Upgrade to Premium
Polaris: AXYS 2016 AXYS chassis
Reply
  #1
Old 08-29-2018, 04:01 AM
RanOutofTalent RanOutofTalent is offline
Currently: Wondering what your can sounds like
RanOutofTalent has a reputation beyond reputeRanOutofTalent has a reputation beyond reputeRanOutofTalent has a reputation beyond reputeRanOutofTalent has a reputation beyond reputeRanOutofTalent has a reputation beyond reputeRanOutofTalent has a reputation beyond reputeRanOutofTalent has a reputation beyond reputeRanOutofTalent has a reputation beyond reputeRanOutofTalent has a reputation beyond reputeRanOutofTalent has a reputation beyond reputeRanOutofTalent has a reputation beyond repute
Default 1600 mile maintenance?
2017 800 Pro 163
Wondering what I should be doing for maintenance on my sled at 1600 miles. I ride a lot and will probably put on another 100 hours and 1000 plus miles this season. I do the general stuff such as greasing everything. Clutching adjustments, new hyfaxes, and shock adjustments.
Put on a new pull cord, stock one had some minor frays.
What else should I be doing to properly prepare my sled? I was thinking motor mounts? The dealership has the sled the end of the season and said the compression was great.
Then the end of this season a MTN TK durability kit as I will be getting a new sled and using this one as a spare/loaner.
Thanks
__________________
2017 Axys 163 2.6
Rate this post: Yes | No
  #2
Old 08-29-2018, 06:13 AM
damx damx is online now
Currently: Not set.
damx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond repute
Default
Engine sounds fine! I would do engine mounts and have the clutch rebuilt. We have lots of axys engines near 3000 miles. I seams the reeds or injectors will go before the engine, that's what we are seeing anyways.
The Following 2 Users Say Thank You to damx For This Useful Post:
RanOutofTalent (08-29-2018), Sage Crusher (08-29-2018)
  #3
Old 08-29-2018, 06:17 AM
Default
Quote:
I recall there being a thread on the engine mounts a while back. Do you know if they are a dealership part or are people using something aftermarket?
Thanks
__________________
2017 Axys 163 2.6
  #4
Old 08-29-2018, 07:09 AM
Currently: Not set.
Default
Just stock replacement
The Following User Says Thank You to damx For This Useful Post:
  #5
Old 08-29-2018, 08:58 AM
ullose272 ullose272 is offline
Currently: workin for the weekend
ullose272 has a reputation beyond reputeullose272 has a reputation beyond reputeullose272 has a reputation beyond reputeullose272 has a reputation beyond reputeullose272 has a reputation beyond reputeullose272 has a reputation beyond reputeullose272 has a reputation beyond reputeullose272 has a reputation beyond reputeullose272 has a reputation beyond reputeullose272 has a reputation beyond reputeullose272 has a reputation beyond repute
Default
3023290 i believe is the mount inserts you want. Those are the ones i just ordered anyway
Sent from my SM-G930V using Tapatalk
The Following User Says Thank You to ullose272 For This Useful Post:
RanOutofTalent (09-02-2018)
  #6
Old 08-29-2018, 09:56 AM
Wheel House Motorsports's Avatar
Wheel House Motorsports Wheel House Motorsports is online now
Currently: is it winter yet?
Wheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond repute
Default
Get motor mounts out of an 18 and take your primary off and send to indy dan for balance/rebuild plus throw fresh spring in secondary. This should keep it ripping like new.
Check brake pads, i only get 800 miles to a set but i ride them hard. you will probably be fairly worn and will not make it through the season on your stock ones.
Also inspect jackshaft where it slides through the bearing by the belt drive pulley. I've seen numerous ones wear the shaft out there. Easy to pull out and inspect.
__________________
Wheelhousemotorsports@gmail.com
406-871-0955 Bozeman, MT
The Following User Says Thank You to Wheel House Motorsports For This Useful Post:
  #7
Old 08-30-2018, 10:02 PM
Sage Crusher's Avatar
Sage Crusher Sage Crusher is online now
Currently: easing into Winter......
Sage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond repute
Default
2K on my 16 Axys-
Already replaced jack and drive shaft bearings- just cause I had the track and drive out over the summer getting suspension re-valved .
Suspension........ instead of just greasing it- I pull it completely out and apart and clean the shafts that have no zerks-and re assemble all with
Red Line CV-2 Extreme Pressure Grease.
__________________
Dealers for:
Silber Turbos.
GGB Exhaust.
TKI.
F-N-I.
K-Mod.
2016 Axys LTD 163 W/Silber Turbo/K-Mod Gen III/TKI
  #8
Old 09-02-2018, 03:22 AM
prorideupper800 prorideupper800 is offline
Currently: waiting for the Big Snow maker to give us some Powder inthebackcountry of theUPehh
prorideupper800 has a reputation beyond reputeprorideupper800 has a reputation beyond reputeprorideupper800 has a reputation beyond reputeprorideupper800 has a reputation beyond reputeprorideupper800 has a reputation beyond reputeprorideupper800 has a reputation beyond reputeprorideupper800 has a reputation beyond reputeprorideupper800 has a reputation beyond reputeprorideupper800 has a reputation beyond reputeprorideupper800 has a reputation beyond reputeprorideupper800 has a reputation beyond repute
Garage
Default
I would install 911 billet clutch cover put one on my 16 SKS and have 8400 miles on it with No problems no rebuilds and it still spins 8250 all day long ( I did replace primary spring at 3500) going to replace pistons this fall though just as a precaution.
  #9
Old 09-02-2018, 01:36 PM
Big10inch Big10inch is offline
Currently: Not set.
Basic Member
Big10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond repute
Default
Mountain ridden sleds don't last 8400 miles LOL. Primary clutch springs will never go 3500 miles out west. My Axys motor lasted 1100 miles, it was on its second primary clutch, motor mounts were shot, exhaust valve cable broke. The failure points for mtn sleds are pretty well documented here. At 1600 mountain miles on an Axys, I needed a whole new sled... YMMV
  #10
Old 09-02-2018, 05:18 PM
Indy_500's Avatar
Indy_500 Indy_500 is offline
Currently: Going Left!
Indy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond repute
Garage
Default
Quote:
X2 i have ~1400 miles and mines in rough shape. Reallyyy need a new one but i just keep dumping thousands into it...
__________________
2016 Polaris Pro RMK 800 LE 155" x 2.6"
~Raptor Shocks, 37" Raptor Front End, Zollinger Billet Spindles, HPS Can, and then some
  #11
Old 09-02-2018, 07:04 PM
Click Here to Register
The Following 3 Users Say Thank You to Sage Crusher For This Useful Post:
RanOutofTalent (09-04-2018), Sheetmetalfab (09-02-2018), summ8rmk (09-02-2018)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 200 mile maintenance. Thread Starter — norsepeak Forum — Ski-Doo: REV Gen 4 Replies — 6 Last Post — 12-27-2016 07:11 PM
Thread — My 4K mile maintenance job Thread Starter — 94fordguy Forum — Polaris: 900 Replies — 25 Last Post — 03-21-2013 10:11 PM
Thread — '02 Polaris XC 120 $1600 Thread Starter — Cor146 Forum — Polaris (Swapmeet) Replies — 1 Last Post — 12-05-2012 09:27 PM
Thread — Sled Maintenance. What maintenance needs to be performed and how often? Thread Starter — Schwartz Forum — Polaris Replies — 9 Last Post — 03-17-2009 08:42 AM
Thread — New 08 M 162 skid 1600.00 Thread Starter — mmsports Forum — Suspension/Shocks (Swapmeet) Replies — 0 Last Post — 04-24-2008 11:09 AM
