Upgrade to Premium
Arctic Cat: Proclimb M 2012 and beyond
Reply
  #1
Old 07-25-2018, 05:41 PM
bgraff1 bgraff1 is offline
Currently: Not set.
Basic Member
bgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond repute
Default belt drive sealed upper bearing
does anybody know if there is a generic P/N to replace the sealed upper bearing when doing a belt drive install?
Rate this post: Yes | No
  #2
Old 07-25-2018, 06:32 PM
PuddyCat PuddyCat is online now
Currently: Not set.
Basic Member
PuddyCat is an unknown quantity at this point
Default
If you go with tki it comes with a new top bearing
I put one on my 16 excellent quality and I’ve had 0
Problems. I highly recommend them
  #3
Old 07-25-2018, 07:20 PM
summ8rmk's Avatar
summ8rmk summ8rmk is online now
Currently: Alpha Hawk!
summ8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond repute
Default
Get the number off the bearing and Google it. Or u could ask Napa for cross reference.
I know that u can get bearings much cheaper than what the dealers charge, maybe $10 vs $30
  #4
Old 07-25-2018, 07:30 PM
Currently: Not set.
Basic Member
Default
It's not that I didn't get one in the kit. I removed the kit to sell and would like to have a new one when I sell as you can't remove it without damaging I'm betting. Also couldnt read and numbers on it
  #5
Old 07-26-2018, 05:38 AM
Old & slow Old & slow is offline
Currently: Not set.
Old & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond repute
Default
They are a standard bearing readily available. You can get them with no seals, one side or both sides sealed. $ 10.00 ish at Motion Industries some made in China and some from Germany your choice. Just measure the id, od and width if you cant find the part number.
  #6
Old 07-26-2018, 09:39 AM
snowmobiler snowmobiler is offline
Currently: Not set.
snowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond repute
Default
seems like you could get oem number off website and cross reference with a sealed bearing?not sure.
  #7
Old 07-26-2018, 01:00 PM
boondocker97 boondocker97 is online now
Currently: working for the man
boondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond repute
Default
What everyone is saying seems logical, but I know that bearing isn't very standard in a sealed configuration due to it's high misalignment capability. It took Tom at TKI a long time to track one down. Something may have changed now, but at the time there was one manufacturer that made it. That's why C3 used to do the hard motor mounts to be able to run a standard sealed bearing up there. I see MVM has the same bearing box pictured on their website as I've seen in the TKI shop.
Also, I believe the 2015 bearing is different from the 2012-2014s so make sure you get the right one for your year.
__________________
Current Sleds:
2014-2018ish BDX Pro-Lite 900, 2005 M7 with upgrades - Ol' Reliable, 1974 Cheetah
Still in the Family:
2009 M1300, 2001 Mountain Cat 800 LE, 1972 Kitty Cat
Gone but not Forgotten:
1999 Powder Special 600 LE, 1998 Powder Special 600, 1993 EXT 550, 1980 JAG 340
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #8
Old 07-26-2018, 07:37 PM
runner runner is online now
Currently: Not set.
runner has a reputation beyond reputerunner has a reputation beyond reputerunner has a reputation beyond reputerunner has a reputation beyond reputerunner has a reputation beyond reputerunner has a reputation beyond reputerunner has a reputation beyond reputerunner has a reputation beyond reputerunner has a reputation beyond reputerunner has a reputation beyond reputerunner has a reputation beyond repute
Default
Its a 2206-2RS bearing, same as the one on the clutch side. Cats part #2602-247. This is for the 2015 and up.
If you go for a better quality bearing then use a SKF 2206 E-2RS1TN9
As far as your belt drive sealed bearing, leave it in and remove the outer seal.
The Following 2 Users Say Thank You to runner For This Useful Post:
jim (07-26-2018), summ8rmk (07-26-2018)
  #9
Old 07-27-2018, 06:14 AM
Currently: Not set.
Default
I was off on the price as i didn't realize how good of a deal I got through work. But they are readily available, I would personally stick with FAG or SKF and avoid the China knock offs.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Quick drive belt slipping off after bearing install? Thread Starter — screamingrhino Forum — Polaris: Pro-Ride Replies — 4 Last Post — 01-05-2018 11:45 AM
Thread — 1 Ski Doo Drive belt. 1 Polaris drive belt and 1 Ski Doo Rear track shock Thread Starter — jtt35 Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 1 Last Post — 05-23-2011 02:52 PM
Thread — drive shaft bearing Thread Starter — mitchellsled87 Forum — Polaris: EDGE Replies — 3 Last Post — 03-16-2011 08:36 PM
Thread — upper drive pulley for 600 Thread Starter — Nut Hawker "G" Forum — Snow Hawk Replies — 4 Last Post — 02-09-2009 10:37 PM
Thread — XP 154 Upper sprocket bearing failure Thread Starter — highmark herring Forum — Ski-Doo Replies — 9 Last Post — 03-21-2008 10:04 AM
