Upgrade to Premium
Arctic Cat: Proclimb M 2012 and beyond
Reply
  #1
Old 08-17-2018, 06:05 PM
Wheeeezy9 Wheeeezy9 is offline
Currently: Not set.
Basic Member
Wheeeezy9 has a reputation beyond reputeWheeeezy9 has a reputation beyond reputeWheeeezy9 has a reputation beyond reputeWheeeezy9 has a reputation beyond reputeWheeeezy9 has a reputation beyond reputeWheeeezy9 has a reputation beyond reputeWheeeezy9 has a reputation beyond reputeWheeeezy9 has a reputation beyond reputeWheeeezy9 has a reputation beyond reputeWheeeezy9 has a reputation beyond reputeWheeeezy9 has a reputation beyond repute
Default Track driver option?
I posted last winter about having impact with a rock hitting and denting my cooler.. ran it the rest of the season.. no issues ..this summer I was going thru it and checking stuff out and I found my track driver has damage.. so it looks like I need to fix it ..replace the driver (on pto side.) ? replace it with a stock 8 tooth or .. .. go 7 tooth? ..sled is a 2015 m8000153 2.6 powerclaw stock track, gearing with ssi low elevation clutch kit.... 7 tooth lowers gearing.. create more track clearance/better snow excavation? Pros cons ?
Rate this post: Yes | No
  #2
Old 08-17-2018, 06:20 PM
F7arcticcat's Avatar
F7arcticcat F7arcticcat is online now
Currently: Not set.
F7arcticcat has a reputation beyond reputeF7arcticcat has a reputation beyond reputeF7arcticcat has a reputation beyond reputeF7arcticcat has a reputation beyond reputeF7arcticcat has a reputation beyond reputeF7arcticcat has a reputation beyond reputeF7arcticcat has a reputation beyond reputeF7arcticcat has a reputation beyond reputeF7arcticcat has a reputation beyond reputeF7arcticcat has a reputation beyond reputeF7arcticcat has a reputation beyond repute
Default
You will lose performance with the 7...stay with the 8.
  #3
Old 08-17-2018, 06:25 PM
Currently: Not set.
Basic Member
Default
I have done some searches and wasn't sure if there was any benefit...I know the cheep root is to order a new cogg and get some one to remove and press a new one one...just making sure before i do it and be sure that there aren't any other options that may be better than the current set up.
  #4
Old 08-17-2018, 06:31 PM
kiliki kiliki is online now
Currently: Not set.
kiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond repute
Garage
Default
Buy a used 8t drive shaft. Do not go 7 t driver!!
  #5
Old 08-17-2018, 06:43 PM
Currently: Not set.
Basic Member
Default
is is cheaper to buy one cogg/driver ..bring it to have the damaged one removed and new one pressed on? vs buy a whole shaft /set up? I see some on ebay for 140 to 170 ish. my shaft is fine only of the drivers is damaged.
  #6
Old 08-17-2018, 08:03 PM
Currently: Not set.
Garage
Default
Price of the driver and 75.00 shop time at best. Your time running it around versus just pull and replace. You do the math
  #7
Old 08-18-2018, 04:23 AM
Currently: Not set.
Basic Member
Default
Thanks for the replies.. guess I’ll start looking for one .
  #8
Old 08-18-2018, 07:35 AM
Big10inch Big10inch is online now
Currently: Not set.
Basic Member
Big10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond repute
Default
If the impact was enough to damage both the driver and the cooler I would make sure the shaft didn't get a slight bend in it. Otherwise 8 tooth for sure. The 7 tooth fitted to 2016 and 17 non MC models with 3 inch tracks definitely saps some performance.
  #9
Old 08-22-2018, 04:12 PM
bgraff1's Avatar
bgraff1 bgraff1 is online now
Currently: patiently waiting for snow
bgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond repute
Default
I have a complete 8t driver set on driveshaft. bolt in and go. 150 plus the ride
__________________
2018 M800 Mountain cat 162. TKI belt drive, airframe running boards, SLP skis, CFR bars/riser, jaws can
  #10
Old 08-23-2018, 04:41 AM
Currently: Not set.
Basic Member
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Another track option? Thread Starter — himark1 Forum — Polaris: AXYS Replies — 5 Last Post — 10-29-2017 12:39 PM
Thread — 137" LT and short track rails, driver, track -$4000 CDN Thread Starter — whistlerhawk Forum — Snowbikes & Parts (Swapmeet) Replies — 0 Last Post — 04-29-2014 05:20 PM
Thread — Why no 3.0" pitch driver option for Mountain Horse? Is 2.86" Really Better? Thread Starter — Frostbite Forum — Snow bikes Replies — 6 Last Post — 02-23-2014 11:02 AM
Thread — Need a new track for the APEX whats the best option!! Thread Starter — PNSPERFORMANCE Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 10 Last Post — 02-22-2011 10:55 PM
Thread — Track option Thread Starter — phaze101 Forum — Yamaha Replies — 2 Last Post — 08-22-2009 02:52 PM
no new posts
