Upgrade to Premium
Reply
  #1
Old 08-19-2018, 11:34 AM
needpowder's Avatar
needpowder needpowder is offline
Currently: dreaming of global cooling
needpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond reputeneedpowder has a reputation beyond repute
Default Timbersled bearing removal
16 timbersled. So I have all the bearings removed from the bike as well as the drive axle (The one with the drivers on it). My question is, the double bearing housing that is on the driveshaft, is that just pressed on? I just press it off right? Thanks. By the way, what a pain to remove these bearings, especially the single bearing housing by the brake.
Edit. Just pressed it off the axle. No problem. Pressed out all the other bearings as well. Just waiting for new bearings to show up now.
__________________
2016 YZ450fx w/16 TS LT
Rate this post: Yes | No
  #2
Old 08-19-2018, 06:39 PM
Sheetmetalfab's Avatar
Sheetmetalfab Sheetmetalfab is online now
Currently: Riding the R6 TS LT and building the ZX6R 636
Sheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond repute
Default
Yep.
Redneck trainwreck. (I should know I have 3) 😂
__________________
Try again
  #3
Old 08-19-2018, 07:47 PM
dooman92 dooman92 is online now
Currently: Not set.
dooman92 has a reputation beyond reputedooman92 has a reputation beyond reputedooman92 has a reputation beyond reputedooman92 has a reputation beyond reputedooman92 has a reputation beyond reputedooman92 has a reputation beyond reputedooman92 has a reputation beyond reputedooman92 has a reputation beyond reputedooman92 has a reputation beyond reputedooman92 has a reputation beyond reputedooman92 has a reputation beyond repute
Default Bearings
What is the condition of the removed bearings? Any appear ready to fail?
  #4
Old 08-19-2018, 09:35 PM
needpowder's Avatar
Default
Quote:
They all looked fairly good actually. The inside diameter of one in particular was worn a bit though and caused some wear on the driveshaft that comes straight off the counter sprocket and has the brake on it. I will have to replace it, because even with a new bearing it wonít fit tight anymore. I will post pictures of it as soon as the snowwest lets me.
__________________
The Following User Says Thank You to needpowder For This Useful Post:
dooman92 (08-20-2018)
  #5
Old 08-19-2018, 10:52 PM
Default
Quote:
Flip the jackshaft 180degrees.
The bearing will be on a new surface.
Save your money.
__________________
Try again
  #6
Old 08-20-2018, 06:40 AM
needpowder's Avatar
Default
Save your money.
I’ll have to look at it again when I get home tonight but im pretty sure it can only go one way. It’s not the long drive shaft with the drivers on it. It’s the smaller shorter one with the brake on it. I think the way the brake fits is specific but I will have another look. Thanks.
Edit:OK, so I looked it up and it’s called the jackshaft not the driveshaft. Number 4 on this schematic.http://parts.polarisind.com/Assemblies.asp. Go to drivetrain, jackshaft and disc brake assembly
__________________
  #7
Old 08-20-2018, 08:54 AM
M5- M5- is offline
Currently: Planning a build
Basic Member
M5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond repute
Default
If its not too bad you may be able to use Loctite 680 on it to glue the new inner race to the shaft. I cant remember how big of a gap it'll fill off the top of my head but I have done it before. 680 is a bearing retainer compound, you just want to stop the inner race from spinning on the shaft.
M5
The Following User Says Thank You to M5- For This Useful Post:
needpowder (08-20-2018)
  #8
Old 08-20-2018, 09:20 AM
Default
Iíll have to look at it again when I get home tonight but im pretty sure it can only go one way. Itís not the long drive shaft with the drivers on it. Itís the smaller shorter one with the brake on it. I think the way the brake fits is specific but I will have another look. Thanks.
Edit:OK, so I looked it up and itís called the jackshaft not the driveshaft. Number 4 on this schematic.http://parts.polarisind.com/Assemblies.asp. Go to drivetrain, jackshaft and disc brake assembly
Yes itís called the jackshaft. (See my post above)
It will definitely work flipped. (My brother has done it on his 16)
__________________
Try again
  #9
Old 08-20-2018, 11:13 AM
needpowder's Avatar
Default
Nice! I will check it out tonight.
__________________
  #10
Old 08-26-2018, 09:28 AM
needpowder's Avatar
  #11
Old 08-26-2018, 03:51 PM
Click Here to Register
The Following User Says Thank You to Sheetmetalfab For This Useful Post:
needpowder (08-27-2018)
  #12
Old 08-26-2018, 04:12 PM
M5- M5- is offline
Basic Member
  #13
Old 08-27-2018, 10:10 AM
needpowder's Avatar
  #14
Old 08-27-2018, 10:26 AM
M5- M5- is offline
Basic Member
  #15
Old 08-27-2018, 02:28 PM
needpowder's Avatar
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Pto side driveshaft bearing removal? Thread Starter — garett87 Forum — Polaris: Pro-Ride Replies — 2 Last Post — 09-18-2013 04:19 PM
Thread — Lower control arm - SPHERICAL BEARING removal Thread Starter — Joemt Forum — Polaris: IQ Replies — 3 Last Post — 06-24-2013 12:44 AM
Thread — Driveshaft Bearing Removal?? Thread Starter — OutermostR1 Forum — Polaris: EDGE Replies — 3 Last Post — 12-18-2010 11:13 AM
Thread — brake bearing removal Thread Starter — sledtahoe Forum — Arctic Cat: M Series Replies — 1 Last Post — 12-06-2010 06:25 PM
Thread — Need Help w/ 07 DD bearing Removal Thread Starter — AKpow Forum — Arctic Cat: M Series Replies — 0 Last Post — 10-23-2009 09:54 PM
no new posts
