Upgrade to Premium
Polaris: Pro-Ride 2010 and up, all models in the Pro-Ride chassis
Reply
  #1
Old 07-27-2018, 11:16 AM
Snowlover Snowlover is offline
Currently: Not set.
Basic Member
Snowlover has a reputation beyond reputeSnowlover has a reputation beyond reputeSnowlover has a reputation beyond reputeSnowlover has a reputation beyond reputeSnowlover has a reputation beyond reputeSnowlover has a reputation beyond reputeSnowlover has a reputation beyond reputeSnowlover has a reputation beyond reputeSnowlover has a reputation beyond reputeSnowlover has a reputation beyond reputeSnowlover has a reputation beyond repute
Default Preffered/best year for used Pro?
I am always a model or 2 behind current due to my choice to limit the cash spent on toys. My IQ is great and the Pro rear suspension I put on it was a step up, but I want to make it my "buddy" sled and get a Pro. Piston issues? Was 2013+ better pistons? Fix it kit needed on what years? 2013 plus with belt drive?
Looking for an 800, 163" deal.
Rate this post: Yes | No
  #2
Old 07-27-2018, 11:21 AM
Jaynelson Jaynelson is offline
Currently: Not set.
Jaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond reputeJaynelson has a reputation beyond repute
Default
The 2015's were the last year and the best.
If you can find a snowcheck model they had some really nice colour combos and most SC'd would also have the big Walker Evans needle shocks (similar to Assault shocks). On that sled I would only worry about replacing pistons if it were a higher mileage unit.
  #3
Old 07-27-2018, 11:39 AM
Currently: Not set.
Basic Member
Default
The 15 assault has wider stance that can't be narrowed without new shocks, correct?
  #4
Old 07-27-2018, 11:46 AM
Currently: Not set.
Default
Quote:
Correct but the Snowcheck RMK's of that year had the needle shocks and narrower RMK stance.
  #5
Old 07-27-2018, 01:18 PM
Wheel House Motorsports's Avatar
Wheel House Motorsports Wheel House Motorsports is offline
Currently: is it winter yet?
Wheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond repute
Default
The newer and lower miles the better. Also just keeping an eye on them for how they were stored. Polaris isn't great with electrical so if the thing sat and ate road grime and is all corroded under the hood id steer clear. the 13-15's can be had for pretty damn cheap and work really well. Hard to beat performance/$$ right now since the axys absolutely tanked the Pro market.
__________________
Wheelhousemotorsports@gmail.com
406-871-0955 Bozeman, MT
  #6
Old 07-27-2018, 01:23 PM
Currently: Not set.
Basic Member
Default
Great info. I’ll watch with new sleds coming someone may need to sell their pro
What do you mean “tanked”. I thought the new ones were well liked.
  #7
Old 07-27-2018, 02:18 PM
Currently: Not set.
Default
That's what he means....the Axys is very well liked, and with used Axy's now on the market, the Pro's can be had super cheap.
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #8
Old 07-27-2018, 05:56 PM
AdrenalineAddict AdrenalineAddict is offline
Currently: Looking Forward To A 0Degree Afternoon!!
Basic Member
AdrenalineAddict has a reputation beyond reputeAdrenalineAddict has a reputation beyond reputeAdrenalineAddict has a reputation beyond reputeAdrenalineAddict has a reputation beyond reputeAdrenalineAddict has a reputation beyond reputeAdrenalineAddict has a reputation beyond reputeAdrenalineAddict has a reputation beyond reputeAdrenalineAddict has a reputation beyond reputeAdrenalineAddict has a reputation beyond reputeAdrenalineAddict has a reputation beyond reputeAdrenalineAddict has a reputation beyond repute
Default
The 2011's and 12's were very good units, although my '12 had piston scuffing issues with the original monoblock. The '13's had the occasional driveshaft and drive sprocket broken bolt issue. My '14 had electrical gremlins from the get go, mostly all wiring harness connector arcing meltdowns. My '14 also broke a few lower sprocket bolts turning it into a suicide machine if you didn't bail soon enough when all hell broke loose. I'm not sure if Polaris really updated or changed much from '13 on except the support clamp on the driven end of the driveshaft. If you do find a clean unit and it has more than 2,000 miles on the stock pistons make sure you freshen it up. They never did update the ankle/leg breaking foot capturing devices they built
  #9
Old 07-28-2018, 09:01 AM
richracer1's Avatar
richracer1 richracer1 is offline
Currently: Loving my BMP 860
richracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond repute
Default
Just an FYI, Pro-RMKs never came with Walker "Needle" shocks. Polaris started putting Walker "Clicker" shocks on 2015 snow-checked Pro-Ride Pro-RMKs and still do on snow-checked Axys Pro-RMKs.
__________________
  #10
Old 07-28-2018, 09:16 AM
Currently: Not set.
  #11
Old 07-28-2018, 10:42 PM
Currently: Not set.
Basic Member
Click Here to Register
  #12
Old 07-29-2018, 11:48 AM
vinpie1 vinpie1 is offline
Currently: wrenching
Basic Member
vinpie1 has a reputation beyond reputevinpie1 has a reputation beyond reputevinpie1 has a reputation beyond reputevinpie1 has a reputation beyond reputevinpie1 has a reputation beyond reputevinpie1 has a reputation beyond reputevinpie1 has a reputation beyond reputevinpie1 has a reputation beyond reputevinpie1 has a reputation beyond reputevinpie1 has a reputation beyond reputevinpie1 has a reputation beyond repute
  #13
Old 07-29-2018, 08:04 PM
diamonddave's Avatar
diamonddave diamonddave is offline
Currently: <<In-House PolarisTechnician not as involved in the shop
diamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond repute
The Following User Says Thank You to diamonddave For This Useful Post:
94fordguy (08-18-2018)
  #14
Old 07-29-2018, 09:12 PM
sledhed's Avatar
sledhed sledhed is offline
Currently: Last ride of the season 5/25/18...
sledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond repute
  #15
Old 07-29-2018, 11:04 PM
sledhead_79's Avatar
sledhead_79 sledhead_79 is offline
Currently: Who's idea was this?
sledhead_79 has a reputation beyond reputesledhead_79 has a reputation beyond reputesledhead_79 has a reputation beyond reputesledhead_79 has a reputation beyond reputesledhead_79 has a reputation beyond reputesledhead_79 has a reputation beyond reputesledhead_79 has a reputation beyond reputesledhead_79 has a reputation beyond reputesledhead_79 has a reputation beyond reputesledhead_79 has a reputation beyond reputesledhead_79 has a reputation beyond repute
Garage
  #16
Old 08-02-2018, 09:28 PM
caddylover caddylover is offline
Currently: Not set.
Basic Member
caddylover is an unknown quantity at this point
  #17
Old 08-03-2018, 09:40 AM
gtwitch gtwitch is offline
Currently: Not set.
gtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond repute
  #18
Old 08-03-2018, 11:44 AM
Murph's Avatar
Murph Murph is offline
Currently: Back in the mountains
Murph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond repute
  #19
Old 08-03-2018, 11:47 AM
Murph's Avatar
  #20
Old 08-03-2018, 12:53 PM
richracer1's Avatar
  #21
Old 08-05-2018, 04:24 PM
Currently: Not set.
Basic Member
  #22
Old 08-05-2018, 05:19 PM
Big10inch Big10inch is online now
Currently: Not set.
Basic Member
Big10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond repute
  #23
Old 08-06-2018, 02:44 PM
BeartoothBaron BeartoothBaron is offline
Currently: Not set.
BeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond repute
  #24
Old 08-06-2018, 08:08 PM
DV-ENT DV-ENT is offline
Currently: Not set.
DV-ENT has a reputation beyond reputeDV-ENT has a reputation beyond reputeDV-ENT has a reputation beyond reputeDV-ENT has a reputation beyond reputeDV-ENT has a reputation beyond reputeDV-ENT has a reputation beyond reputeDV-ENT has a reputation beyond reputeDV-ENT has a reputation beyond reputeDV-ENT has a reputation beyond reputeDV-ENT has a reputation beyond reputeDV-ENT has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — What year model PRO is the go? Thread Starter — chopper Forum — Polaris: Pro-Ride Replies — 5 Last Post — 06-29-2016 02:39 PM
Thread — Best year of the pro? Thread Starter — miralas Forum — Polaris: Pro-Ride Replies — 23 Last Post — 03-30-2014 09:48 PM
Thread — What year pro 800 rmk??? Thread Starter — MNSledShed Forum — Polaris: Pro-Ride Replies — 17 Last Post — 01-27-2014 08:46 AM
Thread — 2011 Turbo Pro year 2 Thread Starter — Robbie Forum — Member Sled Builds Replies — 42 Last Post — 12-05-2011 08:32 PM
