beyond reputeMountainRider05 has a reputation beyond reputeMountainRider05 has a reputation beyond reputeMountainRider05 has a reputation beyond reputeMountainRider05 has a reputation beyond reputeMountainRider05 has a reputation beyond reputeMountainRider05 has a reputation beyond reputeMountainRider05 has a reputation beyond reputeMountainRider05 has a reputation beyond reputeMountainRider05 has a reputation beyond reputeMountainRider05 has a reputation beyond repute
The Following User Says Thank You to MountainRider05 For This Useful Post:
Lwood (09-08-2018)
  #11
Old 09-07-2018, 11:04 PM
cbc76am's Avatar
cbc76am cbc76am is offline
Currently: Cascade Mtns
cbc76am has a reputation beyond reputecbc76am has a reputation beyond reputecbc76am has a reputation beyond reputecbc76am has a reputation beyond reputecbc76am has a reputation beyond reputecbc76am has a reputation beyond reputecbc76am has a reputation beyond reputecbc76am has a reputation beyond reputecbc76am has a reputation beyond reputecbc76am has a reputation beyond reputecbc76am has a reputation beyond repute
Garage
Click Here to Register
The Following User Says Thank You to cbc76am For This Useful Post:
Lwood (09-08-2018)
  #12
Old 09-07-2018, 11:06 PM
cbc76am's Avatar
Garage
Lwood (09-08-2018)
  #13
Old 01-01-2019, 05:04 PM
yooper 8 yooper 8 is offline
Currently: waiting to head west!
yooper 8 has a reputation beyond reputeyooper 8 has a reputation beyond reputeyooper 8 has a reputation beyond reputeyooper 8 has a reputation beyond reputeyooper 8 has a reputation beyond reputeyooper 8 has a reputation beyond reputeyooper 8 has a reputation beyond reputeyooper 8 has a reputation beyond reputeyooper 8 has a reputation beyond reputeyooper 8 has a reputation beyond reputeyooper 8 has a reputation beyond repute
  #14
Old 01-13-2019, 10:35 AM
tahoesldr tahoesldr is offline
Currently: Not set.
Basic Member
tahoesldr has a reputation beyond reputetahoesldr has a reputation beyond reputetahoesldr has a reputation beyond reputetahoesldr has a reputation beyond reputetahoesldr has a reputation beyond reputetahoesldr has a reputation beyond reputetahoesldr has a reputation beyond reputetahoesldr has a reputation beyond reputetahoesldr has a reputation beyond reputetahoesldr has a reputation beyond reputetahoesldr has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2018 KTM AER 48-Updated Parts? Thread Starter — TillTheEnd Forum — Snow bikes Replies — 15 Last Post — 09-24-2017 01:58 AM
Thread — WP AER 48 fork update Thread Starter — BendBrapp Forum — Snow bikes Replies — 2 Last Post — 01-29-2017 07:18 PM
Thread — has anyony tried the AER spring kit? Thread Starter — byeatts Forum — Snow bikes Replies — 20 Last Post — 01-22-2017 07:55 AM
Thread — 2017 KTM & Husky, WP-AER 48 fork settings. Thread Starter — Mawgly Forum — Snow bikes Replies — 8 Last Post — 12-07-2016 10:41 PM
Thread — 2017 KTM & Husky, WP-USD, AER 48 fork settings. Thread Starter — Mawgly Forum — Snowbikes & Parts (Swapmeet) Replies — 0 Last Post — 12-06-2016 02:46 PM
no new posts
