Upgrade to Premium
Reply
  #1
Old 07-31-2018, 05:28 PM
portgrinder portgrinder is offline
Currently: Not set.
portgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond reputeportgrinder has a reputation beyond repute
Default Kawi fork setup
Anyone care to share what springs etc etc they are running in their bike?
Iíve got showaís out of a 13 250F Iím pretty sure.
Tks
Rate this post: Yes | No
  #2
Old 08-01-2018, 08:19 AM
rhino89523 rhino89523 is offline
Currently: Not set.
Basic Member
rhino89523 has a reputation beyond reputerhino89523 has a reputation beyond reputerhino89523 has a reputation beyond reputerhino89523 has a reputation beyond reputerhino89523 has a reputation beyond reputerhino89523 has a reputation beyond reputerhino89523 has a reputation beyond reputerhino89523 has a reputation beyond reputerhino89523 has a reputation beyond reputerhino89523 has a reputation beyond reputerhino89523 has a reputation beyond repute
Default
I weigh a lot...270ish usually. On the Showa's in my CR500 in a 250X frame I run one rate, In the forks on my cr500 steel framed sand bike I run a slightly different rate and in my snowbike (CR500 as well) I ride a custom wound set of springs that are the stiffest springs I have ever felt. Is this just for your snowbike? and how much you weigh and what bike they are on makes a difference...Is it a 250F snowbike?
  #3
Old 08-04-2018, 12:21 PM
Currently: Not set.
Default
I’m 175. Kx500 in a ‘13 250f frame.
  #4
Old 08-10-2018, 10:36 AM
Shanks34 Shanks34 is offline
Currently: Not set.
Basic Member
Shanks34 is an unknown quantity at this point
Default
If the forks are from a 2013 kx250f then they will be a single function fork (SFF), so they will have only one spring and itís in the right side. Stock spring will be approx. 0.96kg which is the same as set of .48ís in a older set of spring forks. At 175lbs on any snowbike I would go with 0.60ís so a 1.20kg for those forks. Spring fitment could be pretty tight though, I have those same forks on my 2016 kx450f but havenít used the bike for snowbiking so I didnít try installing the 1.20kg yet.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Looking for 450fx fork setup and running map options Thread Starter — Uncle Bob Forum — Snow bikes Replies — 12 Last Post — 01-17-2018 11:30 AM
Thread — Kx250f fork setup Thread Starter — Norma Stitz Forum — Snow bikes Replies — 3 Last Post — 07-04-2017 10:27 AM
Thread — Fork setup? Thread Starter — capulin overdrive Forum — Snow bikes Replies — 14 Last Post — 07-31-2015 11:02 AM
Thread — Husa 570 Supermotor front fork setup Thread Starter — DieselTwitch Forum — Snow bikes Replies — 7 Last Post — 12-19-2014 10:46 AM
Thread — Need help to recover my broke sled near South Fork/Willow Fork Thread Starter — kahluablast99 Forum — Colorado Replies — 0 Last Post — 03-12-2012 08:41 AM
no new posts
