NEW BDX ALUMINUM TRACKSHAFTS -3LBS
BD-Xtreme
267
Our new Aluminum Trackshaft is 3 lbs lighter than the stock one! It is a direct replacement for the stock shaft.
Add our Super Lite Brake Rotor and drop 1.5-2.5 more lbs!! 5.5 lbs of total rotating weight loss!!
Fits 2012-2019 Arctic Cat models, both standard and reverse style gearcases. The reverse model has a wider spline on the chaincase side.
Fits Yamaha Sidewinder and Viper Models 2014+
Our BDX shaft is 20% stronger than Arctic Cat's stock M8000 trackshaft. You can see in our cross section that ours has 5 support webs instead of 4 like the oem version. No extra nuts or spacers are needed to use our shaft either, like the oem M8000 shaft.
Our BDX shafts is hardcoat anodized, so it even looks like a stock steel shaft.
Our shafts are also available with several different driver options. Drivers are installed and trued up for perfection
3.0 Pitch Extrovert 8 tooth (mountain tracks), 2.86 Pitch Extrovert 9 tooth (stock trail tracks)
2.52 Pitch 10 tooth, 2.52 Pitch 9 tooth. (Racing and Trail)
(not a direct replacement for 2018-2019 M8000 models)
