Upgrade to Premium
Arctic Cat: Proclimb M 2012 and beyond
Reply
  #1
Old 08-07-2018, 07:26 AM
Radar78 Radar78 is offline
Currently: Back to riding 1HP.
Radar78 has a reputation beyond reputeRadar78 has a reputation beyond reputeRadar78 has a reputation beyond reputeRadar78 has a reputation beyond reputeRadar78 has a reputation beyond reputeRadar78 has a reputation beyond reputeRadar78 has a reputation beyond reputeRadar78 has a reputation beyond reputeRadar78 has a reputation beyond reputeRadar78 has a reputation beyond reputeRadar78 has a reputation beyond repute
Default Which Used Can?
Iím looking for a different can for my Ď16 M8000 limited. Right now thereís a few used ones for sale. An HPS, a TSS and a Silber. Which one would you recommend? Sound doesnít matter to me, just looking for one thatís light and will not cause any bogging issues.
Rate this post: Yes | No
  #2
Old 08-07-2018, 06:37 PM
sno*jet sno*jet is online now
Currently: Not set.
sno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond repute
Default
my SSI ti is too loud for me but I can attest it does not bog and is the lightest you will find. its not as loud as other brand's race/mountain cans, but still too raspy for me. I have an early build 17, before they started putting exhaust deflectors on them. I've choked off the exhaust many times in powder but never had any annoying bogs. mines for sale but was actually thinking of keeping it until I am sure I get as good performance from my replacement. if it sells it sells, if it don't it don't. looks purdy on the shelf.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to sno*jet For This Useful Post:
Radar78 (08-07-2018)
  #3
Old 08-07-2018, 06:46 PM
F7arcticcat's Avatar
F7arcticcat F7arcticcat is online now
Currently: Not set.
F7arcticcat has a reputation beyond reputeF7arcticcat has a reputation beyond reputeF7arcticcat has a reputation beyond reputeF7arcticcat has a reputation beyond reputeF7arcticcat has a reputation beyond reputeF7arcticcat has a reputation beyond reputeF7arcticcat has a reputation beyond reputeF7arcticcat has a reputation beyond reputeF7arcticcat has a reputation beyond reputeF7arcticcat has a reputation beyond reputeF7arcticcat has a reputation beyond repute
Default
I've had two HPS and been around a few others with them. I would buy again.
The Following User Says Thank You to F7arcticcat For This Useful Post:
  #4
Old 08-08-2018, 06:50 AM
Old & slow Old & slow is offline
Currently: Not set.
Old & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond repute
Default
Quote:
I ran a Jaws trail can not to loud no bog worked great. I am running a Sled shed cooker can now I prefer the Jaws (until lunch time), it works good just a little louder, and I'm a little older.
  #5
Old 08-08-2018, 02:35 PM
boondocker97 boondocker97 is online now
Currently: working for the man
boondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond repute
Default
My Bikeman powder lite was definitely light for a steel can, but it made too much noise and I could get it to choke under one certain condition. Sound seemed cool for the first season then got more annoying. Running a Diamond S Ti quiet can now. No bogs on my 900 and fit much better than the Bikeman unit after I added a spring to hold it down against the belly pan (no instructions come with it, but pretty sure that's the way it's intended).
Out of the ones you have listed I'd pick the HPS. Haven't run one personally but I've seen them and build quality seemed good. They also spend time in development to make sure anything they produce works.
__________________
Current Sleds:
2014-2018ish BDX Pro-Lite 900, 2005 M7 with upgrades - Ol' Reliable, 1974 Cheetah
Still in the Family:
2009 M1300, 2001 Mountain Cat 800 LE, 1972 Kitty Cat
Gone but not Forgotten:
1999 Powder Special 600 LE, 1998 Powder Special 600, 1993 EXT 550, 1980 JAG 340
The Following User Says Thank You to boondocker97 For This Useful Post:
Radar78 (08-08-2018)
  #6
Old 08-08-2018, 05:51 PM
Currently: Not set.
Default
I like how hps changes up the bottom contour of the exit flange to the belly pan depending on what year you have. I tweaked the flange on the SSI just a hair to seat it better on my 17MC. neither uses a lower frame mount apparently tho, something I like better on other cans I've seen (DS). but the ssi and hps probably seal better than most down there. however I'm not sure flange seal is much important on these, they suck air from outside unless you've modified the intake somehow.
  #7
Old 08-09-2018, 05:59 AM
beerios5 beerios5 is offline
Currently: Not set.
beerios5 is an unknown quantity at this point
Default
If u can find a MPX used, I am really happy with mine. Sounds great and is re-packable if it gets to loud. Search on eBay. Not to bad of a price new either.
  #8
Old 08-10-2018, 06:58 PM
Suzzy-Q Suzzy-Q is offline
Currently: Not set.
Suzzy-Q has a reputation beyond reputeSuzzy-Q has a reputation beyond reputeSuzzy-Q has a reputation beyond reputeSuzzy-Q has a reputation beyond reputeSuzzy-Q has a reputation beyond reputeSuzzy-Q has a reputation beyond reputeSuzzy-Q has a reputation beyond reputeSuzzy-Q has a reputation beyond reputeSuzzy-Q has a reputation beyond reputeSuzzy-Q has a reputation beyond reputeSuzzy-Q has a reputation beyond repute
Default
SSI
__________________
2017 mountain cat 153; SSI stainless can/y-pipe, SSI pipe mod, pro-cool head, boysen rage cages, Mohawks
2012 sp, 38" front, 162x3, slp stage 2,PCV with timing, mountain fit hood, C3 Belt Drive 2.52, WRP seat, BDX boards(SOLD)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
