Upgrade to Premium
Polaris: AXYS 2016 AXYS chassis
Reply
  #1
Old 07-29-2018, 08:36 PM
gonehuntnpowder gonehuntnpowder is offline
Currently: Not set.
gonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond repute
Default Offset spindles and narrow front end
Anyone tried the aftermarket narrow front ends (zbroz, kmod, or alternative impact) with the Zollinger offset spindles.
Thoughts? It's been a slow day and I have been looking at parts all afternoon.
Rate this post: Yes | No
  #2
Old 07-30-2018, 08:33 AM
tuneman's Avatar
tuneman tuneman is online now
Currently: is a long track addict
tuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond repute
Default
IMHO, that would be too narrow. You'd likely panel out on a lot of hills. Plus, it would be extremely tippy. The stock Axys is as tippy as a 36" Pro-Ride chassis. Not referring to you, but if a guy needs less than 36", he probably just needs a lesson on throttle control.
I've got offset spindles on for next season, which I think will be just perfect. A bit narrower with the ability to pick up a last minute replacement stock arm at the local dealer.
__________________
-- Never Let Your Equipment Hold You Back --
The Following User Says Thank You to tuneman For This Useful Post:
gonehuntnpowder (07-30-2018)
  #3
Old 07-30-2018, 09:29 AM
Ron Burgandy's Avatar
Ron Burgandy Ron Burgandy is online now
Currently: Not set.
Ron Burgandy has a reputation beyond reputeRon Burgandy has a reputation beyond reputeRon Burgandy has a reputation beyond reputeRon Burgandy has a reputation beyond reputeRon Burgandy has a reputation beyond reputeRon Burgandy has a reputation beyond reputeRon Burgandy has a reputation beyond reputeRon Burgandy has a reputation beyond reputeRon Burgandy has a reputation beyond reputeRon Burgandy has a reputation beyond reputeRon Burgandy has a reputation beyond repute
Default
i personally think it would be a riot.
The Following User Says Thank You to Ron Burgandy For This Useful Post:
  #4
Old 08-01-2018, 12:11 PM
Murph's Avatar
Murph Murph is online now
Currently: Back in the mountains
Murph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond repute
Default
Hard to say without riding it. I ran the MOUNTAINSIDE PRODUCTS offset spindles on 39” arms and noticed if I put the skis in the narrowest position, the balance point was a lot narrower. It made the sled harder to control on edge, slow speed, steep side hill, through trees. It didn’t feel as precise.... if that makes sense.
__________________
Missing Digit Motors-- Servicing your 2011-current ProRMKs in Truckee, CA
Truckee's source for BMFab,Camso Tracks, Indy Specialties, Lectron Carbs, Mountain Side Products, Mystik Oil, RAZE Motorsports, Speedcell and other fine snowmobile products
Speedcell Technologies-- Founding Member
Tahoe Nordic Search and Rescue-snowmobile team
  #5
Old 08-05-2018, 07:56 PM
Currently: Not set.
Default
Maybe the narrow front end and pro motion? A Polaris Alpha???? I am bored.
  #6
Old 08-06-2018, 10:28 AM
richracer1's Avatar
richracer1 richracer1 is online now
Currently: Loving my BMP 860
richracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond repute
Default
Quote:
I have a KMOD skid with Kmotion and KMOD 37" IFS with standard ZRP spindles. The ski spacers are centered (one spacer on each side of the spindle) and wouldn't want it any narrower.
__________________
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following 2 Users Say Thank You to richracer1 For This Useful Post:
LPIdaho (09-06-2018), Sage Crusher (08-06-2018)
  #7
Old 08-06-2018, 09:37 PM
Currently: Not set.
Default
That is a great setup!
  #8
Old 08-09-2018, 02:48 PM
Jkinzer Jkinzer is offline
Currently: Not set.
Jkinzer has a reputation beyond reputeJkinzer has a reputation beyond reputeJkinzer has a reputation beyond reputeJkinzer has a reputation beyond reputeJkinzer has a reputation beyond reputeJkinzer has a reputation beyond reputeJkinzer has a reputation beyond reputeJkinzer has a reputation beyond reputeJkinzer has a reputation beyond reputeJkinzer has a reputation beyond reputeJkinzer has a reputation beyond repute
Garage
Default
we set up all of our personal sleds and the majority of our customers with zborz 36" kit and ZRP offset spindles. You will not panel out with this set up. it works amazing and takes the chassis to a whole new level of nimbleness in the trees. The offset spindles make the sled handle better as well over the 36" kit by itself.
2 out of 2 members found this post helpful. Rate this post: Yes | No
The Following 3 Users Say Thank You to Jkinzer For This Useful Post:
frntflp (08-31-2018), LPIdaho (08-13-2018), redneckj (09-09-2018)
  #9
Old 08-31-2018, 06:42 AM
frntflp's Avatar
frntflp frntflp is offline
Currently: Waiting for snow
frntflp has a reputation beyond reputefrntflp has a reputation beyond reputefrntflp has a reputation beyond reputefrntflp has a reputation beyond reputefrntflp has a reputation beyond reputefrntflp has a reputation beyond reputefrntflp has a reputation beyond reputefrntflp has a reputation beyond reputefrntflp has a reputation beyond reputefrntflp has a reputation beyond reputefrntflp has a reputation beyond repute
Default
Just received my 36" Zbroz kit and spindles to put on a 2018 Axys. If I ignore the obvious motor change (800--> 850) the only thing I see really different between the 2018 and 2019's is the drop to a 37" front end. No change to the side panels or basic geometry ...... I had wondered about doing this anyway, but when the factory does it across the board, I'm take that as a sign that this could be a very good thing !
*** Not saying the factory(ies) always make(s) the best changes for my riding style and skill level, but this comes true much more often than not.
Seeing pics of the first snow near Jackson really flipped the "I can't wait for winter" switch in me. A daily dose of YouTube riding video's is now standard practice.
__________________
FRNTFLP
'15 Switchback Assault 800 - 60 th Anniv. Ed
'18 Axys Pro RMK 800 155 SC
  #10
Old 08-31-2018, 09:23 AM
dude's Avatar
dude dude is offline
Currently: The point of a journey is not to arrive...
dude has a reputation beyond reputedude has a reputation beyond reputedude has a reputation beyond reputedude has a reputation beyond reputedude has a reputation beyond reputedude has a reputation beyond reputedude has a reputation beyond reputedude has a reputation beyond reputedude has a reputation beyond reputedude has a reputation beyond reputedude has a reputation beyond repute
Default
For those going with the 36" arms vs. offset spindles keep in mind the geometry of the shocks will now be shorter and will handle differently. That's one big difference with the new 2019 stock narrow front ends... the shocks will be designed to work with the narrower front ends on the 19's. That's why on my 2018 I just went with the offset spindles for a narrower deal. The shocks then were at the manufacture dimensions etc. Just my 2 cents...
__________________
2019 Black 850 163" 3" (My sled)
2018 Orange 163" 2.6 (Wife's sled)
2016 Black / Orange Axys 163" 3" (for sale $7,500)
2016 Red / White Axys 163" 2.6" (for sale $7,500)
  #11
Old 08-31-2018, 10:15 AM
m1kflyingtiger's Avatar
m1kflyingtiger m1kflyingtiger is offline
Currently: Awaiting my 850 axys.
m1kflyingtiger has a reputation beyond reputem1kflyingtiger has a reputation beyond reputem1kflyingtiger has a reputation beyond reputem1kflyingtiger has a reputation beyond reputem1kflyingtiger has a reputation beyond reputem1kflyingtiger has a reputation beyond reputem1kflyingtiger has a reputation beyond reputem1kflyingtiger has a reputation beyond reputem1kflyingtiger has a reputation beyond reputem1kflyingtiger has a reputation beyond reputem1kflyingtiger has a reputation beyond repute
Click Here to Register
  #12
Old 08-31-2018, 12:40 PM
frntflp's Avatar
  #13
Old 08-31-2018, 01:11 PM
dude's Avatar
  #14
Old 08-31-2018, 07:51 PM
frntflp's Avatar
  #15
Old 08-31-2018, 08:10 PM
Sheetmetalfab's Avatar
Sheetmetalfab Sheetmetalfab is online now
Currently: Getting the R6 snowbike ready......
Sheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond repute
  #16
Old 08-31-2018, 11:44 PM
  #17
Old 09-02-2018, 09:35 AM
chawks chawks is offline
Currently: Not set.
chawks is an unknown quantity at this point
  #18
Old 09-02-2018, 10:25 AM
Indy_500's Avatar
Indy_500 Indy_500 is offline
Currently: Going Left!
Indy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond repute
Garage
  #19
Old 09-06-2018, 10:03 AM
LPIdaho's Avatar
LPIdaho LPIdaho is offline
Currently: Working hard!
LPIdaho has a reputation beyond reputeLPIdaho has a reputation beyond reputeLPIdaho has a reputation beyond reputeLPIdaho has a reputation beyond reputeLPIdaho has a reputation beyond reputeLPIdaho has a reputation beyond reputeLPIdaho has a reputation beyond reputeLPIdaho has a reputation beyond reputeLPIdaho has a reputation beyond reputeLPIdaho has a reputation beyond reputeLPIdaho has a reputation beyond repute
  #20
Old 09-06-2018, 10:45 AM
Teth-Air's Avatar
Teth-Air Teth-Air is online now
Currently: sourceinnovations.ca
Teth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond repute
The Following 3 Users Say Thank You to Teth-Air For This Useful Post:
dude (09-09-2018), MDEVO (09-12-2018), ZRP Engineering (09-11-2018)
  #21
Old 09-06-2018, 12:36 PM
The Following 3 Users Say Thank You to Sheetmetalfab For This Useful Post:
rulonjj (09-09-2018), takethebounce (09-09-2018), ZRP Engineering (09-11-2018)
  #22
Old 09-08-2018, 02:14 PM
mt.sledder mt.sledder is offline
Currently: Silber Dealer
mt.sledder has a reputation beyond reputemt.sledder has a reputation beyond reputemt.sledder has a reputation beyond reputemt.sledder has a reputation beyond reputemt.sledder has a reputation beyond reputemt.sledder has a reputation beyond reputemt.sledder has a reputation beyond reputemt.sledder has a reputation beyond reputemt.sledder has a reputation beyond reputemt.sledder has a reputation beyond reputemt.sledder has a reputation beyond repute
  #23
Old 09-09-2018, 03:22 AM
Norway's Avatar
Norway Norway is online now
Currently: gettin ready to ride!
Norway has a reputation beyond reputeNorway has a reputation beyond reputeNorway has a reputation beyond reputeNorway has a reputation beyond reputeNorway has a reputation beyond reputeNorway has a reputation beyond reputeNorway has a reputation beyond reputeNorway has a reputation beyond reputeNorway has a reputation beyond reputeNorway has a reputation beyond reputeNorway has a reputation beyond repute
The Following 2 Users Say Thank You to Norway For This Useful Post:
dude (09-09-2018), Teth-Air (09-10-2018)
  #24
Old 09-11-2018, 07:47 PM
Currently: Not set.
  #25
Old 09-12-2018, 04:20 PM
MDEVO's Avatar
MDEVO MDEVO is offline
Currently: Flyboarding until the snow comes!
MDEVO has a reputation beyond reputeMDEVO has a reputation beyond reputeMDEVO has a reputation beyond reputeMDEVO has a reputation beyond reputeMDEVO has a reputation beyond reputeMDEVO has a reputation beyond reputeMDEVO has a reputation beyond reputeMDEVO has a reputation beyond reputeMDEVO has a reputation beyond reputeMDEVO has a reputation beyond reputeMDEVO has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Want a more narrow front end Thread Starter — galljr13 Forum — Arctic Cat: 1100 ProClimb Replies — 8 Last Post — 03-03-2015 11:10 AM
Thread — narrow front end Thread Starter — dhdey Forum — Arctic Cat: M Series Replies — 4 Last Post — 01-14-2015 01:42 AM
Thread — front narrow end kit?? Thread Starter — baldursson Forum — Polaris: 900 Replies — 1 Last Post — 09-13-2012 08:40 AM
Thread — Narrow Front-end on HCR? Thread Starter — MTN AIR Forum — Arctic Cat: M Series Replies — 2 Last Post — 01-25-2010 06:10 PM
