Upgrade to Premium
Polaris: 900 05-06 Polaris RMK 900
Reply
  #1
Old 08-16-2018, 10:32 PM
Drtryda Drtryda is offline
Currently: Not set.
Basic Member
Drtryda is an unknown quantity at this point
Default Instructions for 2006 rmk 900 electric start kit
I bought a electric start for my 2006 rmk 900 and got it all installed but dont know how to mount the battery box. If any one has the instructions or a pic that would be great thanks
Rate this post: Yes | No
  #2
Old 08-16-2018, 10:49 PM
guidoxpress's Avatar
guidoxpress guidoxpress is offline
Currently: Tearing up Alaskas BOMB POW
guidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond repute
Garage
Default
They mount the same as all IQ models from 06-10 if that helps. If you still can’t find anything let me knw and I can get u a pic. I have one in the shop I can snap pics of. But will be in a few hours yet
__________________
"Too much, is not enough"
3 2016 Polaris AXYS.
06 RMK 900
His and Hers 16 badass AXYS builds
  #3
Old 08-16-2018, 11:21 PM
Garage
This off my 05 900, very similar, just a different size battery and battery box. Same layout. If that helps in the meantime. It’s pretty self-explanatory how it lines up. The bottom of the battery box you will run two bolts and nuts through the bottom fender and on the side you’ll run one or two bolts through the left foot well plate. The upper portion of the battery box slides in the slot and closes down over the battery. And you were out the wires through from the foot well plate to the solenoid, circuit breaker and the battery. And then plug in your really. Just make sure to put some dielectric grease on everything when you install it.
Let me know exactly what kind of pictures you are needing and I could try to do better in a little bit when I go to the shop
__________________
06 RMK 900
  #4
Old 08-16-2018, 11:29 PM
Garage
Default
My other 05 900, kind of a chit show, but an idea (some pics off my cell)
__________________
06 RMK 900
  #5
Old 08-17-2018, 01:05 AM
Currently: Not set.
Basic Member
Default
If you could get me a pic that would be awesome I can't find anything
  #6
Old 08-17-2018, 01:08 AM
Currently: Not set.
Basic Member
Default
Are you able to get a pic of the bottom of the bracket that's the part I'm having trouble with I dont know where on the floor it mounts
  #7
Old 08-17-2018, 01:57 AM
Garage
Here’s the 06, if you look straight down under the secondary there is 2 square holes. If you have the bolts with a round head and square neck they work best here (i’m spacing the correct name) otherwise a regular ball washer and that will work fine. The one picture shows the bolts from the bottom up there is two of them. The other picture shows the holes from the top view below the secondary. The last picture shows the bolt that holds the battery box to the side of the foot well.
You only need these three bolts to secure it and then slide the top piece in and hold the battery down. Every 900 comes with these holes predrilled in the lower fender so you cannot miss them
Hope that helps if not private message me and I can help you out again tomorrow if needed
__________________
06 RMK 900
1 out of 1 members found this post helpful. Rate this post: Yes | No
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Polaris Dragon Electric Start Kit Installation Instructions Needed Thread Starter — Yamakaze Forum — Polaris: IQ Replies — 0 Last Post — 03-18-2014 11:29 AM
Thread — Need install instructions for electric start kit, 2009 RMK 800 Thread Starter — towngrunt Forum — Polaris: IQ Replies — 7 Last Post — 10-08-2009 10:32 PM
Thread — Does anyone have instructions for installing electric start? Thread Starter — Super A Forum — Polaris Replies — 1 Last Post — 08-25-2009 09:34 PM
Thread — WTB Electric Start Kit 900 Polaris Thread Starter — promod161 Forum — Engine/Engine Parts (Swapmeet) Replies — 2 Last Post — 03-10-2009 03:50 PM
Thread — Electric start installation instructions 08 700 needed Thread Starter — mtnsledder Forum — Polaris Replies — 1 Last Post — 01-06-2008 09:30 AM
no new posts
