Upgrade to Premium
Polaris: AXYS 2016 AXYS chassis
Reply
  #1
Old 07-24-2018, 10:49 AM
szotty szotty is online now
Currently: Winning
Basic Member
szotty has a reputation beyond reputeszotty has a reputation beyond reputeszotty has a reputation beyond reputeszotty has a reputation beyond reputeszotty has a reputation beyond reputeszotty has a reputation beyond reputeszotty has a reputation beyond reputeszotty has a reputation beyond reputeszotty has a reputation beyond reputeszotty has a reputation beyond reputeszotty has a reputation beyond repute
Default Will cats magnetic teather work?
Will cats magnetic teather work on axys pro rmk? Thinking sounds nicer than a polaris teather.
Rate this post: Yes | No
The Following User Says Thank You to szotty For This Useful Post:
TRS (07-24-2018)
  #2
Old 07-24-2018, 12:50 PM
Teth-Air's Avatar
Teth-Air Teth-Air is offline
Currently: sourceinnovations.ca
Teth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond repute
Default
It will work, but only for the 20% of guys who actually wear them. 80% will still be hooked to the riser.
These numbers gained from an online survey we did a couple years ago.
We see a need for the cordless tether, not because the corded don't work, it is because most guys hate to use them.
Chris
__________________
Home of the "Cordless Teth-Air" and NEW "Phantom Teth-Air"
http://www.sourceinnovations.ca
We also have TKI Belt Drives, Arm Candy A-Arm Braces, Oil Tank Inserts, Reversible Scratchers, Polaris Suspension Couplers, Track Clips, Clutching and more.
  #3
Old 07-24-2018, 01:06 PM
Currently: Winning
Basic Member
Default
Yeah I don't put on till off trail but don't feel safe with out it on. Have always used polaris one but have had few freeze up in winter and not work so I'm looking for a better idea than get in woods and factory one is making sled cut out so have to disconnect again
  #4
Old 07-24-2018, 01:08 PM
Scott's Avatar
Scott Scott is offline
Currently: ACTIVELY defend your right to ride.
Polaris & Montana Moderator
Scott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond repute
Garage
Default
I'm sold on tethers. I've seen what happens when they are not used.
My only problem is with my cordless teth-air...when it randomly cuts out at intermittent and strange times. Sled totally shuts off. Usually starts right back up again though.
Yes, my antennae is right at the throttle, fresh batteries, the wristband is not buried under my sleeve.
I got stuck once during the 16-17 season on a climb in steep timber because the teth-air shot me down. Was a BAD stick and a rough situation with dangerous terrain below me. I disconnected it right on the spot and haven't used it since.
Otherwise it's GREAT!!!! And I mean that sincerely.
__________________
What's up Sparky?
OEM parts from Free Agent
Ambassador
Honestly, Honey!!! The shop paid for these mods. They sponsor me now. Really!
2 out of 2 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to Scott For This Useful Post:
owenbstory (08-28-2018)
  #5
Old 07-24-2018, 01:45 PM
Wheel House Motorsports's Avatar
Wheel House Motorsports Wheel House Motorsports is offline
Currently: is it winter yet?
Wheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond repute
Default
Its hard, you really got to get people trained up on them. I make the stock POO tether cord into a loop on the end and have it hooked on my throttle hand wrist from the second i head down the trail until I get home. Ive run myself over SOOO many times. and even with traditional tethers just hooked to your jacket you can easily be under your track and it not pulled. Ask me how I know.
With them wrapped like that it helps eat up some extra length as well, this way it stays short and tight to my wrist so its behind the bars and doesnt snag branches but can also pull with ease if need be.
As for the cat one, right now its more finding out if its a normally open switch (like cat has been using) if so then you should be good to go.
__________________
Wheelhousemotorsports@gmail.com
406-871-0955 Bozeman, MT
The Following User Says Thank You to Wheel House Motorsports For This Useful Post:
Scott (07-24-2018)
  #6
Old 07-24-2018, 01:53 PM
Teth-Air's Avatar
Default
We stand behind our products. If you have a unit that is experiencing some interference or other, we will repair/replace or upgrade you to a Phantom Teth-Air. Send me a PM and we will make it right.
Chris
__________________
The Following 2 Users Say Thank You to Teth-Air For This Useful Post:
mtncat1 (08-02-2018), summ8rmk (07-24-2018)
  #7
Old 07-24-2018, 04:53 PM
kiliki kiliki is offline
Currently: Not set.
kiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond repute
Garage
Default
^^ this I also put it around the handle bar when I get off. most times on the throttle side but around the brake side when I lock it to remind me to not waste a belt over a locked brake.
I do have a 2019 mt cat sitting in the shop right now and the cord is a lot shorter this year.
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #8
Old 07-24-2018, 10:24 PM
Scott's Avatar
Garage
Default
Quote:
Chris
Chris, I really appreciate that.
IT WASN'T what I'm after though. Seriously..
I figured I set it up wrong and just needed to figure it out. I just haven't gotten around to meeting with it. I really do like the product.
I'll send you a PM.
Scott
__________________
What's up Sparky?
Ambassador
Teth-Air (07-25-2018)
  #9
Old 07-25-2018, 08:50 AM
Teth-Air's Avatar
Default
An interesting thing about a magnetic tether. Our first project on a tether was to make it easier to use. We attached a magnet to our sled jackets and another to the loose end of a standard corded tether. This way there was no hook to attach when taking off our gloves wasn't ideal, when riding in a blizzard for example. It worked pretty well but we needed really strong magnets that would not break apart before pulling the cord off the switch. It was nice just to bring both magnets near each other and they would hook up automatically. Pulling apart was easy enough too, just a little harder than pulling the cord off the switch. We abandoned the idea when it became a nuisance due to the magnet sticking to every steel surface we brushed by such as when climbing into the truck. Ideally we should have had the magnetic coupling just in the center of the cord so we unclipped and left the magnet with the machine after riding.
I would still like to see this on the market.
__________________
  #10
Old 07-25-2018, 12:07 PM
summ8rmk's Avatar
summ8rmk summ8rmk is online now
Currently: Alpha Hawk!
summ8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond repute
Default
I may be wrong,
I believe the cat tether is a magnetic switch vs a plunger or physical button, not held on by the magnet.
Brilliant idea, a sealed unit will never have snow/ice issues!
Attached pic. Looks like tabs on the tether lock on to the sled.
Looks like they may break easily?
Someone here with in depth knowledge?
The Following 2 Users Say Thank You to summ8rmk For This Useful Post:
mountainhorse (08-07-2018), sno*jet (08-02-2018)
  #11
Old 07-25-2018, 12:34 PM
Click Here to Register
  #12
Old 07-26-2018, 08:55 AM
Teth-Air's Avatar
  #13
Old 07-26-2018, 08:58 AM
Teth-Air's Avatar
  #14
Old 07-27-2018, 02:53 PM
Currently: Not set.
Garage
The Following User Says Thank You to kiliki For This Useful Post:
summ8rmk (07-27-2018)
  #15
Old 07-27-2018, 02:59 PM
summ8rmk's Avatar
  #16
Old 07-27-2018, 03:09 PM
Currently: Not set.
Garage
The Following 3 Users Say Thank You to kiliki For This Useful Post:
Catlarsen (07-28-2018), ndfb35 (07-27-2018), summ8rmk (07-27-2018)
  #17
Old 08-02-2018, 02:58 PM
Currently: Winning
Basic Member
  #18
Old 08-02-2018, 03:59 PM
Currently: Not set.
Garage
The Following 2 Users Say Thank You to kiliki For This Useful Post:
d8grandpa (09-12-2018), summ8rmk (08-02-2018)
  #19
Old 08-27-2018, 05:27 PM
CROW's Avatar
CROW CROW is online now
Currently: Not set.
CROW has a reputation beyond reputeCROW has a reputation beyond reputeCROW has a reputation beyond reputeCROW has a reputation beyond reputeCROW has a reputation beyond reputeCROW has a reputation beyond reputeCROW has a reputation beyond reputeCROW has a reputation beyond reputeCROW has a reputation beyond reputeCROW has a reputation beyond reputeCROW has a reputation beyond repute
  #20
Old 08-28-2018, 08:26 PM
AndrettiDog's Avatar
AndrettiDog AndrettiDog is online now
Currently: I know, let's have a spelling contest
AndrettiDog has a reputation beyond reputeAndrettiDog has a reputation beyond reputeAndrettiDog has a reputation beyond reputeAndrettiDog has a reputation beyond reputeAndrettiDog has a reputation beyond reputeAndrettiDog has a reputation beyond reputeAndrettiDog has a reputation beyond reputeAndrettiDog has a reputation beyond reputeAndrettiDog has a reputation beyond reputeAndrettiDog has a reputation beyond reputeAndrettiDog has a reputation beyond repute
  #21
Old 09-12-2018, 05:51 PM
summ8rmk's Avatar
  #22
Old 09-12-2018, 11:41 PM
Colbymh Colbymh is offline
Currently: Not set.
Basic Member
Colbymh Colbymh Colbymh Colbymh Colbymh Colbymh Colbymh Colbymh Colbymh Colbymh Colbymh
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — anyone with experience with bikeman magnetic weights? Thread Starter — Tonysnoo Forum — Arctic Cat: TURBO Replies — 3 Last Post — 02-23-2014 09:39 PM
Thread — 13 xm x teather Thread Starter — zxsummitrider01 Forum — Ski-Doo: XM Sleds Replies — 9 Last Post — 10-02-2013 09:01 AM
Thread — got me a new toy. Racer's Edge magnetic block setup Thread Starter — noob Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 16 Last Post — 12-12-2010 04:44 PM
Thread — Racer's Edge magnetic coupler block setup Thread Starter — noob Forum — General Snowmobiling Replies — 0 Last Post — 12-09-2010 11:00 PM
