Upgrade to Premium
Fouled Plug Stuff not directly related to snowmobiles. ATVs, trucks, hunting, sports, boating etc. Please keep it clean.
Reply
  #1
Old 08-09-2018, 09:52 PM
slyrydr slyrydr is online now
Currently: Not set.
Basic Member
slyrydr has a reputation beyond reputeslyrydr has a reputation beyond reputeslyrydr has a reputation beyond reputeslyrydr has a reputation beyond reputeslyrydr has a reputation beyond reputeslyrydr has a reputation beyond reputeslyrydr has a reputation beyond reputeslyrydr has a reputation beyond reputeslyrydr has a reputation beyond reputeslyrydr has a reputation beyond reputeslyrydr has a reputation beyond repute
Default 4.3 efi mercruser engine
so i buy a slightly used (140 hrs) boat, very clean...has 2 4.3efi merc engines, drive it around the lake near where i live, everything checks out....change out all the filters, gas, oil, outdrives, etc....take it to Lake Powell, hot there, day temps around 100 F, everything goes well first day....second day, i notice one engine tachometer fluctuating from 3800 to as much as 6000 rpm...not the engine itself, just the tach, no problem i figure, just a connection somewhere...short time later i start getting some serious pops (backfires) out of the throttle body, pull power back, backfires go away, power back up, runs for about 5 minutes, then same thing....runs good at idle and up to 2400 to 3400 rpm, then problem repeats itself depending on how long its been running...runs good in the morning when its cool, but as day gets warmer, problem repeats....anybody with 4.3 or similar problem on another engine have experience that might give me a place to start ?....i'm thinking electrical, but not plugs, wires, or rotary cap because for first hour engine runs great, gets full rpm, but after cruising for hour or so, problem begins as described...any ideas ?
Rate this post: Yes | No
  #2
Old 08-10-2018, 05:30 AM
Mafesto's Avatar
Mafesto Mafesto is online now
Currently: and here we have a monkey with 4 asses
Mafesto has a reputation beyond reputeMafesto has a reputation beyond reputeMafesto has a reputation beyond reputeMafesto has a reputation beyond reputeMafesto has a reputation beyond reputeMafesto has a reputation beyond reputeMafesto has a reputation beyond reputeMafesto has a reputation beyond reputeMafesto has a reputation beyond reputeMafesto has a reputation beyond reputeMafesto has a reputation beyond repute
Default
The heat described in scenarios leads me first to detonation.
What grade fuel are you running?
Try some octane booster.
Just an amateurs opinion.
__________________
Member of Day County Trailblazers snowmobile club.
Member of South Dakota Snowmobile Assn.
Support the sport you love, join a club & get involved!
Remember, Pig & Elephant DNA just don't splice
  #3
Old 08-10-2018, 10:29 AM
Currently: Not set.
Basic Member
Default
premium fuel from name brand station...thanks for input though
  #4
Old 08-10-2018, 11:45 AM
summ8rmk's Avatar
summ8rmk summ8rmk is online now
Currently: Stirring pots
summ8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond repute
Default
Does this have an HEI distributor?
Could be the coil or moisture in the cap.
The coil sends the signal to the tach unless u don't have a distributor, then tach signal would come from a crank sensor.
The Following User Says Thank You to summ8rmk For This Useful Post:
MountainTrashCat (08-23-2018)
  #5
Old 08-10-2018, 06:31 PM
Currently: Not set.
Basic Member
Default
has distributor, backfiring reminds me of a lean condition, but it's definitely related to temperature of running it for 45+ minutes
  #6
Old 08-10-2018, 06:35 PM
summ8rmk's Avatar
Default
Could be fuel pump getting hot and not producing enough pressure?
Hook a pressure gauge on the fuel rail and check it while driving.
  #7
Old 08-10-2018, 10:15 PM
Currently: Not set.
Basic Member
Default
has distributor, the coil comment has merit i think, will be looking at that angle....the fuel pressure also...thx
The Following User Says Thank You to slyrydr For This Useful Post:
  #8
Old 08-11-2018, 06:28 AM
Big10inch Big10inch is offline
Currently: Not set.
Basic Member
Big10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond repute
Default
The backfire is being caused by the engine being out of time. Either the distributor timing is way off, you have a worn distributor or possibly it has jumped time on the timing chain. In any case, backfires on a boat are a good way to blow the whole thing up.
  #9
Old 08-11-2018, 12:14 PM
Currently: Not set.
Basic Member
Default
yup....that's what i'm trying to prevent
  #10
Old 08-11-2018, 12:41 PM
Jaynelson Jaynelson is online now
Currently: Not set.
Jaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond repute
Default
I would agree on the timing. I have heard of guys trying to advance timing on those motors....maybe someone has done that and gotten carried away? Maybe it's on the edge and presents itself more when hot? Total guess.
On another note....I have that same motor in my boat and the tachometer does the same thing, but never had a running issue. Some times if it's acting up I can tap it and it fixes itself. So the 2 issues may be completely unrelated.
  #11
Old 08-11-2018, 12:45 PM
Mafesto's Avatar
Click Here to Register
  #12
Old 08-11-2018, 04:29 PM
89sandman's Avatar
89sandman 89sandman is online now
Currently: Meadow Muffin
89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute
The Following User Says Thank You to 89sandman For This Useful Post:
SayatodaU.P.eh? (08-23-2018)
  #13
Old 08-12-2018, 09:22 PM
Currently: Not set.
Basic Member
  #14
Old 08-22-2018, 05:32 PM
Currently: Not set.
Basic Member
The Following 3 Users Say Thank You to slyrydr For This Useful Post:
Jaynelson (08-22-2018), MountainTrashCat (08-23-2018), summ8rmk (08-22-2018)
  #15
Old 08-22-2018, 08:44 PM
89sandman's Avatar
  #16
Old 08-23-2018, 02:55 PM
SayatodaU.P.eh?'s Avatar
SayatodaU.P.eh? SayatodaU.P.eh? is online now
Currently: Waiting for snow...
SayatodaU.P.eh? has a reputation beyond reputeSayatodaU.P.eh? has a reputation beyond reputeSayatodaU.P.eh? has a reputation beyond reputeSayatodaU.P.eh? has a reputation beyond reputeSayatodaU.P.eh? has a reputation beyond reputeSayatodaU.P.eh? has a reputation beyond reputeSayatodaU.P.eh? has a reputation beyond reputeSayatodaU.P.eh? has a reputation beyond reputeSayatodaU.P.eh? has a reputation beyond reputeSayatodaU.P.eh? has a reputation beyond reputeSayatodaU.P.eh? has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — M7 EFI Engine Cases Thread Starter — RACINSTATION Forum — Engine/Engine Parts (Swapmeet) Replies — 0 Last Post — 04-04-2011 07:30 PM
Thread — 95 500 efi engine Thread Starter — Snow Duck Forum — Engine/Engine Parts (Swapmeet) Replies — 0 Last Post — 12-07-2009 12:20 AM
Thread — 99 600 EFI engine......... Thread Starter — bruno55 Forum — Engine/Engine Parts (Swapmeet) Replies — 9 Last Post — 02-13-2009 12:16 PM
Thread — Trade m7 efi engine for carb. engine? they don't interchange Thread Starter — wrench2race Forum — Racing Replies — 0 Last Post — 10-26-2008 07:13 PM
Thread — 04 f6 efi engine parts Thread Starter — cat45 Forum — Engine/Engine Parts (Swapmeet) Replies — 0 Last Post — 03-13-2008 03:04 PM
no new posts
