Upgrade to Premium
Arctic Cat: Proclimb M 2012 and beyond
Reply
  #1
Old 08-29-2018, 04:21 PM
GlennRMK GlennRMK is offline
Currently: Riding every chance I get
Basic Member
GlennRMK has a reputation beyond reputeGlennRMK has a reputation beyond reputeGlennRMK has a reputation beyond reputeGlennRMK has a reputation beyond reputeGlennRMK has a reputation beyond reputeGlennRMK has a reputation beyond reputeGlennRMK has a reputation beyond reputeGlennRMK has a reputation beyond reputeGlennRMK has a reputation beyond reputeGlennRMK has a reputation beyond reputeGlennRMK has a reputation beyond repute
Default Steel Lower Gear for 2016 M8?
I have a 16 M8 and I am planning on changing the oil in the chaincase.
I have read the aluminum sprockets wear out quickly.
Is there a steel lower sprocket you can use on the 16?
I believe in 16 they changed to a Hyvo chain and sprockets, so you can't use the steel sprocket for the 12-15s
Does Arctic Cat make it? Part #? Is the 3602-024 18 mountain cat lightweight sprocket steel?
I see TEAM makes a HYVO kit and here is just the sprocket: Can you use this with the Arctic Cat chain and top sprocket?
https://venomproducts.com/index.php/...ket-930176-013
Or do you have to get the kit?
https://venomproducts.com/index.php/...50-2014-520906
Thanks!
Rate this post: Yes | No
  #2
Old 08-29-2018, 06:21 PM
summ8rmk's Avatar
summ8rmk summ8rmk is online now
Currently: Snow angels in dog parks
summ8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond repute
Default
I wouldn't worry about the life expectancy of the aluminum sprocket.
Yes it wears as it breaks in but then it is matched to the chain and ur good.
I personally have not seen or heard of an actual sprocket failure.
Tensioner failures, yes.
They have been out since 2014.
  #3
Old 08-29-2018, 08:38 PM
mk2g60's Avatar
mk2g60 mk2g60 is offline
Currently: Not set.
mk2g60 has a reputation beyond reputemk2g60 has a reputation beyond reputemk2g60 has a reputation beyond reputemk2g60 has a reputation beyond reputemk2g60 has a reputation beyond reputemk2g60 has a reputation beyond reputemk2g60 has a reputation beyond reputemk2g60 has a reputation beyond reputemk2g60 has a reputation beyond reputemk2g60 has a reputation beyond reputemk2g60 has a reputation beyond repute
Default
Thanks!
Yes cat has BW steel gears, first thing i swap out on my sleds. What size do you want? I can look up a pn for you tomorrow.
  #4
Old 08-29-2018, 08:56 PM
runner runner is offline
Currently: Not set.
runner has a reputation beyond reputerunner has a reputation beyond reputerunner has a reputation beyond reputerunner has a reputation beyond reputerunner has a reputation beyond reputerunner has a reputation beyond reputerunner has a reputation beyond reputerunner has a reputation beyond reputerunner has a reputation beyond reputerunner has a reputation beyond reputerunner has a reputation beyond repute
Default
Here is Cats part #'s
https://www.speedwerxstore.com/index..._detail&p=3608
https://www.speedwerxstore.com/index..._detail&p=3610
  #5
Old 08-30-2018, 06:18 AM
Basic Member
Default
So looks like 2602-746 is a 50T
Is that steel?
  #6
Old 08-30-2018, 09:55 AM
sno*jet sno*jet is online now
Currently: Not set.
sno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond repute
Default
belt drive time
  #7
Old 08-31-2018, 09:03 PM
mk2g60's Avatar
Currently: Not set.
Default
Is that steel?
Yes, but those prices through SW are pretty spendy. I usually pay around $50 for them.
  #8
Old 09-04-2018, 10:04 AM
Basic Member
Default
Thanks guys
Have the aluminum sprockets been better with the Hyvo setup vs the old 13W?
  #9
Old 09-27-2018, 12:17 PM
kidwoo's Avatar
kidwoo kidwoo is online now
Currently: schmurrently
kidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond repute
Default
I've kind of changed my thinking on this. There's got to be a reason cat used aluminum. Yeah rotational weight and all that but it's got to help take some of the wear away from the chain right? Double steel gears just seem like it would put more long term stress on the links.
__________________
www.sierrasnowmobilefoundation.com
Your loud can sounds stupid
  #10
Old 09-27-2018, 01:18 PM
boondocker97 boondocker97 is offline
Currently: working for the man
boondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond repute
  #11
Old 09-27-2018, 04:15 PM
kidwoo's Avatar
Click Here to Register
  #12
Old 09-27-2018, 06:10 PM
jim jim is online now
Currently: Keyboard highmarking at its best.
jim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond repute
The Following User Says Thank You to jim For This Useful Post:
Bills R.E. Repair (09-30-2018)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Anyone have a steel 50t gear they don't want? Thread Starter — kidwoo Forum — Arctic Cat: Proclimb M Replies — 5 Last Post — 02-03-2017 07:59 PM
Thread — New Arctic Cat Steel 50 tooth Gear (sprocket) Thread Starter — Mntryder Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 4 Last Post — 12-07-2016 10:55 AM
Thread — Steel Replacement Gears for the Plastic Idler Gear Thread Starter — M5- Forum — Snow bikes Replies — 7 Last Post — 03-11-2016 08:10 PM
Thread — Crappy lower gear in 2016 Thread Starter — Bacon Forum — Arctic Cat: Proclimb M Replies — 5 Last Post — 12-28-2015 02:28 AM
Thread — Part # 47 tooth gear-steel Thread Starter — Maxwe Forum — Ski-Doo Replies — 0 Last Post — 01-16-2008 07:02 PM
no new posts
