Upgrade to Premium
Polaris: Pro-Ride 2010 and up, all models in the Pro-Ride chassis
Reply
  #1
Old 08-08-2018, 03:46 PM
MTNTK's Avatar
MTNTK MTNTK is offline
Currently: Not set.
MTNTK has a reputation beyond reputeMTNTK has a reputation beyond reputeMTNTK has a reputation beyond reputeMTNTK has a reputation beyond reputeMTNTK has a reputation beyond reputeMTNTK has a reputation beyond reputeMTNTK has a reputation beyond reputeMTNTK has a reputation beyond reputeMTNTK has a reputation beyond reputeMTNTK has a reputation beyond reputeMTNTK has a reputation beyond repute
Default Overheating Problems in Marginal Snow?
Here is the solution for your overheating problems in marginal snow conditions. Let’s face it, with a 3" track marginal snow conditions are any time you are on the trail! By installing the MTNTK performance long tunnel cooler you will double your cooling surface area and coolant capacity. We started with a fresh design and had our own profile made because the other coolers on the market do not fit the tunnel properly and do not allow you to put the rivets back in the correct locations. This cooler is very simple to install and requires no cutting or welding to your original tunnel cooler. All connections are made between the fuel tank and the air box to maintain a stock appearance. This tunnel cooler is available in a 5 foot length for maximum cooling or 3 foot length to increase cooling without the 5' weight penalty. The 5 foot cooler and added coolant capacity totals an 11 pound gain, but the cooling cannot be overstated. The weight is far less noticeable than being stuck on the side of the trail with an overheat. With the 5' cooler you realistically maintain a 125 deg engine temp even when going down the trail. The 3' cooler will dramatically reduce temps and for most sleds it will be the solution you have been dreaming of. The engine runs much better when the heat is managed properly and you only need to be concerned about hyfax lubrication which is easily overcome with the use of the factory "scratchers". It is a liberating experience to ride without your engine overheating. We have been told that overheating on the trail is something that you have to live with because of the "modern" design of mountain sleds. This is simply not true. The weight wars on sleds has been beneficial at making sleds easier to ride and more capable but the cooling systems have become ineffective. These coolers are the answer you have been looking for.
For more information, click the link below!
https://www.mtntkperformance.com/eng...-tunnel-cooler
__________________
https://mtntkperformance.com/
Rate this post: Yes | No
The Following 3 Users Say Thank You to MTNTK For This Useful Post:
kanedog (08-09-2018), mountainhorse (08-09-2018), Norway (09-22-2018)
  #2
Old 08-08-2018, 06:36 PM
TRS's Avatar
TRS TRS is online now
Currently: Waiting for winter
TRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond repute
Default
Awesome product. I have installed the 5’Er on two sleds. If you have a 3” or a turbo this is a must have mod.
  #3
Old 08-08-2018, 08:33 PM
gonehuntnpowder gonehuntnpowder is offline
Currently: Not set.
gonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond repute
Default
The one thing I disliked more than anything about my axys is the constant watching of the temp gauge and overheating. Put a 5 ft mtntk cooler on it. Problem solved. Great product.
  #4
Old 08-09-2018, 05:34 AM
Mark's RMK's Avatar
Mark's RMK Mark's RMK is offline
Currently: Not set.
Mark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond repute
Default Hay Days?
Will you be at Hay Days in Sept?
__________________
2013 800 Pro RMK 155 ES, Burandt boards, Timbersled A-arms, NXT Level WS Bag, skid plate, VE belt guard, Team Tied Clutch, MTX wts, SLP Hot Air Eliminators, Mike Taylor Footwell Vents, Powder Keg tank/pack, Rox Flex Tec II Handguards.
Wife's Sled - 2012 Yamaha Apex XTX 144" EPS, Earth X battery, Yamaha Handguards, cable scratchers
2015 600 RMK 155, ES, skid plate, MTX wts
The Following User Says Thank You to Mark's RMK For This Useful Post:
NorthMNSledder (08-09-2018)
  #5
Old 08-30-2018, 07:45 AM
TransDoc TransDoc is offline
Currently: Working to ride...
Basic Member
TransDoc is an unknown quantity at this point
Default
I just installed the 5' cooler on my wife's '13 800 155. Not too bad to install at all, and a quality product!
The Following User Says Thank You to TransDoc For This Useful Post:
TRS (08-30-2018)
  #6
Old 09-30-2018, 11:17 AM
prowop prowop is offline
Currently: chug.chug.chug. goes the 600
Basic Member
prowop has a reputation beyond reputeprowop has a reputation beyond reputeprowop has a reputation beyond reputeprowop has a reputation beyond reputeprowop has a reputation beyond reputeprowop has a reputation beyond reputeprowop has a reputation beyond reputeprowop has a reputation beyond reputeprowop has a reputation beyond reputeprowop has a reputation beyond reputeprowop has a reputation beyond repute
Default
is there somewhere to get one of these in or around canada? Im in ontario and am looking to not get bent over on shipping..
Reply
Bookmarks
Tags
mtntk, overheating, polaris axys, polaris pro rmk, snowmobile
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — New Snow new problems Thread Starter — 05900 Forum — Avalanche and Survival Replies — 1 Last Post — 02-11-2014 07:36 PM
Thread — Need Marginal Snow Kit for 2000 MM700 Thread Starter — chibravo Forum — Yamaha: 2-stroke Replies — 0 Last Post — 12-26-2010 05:30 PM
Thread — 2008 Dragon 163" overheating problems Thread Starter — Biegs Forum — Polaris: IQ Replies — 13 Last Post — 08-29-2010 04:21 PM
Thread — 2004 rmk 800 overheating problems Thread Starter — EB360 Forum — Polaris Replies — 6 Last Post — 03-10-2009 09:26 AM
Thread — f/ s marginal snow 3" wheel kit Thread Starter — neverenoughsnow Forum — Suspension/Shocks (Swapmeet) Replies — 0 Last Post — 12-15-2007 12:03 PM
no new posts
