Upgrade to Premium
Polaris: AXYS 2016 AXYS chassis
Reply
  #1
Old 08-15-2018, 10:43 AM
indydan's Avatar
indydan indydan is offline
Currently: Not set.
indydan has a reputation beyond reputeindydan has a reputation beyond reputeindydan has a reputation beyond reputeindydan has a reputation beyond reputeindydan has a reputation beyond reputeindydan has a reputation beyond reputeindydan has a reputation beyond reputeindydan has a reputation beyond reputeindydan has a reputation beyond reputeindydan has a reputation beyond reputeindydan has a reputation beyond repute
Default Checking your TPS ( simplified )
Its important to have your TPS set correctly.
With this meter you can just unplug the ECM and plug the factory OEM wire harness plug into the meter and see you TPS voltage.
It has a USB plug with a supplied wall outlet plug-in for supply voltage.
We found small variances in different plugs and USB Laptop out puts
( And it's calibrated to that plug only )
It takes under 1 minute to check your TPS with this unit.
No need to hunt for the TPS plug
Works on most 2007 newer Polaris Models.
Dan
__________________
____Indy Specialty____
23503 145th Ave
Welch Mn, 55089
Phone 651-388-9045
Home of the multi-year warranty engines and crankshafts !!!
support@indyspecialty.com
Clickable website link below.
http://stores.shop.ebay.com/Indy-Spe...__W0QQ_armrsZ1
4 out of 4 members found this post helpful. Rate this post: Yes | No
The Following 10 Users Say Thank You to indydan For This Useful Post:
05900 (08-16-2018), CO 2.0 (08-20-2018), guidoxpress (08-29-2018), kidder17 (08-27-2018), LPIdaho (08-22-2018), Nooby (09-02-2018), Norway (08-17-2018), Prayn4snow (08-16-2018), Visi (09-09-2018), Wheel House Motorsports (08-15-2018)
  #2
Old 08-15-2018, 05:21 PM
Wheel House Motorsports's Avatar
Wheel House Motorsports Wheel House Motorsports is online now
Currently: is it winter yet?
Wheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond repute
Default
This is brilliant. Take a task that is pretty stupid and make the more complex parts of it MUCH simpler. Now its just hook up and adjust. Not spend a day trying to figure out how to wire up power then take the 10 minutes to adjust things.
__________________
Wheelhousemotorsports@gmail.com
406-871-0955 Bozeman, MT
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to Wheel House Motorsports For This Useful Post:
indydan (08-18-2018)
  #3
Old 08-15-2018, 08:00 PM
SRXSRULE SRXSRULE is online now
Currently: Not set.
SRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond repute
Default
Dont forget the most important part of setting the TPS..... The BASE setting, Which still requires you to tear the sled apart to get the throttle shaft adjusting screw backed off. If someone cant figure out how to hook up a meter, there is a good chance they wont be able to perform the base setting procedure.
This is still a good tool though. I like how this removes the extra connections required when using test leads.
The Following User Says Thank You to SRXSRULE For This Useful Post:
  #4
Old 08-17-2018, 09:17 AM
dude dude is online now
Currently: The point of a journey is not to arrive...
dude has a reputation beyond reputedude has a reputation beyond reputedude has a reputation beyond reputedude has a reputation beyond reputedude has a reputation beyond reputedude has a reputation beyond reputedude has a reputation beyond reputedude has a reputation beyond reputedude has a reputation beyond reputedude has a reputation beyond reputedude has a reputation beyond repute
Default
And the cost??
  #5
Old 08-17-2018, 05:54 PM
tdbaugha's Avatar
tdbaugha tdbaugha is online now
Currently: Not set.
tdbaugha has a reputation beyond reputetdbaugha has a reputation beyond reputetdbaugha has a reputation beyond reputetdbaugha has a reputation beyond reputetdbaugha has a reputation beyond reputetdbaugha has a reputation beyond reputetdbaugha has a reputation beyond reputetdbaugha has a reputation beyond reputetdbaugha has a reputation beyond reputetdbaugha has a reputation beyond reputetdbaugha has a reputation beyond repute
Default
The best way to adjust your TPS is to just buy an 850 and forget about it
The Following User Says Thank You to tdbaugha For This Useful Post:
tmberro (08-20-2018)
  #6
Old 08-20-2018, 01:52 PM
sumtinwong sumtinwong is offline
Currently: Not set.
Basic Member
sumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond repute
Default
it costs 200$ not to bad for the PITA. it will save ya
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Checking TPS with Pc V? Thread Starter — PR Performance Forum — Polaris: Pro-Ride Replies — 4 Last Post — 04-03-2012 09:38 PM
Thread — checking/adjusting TPS, how to? Thread Starter — TurboMatt Forum — Polaris: Pro-Ride Replies — 4 Last Post — 12-12-2011 12:20 PM
Thread — Checking TPS ??? Thread Starter — unclemark Forum — Arctic Cat: 1M Replies — 6 Last Post — 04-12-2011 01:59 AM
Thread — PCV for checking the TPS Thread Starter — powerstroke 350,700 Forum — Polaris: IQ Replies — 5 Last Post — 03-23-2010 07:50 AM
Thread — Checking the TPS ???? Thread Starter — TREE_MAGNET_777 Forum — Polaris Replies — 2 Last Post — 12-08-2008 12:38 AM
no new posts
