Upgrade to Premium
Reply
  #1
Old 08-09-2018, 07:52 AM
tmgilder tmgilder is offline
Currently: Not set.
Basic Member
tmgilder is an unknown quantity at this point
Default Big guy needs bigger running boards
I want to get into the new ascender chassis. But because they made the sled more narrow, the running boards more more narrow. I’m 6’7” and wear a size 16 boot. I need the wider running boards to stay on. Is there any aftermarket options to widen the boards? Everything I’ve found is to make them more narrow. Thank you!
Rate this post: Yes | No
  #2
Old 08-09-2018, 08:14 AM
summ8rmk's Avatar
summ8rmk summ8rmk is online now
Currently: Alpha Hawk!
summ8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond repute
Default
U will be fine.
Give it a few rides and u will be comfortable on the narrow boards.
My little size 12 boots fit just fine and i don't have my feet against the tunnel.
Put ur pinky toe up on the edge or just past the edge of the board and that helps tilt the ankle in towards the tunnel and gives better control as a rider.
I either have the pinky or the heel hanging off when off trail, even with the wider boards.
2 out of 2 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to summ8rmk For This Useful Post:
tmgilder (08-09-2018)
  #3
Old 08-09-2018, 08:27 AM
jakey-boy jakey-boy is online now
Currently: Not set.
jakey-boy has a reputation beyond reputejakey-boy has a reputation beyond reputejakey-boy has a reputation beyond reputejakey-boy has a reputation beyond reputejakey-boy has a reputation beyond reputejakey-boy has a reputation beyond reputejakey-boy has a reputation beyond reputejakey-boy has a reputation beyond reputejakey-boy has a reputation beyond reputejakey-boy has a reputation beyond reputejakey-boy has a reputation beyond repute
Garage
Default
X brand performance builds wider boards. Give Mike a call 208-534-1557 and he can give you the details.
__________________
TheJKYboy
Click here for Awesome Sled Pics!!!
The Following User Says Thank You to jakey-boy For This Useful Post:
  #4
Old 08-09-2018, 09:58 AM
kanedog kanedog is offline
Currently: resident jackass #2
kanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond repute
Garage
Default
Cr racing makes wide running boards all the way to the back. Perfect for size 16 boots.
Sent from my SM-G920W8 using Tapatalk
The Following User Says Thank You to kanedog For This Useful Post:
  #5
Old 08-09-2018, 12:46 PM
boondocker97 boondocker97 is online now
Currently: working for the man
boondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond repute
Default
I'm a big guy too with a size 16 boots and had the same concerns as you going to the narrow boards. I ended up putting the Cat pro-mtn narrow boards on anyway, but with screws in the outer rail and don't have any grip/slip issues. The only time I feel a little cramped is riding down the trail and I'm trying to slide my foot all the way up into the toe box area. Off trail I don't have any issues. I'll try to take a picture or two of what it looks like standing with my boots on.
I will say if I did it again I'd skip the Cat boards and spend the extra $100 on B&M. The inside plastic traction cleats I left on build some ice under certain conditions (the newer ones have a different shape to the cleats that might help this), I had to grind down a couple high spots of weld to get them to sit flat down like I wanted on the tunnel edge, and they aren't quite as beefy for a big guy jumping. I have a slight bow in them now. Not as bad as if it was a stock running board edge, but my previous early-build BDX tube boards were still straight after 3 seasons.
__________________
Current Sleds:
2014-2018ish BDX Pro-Lite 900, 2005 M7 with upgrades - Ol' Reliable, 1974 Cheetah
Still in the Family:
2009 M1300, 2001 Mountain Cat 800 LE, 1972 Kitty Cat
Gone but not Forgotten:
1999 Powder Special 600 LE, 1998 Powder Special 600, 1993 EXT 550, 1980 JAG 340
The Following User Says Thank You to boondocker97 For This Useful Post:
  #6
Old 08-09-2018, 01:03 PM
Chewy22's Avatar
Chewy22 Chewy22 is offline
Currently: Not set.
Chewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond repute
Default
B&M fab has both the skinny and burly (wider) boards.
The Following User Says Thank You to Chewy22 For This Useful Post:
  #7
Old 08-09-2018, 04:17 PM
Currently: Not set.
Basic Member
Default
Thank you guys for the input. I’m just doing research now. Torn between a 2016 m8000 limited and a 2018 xf 8000 hc limited. Both are super good deals at my local dealer. But still 3k$ difference. Coming from a 06 m7, both are going to be a new world for me. Going to probably let the bank make the decision for me and see what I can afford.
  #8
Old 08-09-2018, 04:26 PM
summ8rmk's Avatar
Default
The 18 is vastly improved over the 16, definatley worth the price difference.
I hope ur bank tells u to get the 18...
tmgilder (08-10-2018)
  #9
Old 08-09-2018, 11:35 PM
madmax's Avatar
madmax madmax is offline
Currently: Not set.
madmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond repute
Default
Before buying any new boards ride it the way it comes a few times and then decide if you need wider. Definitely get the 18’ if cannat all afford it, you’ll be glad you did. BTW, I’m pretty sure the stock boards on the 16’ are a little wider than the 18’.
__________________
19’ Alpha 800 turbo
18, MC 153 stock
18’ axys 155 stock
17’ Cat 800 snow pro 153 alpha skid
The Following User Says Thank You to madmax For This Useful Post:
  #10
Old 08-09-2018, 11:49 PM
summ8rmk's Avatar
Default
If im not mistaken, the ascender boards are the same width as the Mseries.
The proclimb has fat boards, about 1in wider.
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #11
Old 08-10-2018, 06:34 AM
Currently: Not set.
Basic Member
Click Here to Register
  #12
Old 08-10-2018, 10:38 AM
Wheel House Motorsports's Avatar
Wheel House Motorsports Wheel House Motorsports is offline
Currently: is it winter yet?
Wheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond repute
The Following User Says Thank You to Wheel House Motorsports For This Useful Post:
  #13
Old 08-10-2018, 12:27 PM
Yaeger34 Yaeger34 is offline
Currently: Not set.
Yaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond repute
  #14
Old 08-11-2018, 08:10 AM
goridedoo's Avatar
goridedoo goridedoo is online now
Currently: Not set.
goridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — WTB: Polaris Pro Stock 13 Running Boards or Burandt Boards Thread Starter — seth25 Forum — WTB (Swapmeet) Replies — 0 Last Post — 01-05-2013 09:57 PM
Thread — Big 3 day SALE starts today vents, running boards, bumpers, 509 helmets & goggles Thread Starter — ronniehotdogg Forum — Arctic Cat: Proclimb M Replies — 0 Last Post — 11-22-2012 10:26 AM
Thread — Running Boards, Skinz Air-Frame, Better Boards, and WRP Thread Starter — GoBigParts Forum — Polaris: Pro-Ride Replies — 10 Last Post — 10-22-2011 03:47 AM
Thread — 900 cc big bore or bigger for xp Thread Starter — lookup Forum — Ski-Doo: XP Sleds Replies — 11 Last Post — 02-23-2010 11:22 AM
Thread — Big government gets bigger. Thread Starter — Ollie Forum — Fouled Plug Replies — 2 Last Post — 06-16-2009 12:45 PM
no new posts
