Upgrade to Premium
Arctic Cat: Proclimb M 2012 and beyond
Reply
  #1
Old 07-27-2018, 08:56 PM
firecat225 firecat225 is offline
Currently: Not set.
Basic Member
firecat225 has much to be proud offirecat225 has much to be proud offirecat225 has much to be proud offirecat225 has much to be proud offirecat225 has much to be proud offirecat225 has much to be proud offirecat225 has much to be proud offirecat225 has much to be proud offirecat225 has much to be proud offirecat225 has much to be proud offirecat225 has much to be proud of
Default Mds weights 16-17 team
Just wondering who has these and what they think of then on the team clutch? Im also seeing if anyone has a picture of them since they are not on the website?
Looking to get a set for my flatlander and want some reviews of them on the team.
Thanks
Rate this post: Yes | No
  #2
Old 07-27-2018, 10:25 PM
summ8rmk's Avatar
summ8rmk summ8rmk is online now
Currently: Stirring pots
summ8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond repute
Default
I have them on my 14 with a team primary.
Use the Polaris 100/340.
Added 8.8 grams and still at 8200 rpm at 7k ft.
Put on jaws pipe and removed 2.5 gram from the middle to run 8,400rpm at 7kft.
I like them much better empty in the middle, loaded in the tip.
My 153 can wheelie on flat ground. Its a lot of fun.
  #3
Old 07-28-2018, 07:11 AM
Currently: Not set.
Basic Member
Default
Thanks for the review, did you feel when you had weight in the mid that it didnt feel as punchy? I have these in a non team 2015 flat lander, sled does not have the punch even with reeds down low that my stock 17 does. I may try and reconfigure weight setup this year to get that punch and grunt back.
  #4
Old 07-28-2018, 07:19 AM
summ8rmk's Avatar
Default
Yes, the weight in the middle killed the responsiveness. Once i removed the weight from the middle i was instantly happy.
I forgot to mention, my secondary is all stock 2014 calibration.
  #5
Old 07-28-2018, 08:00 AM
Currently: Not set.
Basic Member
Default
Alright. Only thing im worried about is i have the turbo weights on my 15 for a flat lander, they are supposed to be beneficial for low elevation 800s. I have the mid and tip loaded down to where steve recommends. I hit 7900+ off the bat and climb to 8300. If i lighten mid and add tip weight im worried about belt slip down low.
Maybe im over looking it
  #6
Old 07-28-2018, 08:02 AM
Currently: Not set.
Basic Member
Default
I realize i need to be around 8050 peak. I have to add tip weight
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Team clutch and MDS weights Thread Starter — m-ervin Forum — Arctic Cat: 1100 ProClimb Replies — 7 Last Post — 12-16-2013 07:09 PM
Thread — Team clutch review 275 evo kit. MDS weights. Thread Starter — HCM Forum — Arctic Cat: 1100 ProClimb Replies — 5 Last Post — 02-03-2013 09:30 AM
Thread — Tied Team clutch w/ 215 Evo, and MDS weights Thread Starter — cattracks Forum — Arctic Cat: 1100 ProClimb Replies — 4 Last Post — 12-15-2012 06:35 PM
Thread — Team Rooster Weights or MDS Thread Starter — edavis0202 Forum — Polaris: Pro-Ride Replies — 10 Last Post — 06-07-2012 08:24 PM
Thread — team and mds weights in alaska Thread Starter — aksnopro Forum — Arctic Cat: Proclimb M Replies — 21 Last Post — 03-24-2012 08:30 PM
no new posts
