Upgrade to Premium
Polaris: AXYS 2016 AXYS chassis
Reply
  #1
Old 08-07-2018, 09:51 AM
RMK-King's Avatar
RMK-King RMK-King is online now
Currently: Not set.
RMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond repute
Default EPA has released HP numbers
2019 EPA testing is done, the HP listed on the tests are as follows.
550 fan-75HP
600CFI- 123.7HP
800CFI-156.7HP
850-167 HP
All seem to be pretty accurate in comparison to past testing. Im sure independent dynos will be +/- a couple HP.
__________________
"Days get shorter,Snow gets deeper,Life gets better"
'19 Pro RMK 850- On order
'17 SB Assault 800
'16 SKS 800 2.6
2 out of 2 members found this post helpful. Rate this post: Yes | No
The Following 10 Users Say Thank You to RMK-King For This Useful Post:
AndrettiDog (08-07-2018), arcticblast (08-09-2018), Daag44 (08-07-2018), freekweet mods (08-07-2018), mountainhorse (08-07-2018), Prayn4snow (08-13-2018), Scott (08-09-2018), Sheetmetalfab (08-07-2018), Teth-Air (08-14-2018), Zrider (08-07-2018)
  #2
Old 08-07-2018, 11:45 AM
Ski-doo#1 Ski-doo#1 is online now
Currently: Not set.
Basic Member
Ski-doo#1 has a reputation beyond reputeSki-doo#1 has a reputation beyond reputeSki-doo#1 has a reputation beyond reputeSki-doo#1 has a reputation beyond reputeSki-doo#1 has a reputation beyond reputeSki-doo#1 has a reputation beyond reputeSki-doo#1 has a reputation beyond reputeSki-doo#1 has a reputation beyond reputeSki-doo#1 has a reputation beyond reputeSki-doo#1 has a reputation beyond reputeSki-doo#1 has a reputation beyond repute
Default
You are incorrect.
Those are torque numbers that you converted to HP.
Sorry but units of torque and HP aren't interchangeable. The EPA lists the values as kW which is power, but the EPA is incorrect.
If you did the same thing from that spreadhseet and converted the Doo 850's number from kW to HP you would get 193 HP.
So you're telling me the Doo 850 puts out 193 HP? Okay I agree, but no. 😂
  #3
Old 08-07-2018, 11:51 AM
Currently: Not set.
Basic Member
Default
What you really should take from the EPA data is torque not power:
Poo 840: 124.5 Nm ~ 91.83 ft-lb
Doo 850: 144.5 Nm ~ 106.58 ft-lb (awfully close to what Dynotech found)
  #4
Old 08-07-2018, 12:35 PM
Timbre's Avatar
Timbre Timbre is offline
Currently: Let 'er SNOW!!
Timbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond repute
Default
Sounds about right.
Add a pipe and can to the 850 and it will be close to 180 HP.
Gonna be a BEAST!!
  #5
Old 08-07-2018, 12:42 PM
richracer1's Avatar
richracer1 richracer1 is online now
Currently: Loving my BMP 860
richracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond repute
Default
If you convert the 124.6kW to HP (KW power to mechanical horse power) it comes out as:
124.6 kilowatt = 167.09135236 horsepower (550 ft*lbf/s)
Kilowatts are used worldwide, typically to express the output power of engines and the power of electric motors, tools, machines, and heaters.
Mechanical horsepower, also known as imperial horsepower, is defined as approximately 745.7 watts (550 ft·lbf/s)
__________________
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following 3 Users Say Thank You to richracer1 For This Useful Post:
05900 (08-08-2018), Daag44 (08-08-2018), Sage Crusher (08-07-2018)
  #6
Old 08-07-2018, 12:45 PM
richracer1's Avatar
Default
IMO the spreadsheet should read "max test power" instead of "max test torque"
Of course, I or the EPA could be full of you know what....LOL
__________________
  #7
Old 08-07-2018, 01:34 PM
damx damx is online now
Currently: Not set.
damx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond repute
Default
I would of liked it to be over 100 ft-lbs
  #8
Old 08-07-2018, 01:39 PM
Currently: Not set.
Basic Member
Default
Also wrong, it should read "Max Test Torque (Nm)" The EPA is wrong. Cause the values in that column are torque values not Power and not kW values. They are Nm (Newton-Meter) Values.
You do that exact same calculation that you did above with the value for the Doo 850 on that spreadsheet and report back to everyone what your HP value is for the Doo 850. And then I will ask you: You still think it should say max test power?
The Following User Says Thank You to Ski-doo#1 For This Useful Post:
richracer1 (08-07-2018)
  #9
Old 08-07-2018, 03:30 PM
richracer1's Avatar
Default
No need to recalculate, you are correct, should be "Max Test Torque, Nm" not kW. To many dang conversions going through my few brain cells at that time.
__________________
The Following 4 Users Say Thank You to richracer1 For This Useful Post:
05900 (08-08-2018), Sage Crusher (08-07-2018), Ski-doo#1 (08-07-2018), summ8rmk (08-07-2018)
  #10
Old 08-07-2018, 04:39 PM
freekweet mods freekweet mods is offline
Currently: Not set.
freekweet mods has a reputation beyond reputefreekweet mods has a reputation beyond reputefreekweet mods has a reputation beyond reputefreekweet mods has a reputation beyond reputefreekweet mods has a reputation beyond reputefreekweet mods has a reputation beyond reputefreekweet mods has a reputation beyond reputefreekweet mods has a reputation beyond reputefreekweet mods has a reputation beyond reputefreekweet mods has a reputation beyond reputefreekweet mods has a reputation beyond repute
Default
So if doo had poo clutching?
  #11
Old 08-07-2018, 04:48 PM
AndrettiDog's Avatar
AndrettiDog AndrettiDog is offline
Currently: I know, let's have a spelling contest
AndrettiDog has a reputation beyond reputeAndrettiDog has a reputation beyond reputeAndrettiDog has a reputation beyond reputeAndrettiDog has a reputation beyond reputeAndrettiDog has a reputation beyond reputeAndrettiDog has a reputation beyond reputeAndrettiDog has a reputation beyond reputeAndrettiDog has a reputation beyond reputeAndrettiDog has a reputation beyond reputeAndrettiDog has a reputation beyond reputeAndrettiDog has a reputation beyond repute
Click Here to Register
The Following User Says Thank You to AndrettiDog For This Useful Post:
  #12
Old 08-07-2018, 05:39 PM
Currently: Not set.
  #13
Old 08-07-2018, 08:55 PM
Currently: Not set.
Basic Member
  #14
Old 08-08-2018, 09:18 AM
snowmobiler snowmobiler is offline
Currently: Not set.
snowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond repute
  #15
Old 08-08-2018, 02:20 PM
Perk's Avatar
Perk Perk is online now
Currently: Not set.
Perk has a reputation beyond reputePerk has a reputation beyond reputePerk has a reputation beyond reputePerk has a reputation beyond reputePerk has a reputation beyond reputePerk has a reputation beyond reputePerk has a reputation beyond reputePerk has a reputation beyond reputePerk has a reputation beyond reputePerk has a reputation beyond reputePerk has a reputation beyond repute
  #16
Old 08-08-2018, 03:39 PM
05900's Avatar
05900 05900 is offline
Currently: Hele i kahi mokupuni
05900 has a reputation beyond repute05900 has a reputation beyond repute05900 has a reputation beyond repute05900 has a reputation beyond repute05900 has a reputation beyond repute05900 has a reputation beyond repute05900 has a reputation beyond repute05900 has a reputation beyond repute05900 has a reputation beyond repute05900 has a reputation beyond repute05900 has a reputation beyond repute
Garage
  #17
Old 08-08-2018, 09:27 PM
Currently: Not set.
Basic Member
Perk (08-09-2018)
  #18
Old 08-08-2018, 09:38 PM
WestMont WestMont is offline
Currently: Not set.
WestMont has a reputation beyond reputeWestMont has a reputation beyond reputeWestMont has a reputation beyond reputeWestMont has a reputation beyond reputeWestMont has a reputation beyond reputeWestMont has a reputation beyond reputeWestMont has a reputation beyond reputeWestMont has a reputation beyond reputeWestMont has a reputation beyond reputeWestMont has a reputation beyond reputeWestMont has a reputation beyond repute
  #19
Old 08-08-2018, 09:50 PM
RMK-King's Avatar
Currently: Not set.
  #20
Old 08-08-2018, 09:53 PM
Currently: Not set.
Basic Member
  #21
Old 08-08-2018, 09:58 PM
Daag44 Daag44 is online now
Currently: Not set.
Basic Member
Daag44 has a reputation beyond reputeDaag44 has a reputation beyond reputeDaag44 has a reputation beyond reputeDaag44 has a reputation beyond reputeDaag44 has a reputation beyond reputeDaag44 has a reputation beyond reputeDaag44 has a reputation beyond reputeDaag44 has a reputation beyond reputeDaag44 has a reputation beyond reputeDaag44 has a reputation beyond reputeDaag44 has a reputation beyond repute
  #22
Old 08-08-2018, 10:17 PM
Currently: Not set.
Basic Member
  #23
Old 08-08-2018, 10:23 PM
Currently: Not set.
Basic Member
  #24
Old 08-08-2018, 10:26 PM
RMK-King's Avatar
Currently: Not set.
  #25
Old 08-08-2018, 10:50 PM
RMK-King's Avatar
Currently: Not set.
The Following 2 Users Say Thank You to RMK-King For This Useful Post:
Daag44 (08-09-2018), Ski-doo#1 (08-09-2018)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Any changes for 2012 EPA Phase3 ? Thread Starter — Daggerboat Forum — Polaris: Pro-Ride Replies — 1 Last Post — 02-12-2012 02:15 PM
Thread — EPA 2012 Thread Starter — Daggerboat Forum — Polaris: Pro-Ride Replies — 4 Last Post — 03-28-2010 09:15 PM
Thread — The EPA....help me out here Thread Starter — RichardCranium Forum — Fouled Plug Replies — 0 Last Post — 10-28-2009 04:21 PM
Thread — has cat released actuall weight and hp numbers for the 2010 M8 Thread Starter — 89sandman Forum — Arctic Cat: M Series Replies — 4 Last Post — 03-25-2009 02:57 PM
Thread — EPA crackdown on sleds?!! Must See Thread Starter — ucandooit Forum — General Snowmobiling Replies — 17 Last Post — 02-03-2008 10:59 PM
