Upgrade to Premium
Trucks and Trailers Towing and hauling your sleds
Reply
  #1
Old 08-03-2018, 08:30 AM
volcano buster volcano buster is online now
Currently: Not set.
volcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond repute
Default Converting trailer door from cam bar to RV latch
Anyone comment on the install of an RV latch in a side door? I don't think it will be too difficult on an Interstate trailer, but I'm curious if I need a metal reinforcing ring inside the opening to keep from compressing the foam too much.
Rate this post: Yes | No
  #2
Old 08-05-2018, 11:38 AM
Currently: Not set.
Default
Update:
No foam. Non insulated so just a big air gap.
Not the easiest job.
  #3
Old 08-15-2018, 06:32 AM
Currently: Not set.
Default
I got the door done.
There is a 1" x 1" vertical stud about 7" away from the latch edge that held a plate for the cam bar support. I ended up cutting it above the plate and welding laterally to install a window in the upper portion of the door. With some fiddling it went together pretty well. The latch hole wasn't too bad either once I just dove in and did it.
The big part was to remove the inner plywood and outerskin so I was just working with the door frame. It all came off easy enough and went back on with no issues.
One indispensable tool was my double cut carbide burr set for my dremel. I was able to drill out the holes in the steel door frame and then clean them up to shape using the burrs. Throws sharp shards of steel so be careful. I picked mine up on Amazon for about $13 https://www.amazon.com/YXGOOD-Pieces...rbide+burr+set
This is a door on a concession trailer for the high school boosters so a sled trailer may not need such a large window.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Enclosed Trailer Side Door - Where to purchase? Thread Starter — NorthMNSledder Forum — Trucks and Trailers Replies — 3 Last Post — 09-18-2017 07:00 AM
Thread — Trailer door head pad Thread Starter — ItDoAble Forum — Trucks and Trailers Replies — 5 Last Post — 04-16-2011 11:06 AM
Thread — Trailer Door Frozen Shut Thread Starter — deschutes Forum — Trucks and Trailers Replies — 2 Last Post — 04-06-2010 11:38 AM
Thread — Need a Trailer Door Lock/Latch for Enclosed Thread Starter — Mortgage Paul Forum — General Snowmobiling Replies — 0 Last Post — 11-26-2009 09:33 PM
Thread — Trailer door location Thread Starter — mdutton Forum — General Snowmobiling Replies — 4 Last Post — 10-13-2009 11:49 AM
no new posts
