Upgrade to Premium
Reply
  #1
Old 08-22-2018, 09:03 PM
mtnthumper mtnthumper is offline
Currently: Not set.
Basic Member
mtnthumper has a reputation beyond reputemtnthumper has a reputation beyond reputemtnthumper has a reputation beyond reputemtnthumper has a reputation beyond reputemtnthumper has a reputation beyond reputemtnthumper has a reputation beyond reputemtnthumper has a reputation beyond reputemtnthumper has a reputation beyond reputemtnthumper has a reputation beyond reputemtnthumper has a reputation beyond reputemtnthumper has a reputation beyond repute
Default Anyone use a battery warmer?
I bought a couple adhesive pad block heaters I'm going to hook up to the bike. One will be on the block and the other I'll insulate and put under the battery. The plan is to be able to plug the bike in an hour or so before heading to the trailhead.
Anyone try something like this with any luck?
Rate this post: Yes | No
  #2
Old 08-30-2018, 12:04 PM
GeraldG GeraldG is offline
Currently: Not set.
Basic Member
GeraldG is an unknown quantity at this point
Default
I use disposable hand/ foot warmers.
The Following 2 Users Say Thank You to GeraldG For This Useful Post:
mtnthumper (08-31-2018), turbonium (08-30-2018)
  #3
Old 08-31-2018, 05:00 PM
Currently: Not set.
Basic Member
Default
Did you use those when out on the mountain or just for the first start of the day?
I tested the block heater a little and it just seems too hot for a battery. Im going to find something with less heat.
  #4
Old 08-31-2018, 07:32 PM
Sheetmetalfab's Avatar
Sheetmetalfab Sheetmetalfab is online now
Currently: Riding the R6 TS LT and building the ZX6R 636
Sheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond repute
Default
Look for a “battery blanket”.
They are used up in the oilfields quite a bit.
__________________
Try again
  #5
Old 09-01-2018, 12:30 PM
Dartos's Avatar
Dartos Dartos is offline
Currently: Waiting
Dartos has a reputation beyond reputeDartos has a reputation beyond reputeDartos has a reputation beyond reputeDartos has a reputation beyond reputeDartos has a reputation beyond reputeDartos has a reputation beyond reputeDartos has a reputation beyond reputeDartos has a reputation beyond reputeDartos has a reputation beyond reputeDartos has a reputation beyond reputeDartos has a reputation beyond repute
Default
I found this on Amazon.
25 watt 1” X 5” heater that may be just right.
https://www.amazon.com/Kats-24025-Watt-Universal-Heater
__________________
Just so you know, there is no such thing as RPM's - it's just RPM.
The Following 2 Users Say Thank You to Dartos For This Useful Post:
mtnthumper (09-02-2018), Sheetmetalfab (09-01-2018)
  #6
Old 09-01-2018, 05:06 PM
Coldfinger's Avatar
Coldfinger Coldfinger is online now
Currently: Not set.
Coldfinger has a reputation beyond reputeColdfinger has a reputation beyond reputeColdfinger has a reputation beyond reputeColdfinger has a reputation beyond reputeColdfinger has a reputation beyond reputeColdfinger has a reputation beyond reputeColdfinger has a reputation beyond reputeColdfinger has a reputation beyond reputeColdfinger has a reputation beyond reputeColdfinger has a reputation beyond reputeColdfinger has a reputation beyond repute
Default
Iwas wondering if those coolant heaters would work.
https://images.oreillyauto.com/parts.../kat/13100.jpg
  #7
Old 09-02-2018, 01:29 PM
Currently: Not set.
Basic Member
Default
That 25 watt seems like it would work good. It shouldn't need to warm it up very much. If I can just get it to 50 degrees or so I bet it'll crank over pretty well.
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #8
Old 09-03-2018, 08:06 AM
mrsnow mrsnow is offline
Currently: Highwood MT age 64
mrsnow has a reputation beyond reputemrsnow has a reputation beyond reputemrsnow has a reputation beyond reputemrsnow has a reputation beyond reputemrsnow has a reputation beyond reputemrsnow has a reputation beyond reputemrsnow has a reputation beyond reputemrsnow has a reputation beyond reputemrsnow has a reputation beyond reputemrsnow has a reputation beyond reputemrsnow has a reputation beyond repute
Default
Even a blow dryer works used it on my snowmobiles
  #9
Old 09-08-2018, 10:27 PM
BendBrapp BendBrapp is offline
Currently: Itching for powder
BendBrapp has a reputation beyond reputeBendBrapp has a reputation beyond reputeBendBrapp has a reputation beyond reputeBendBrapp has a reputation beyond reputeBendBrapp has a reputation beyond reputeBendBrapp has a reputation beyond reputeBendBrapp has a reputation beyond reputeBendBrapp has a reputation beyond reputeBendBrapp has a reputation beyond reputeBendBrapp has a reputation beyond reputeBendBrapp has a reputation beyond repute
Default
I run my battery tender and and a transmission pan heater while transporting my bike in the bed of my truck.
The heating pad is adhesive backed and I used copper gasket silicone to help stick it to the bottom of the engine case. I covered the area with some dense cell foam and it’s covered up by my skid plate. With an engine blanket and a cover on my bike, my bike is 30+ degrees warmer when arriving at the trailhead. The battery is topped off and the bike cranks easy as the oil is a reasonable temp.
The Following 2 Users Say Thank You to BendBrapp For This Useful Post:
mtnthumper (09-09-2018), Sheetmetalfab (09-09-2018)
  #10
Old 09-09-2018, 09:38 AM
Currently: Not set.
Basic Member
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 14 M8000 hand warmer-thumb warmer switch issue Thread Starter — Sledbrain2 Forum — Arctic Cat: Proclimb M Replies — 5 Last Post — 02-07-2018 08:10 PM
Thread — Is there a Warmer Thumb Warmer? Thread Starter — Frostbite Forum — Arctic Cat: Proclimb M Replies — 16 Last Post — 01-07-2016 07:36 PM
Thread — Wiring in a battery on battery-less FI bikes Thread Starter — 4bangrboost Forum — Snow bikes Replies — 1 Last Post — 01-07-2015 05:25 PM
Thread — Putting a hand warmer ON your battery? Thread Starter — the gman Forum — Snow bikes Replies — 19 Last Post — 11-03-2013 09:46 PM
Thread — Swapping battery from 06 Rmk to a 05 Rmk With out battery? Thread Starter — Hjalti_GTO Forum — Polaris: 900 Replies — 3 Last Post — 01-26-2012 12:08 AM
no new posts
