Upgrade to Premium
Arctic Cat: Proclimb M 2012 and beyond
Reply
  #1
Old 07-24-2018, 02:54 AM
Northlight Northlight is offline
Currently: Not set.
Basic Member
Northlight is an unknown quantity at this point
Default Mountain cat beltdrive
Hello!
I'm thinking of buying a belt drive for my 2017 mountain cat and I'm wondering if it will fit an alpha one? not sure if its worth to buy a beltdrive since im most likely going to buy an alpha for the 2019/2020 season anyway.
Rate this post: Yes | No
  #2
Old 07-24-2018, 06:16 AM
Old & slow Old & slow is offline
Currently: Not set.
Old & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond repute
Default
I don't believe there were any changes is the 19 chain case so it should be the same. I would check with a dealer once the production is complete. Now for the 19/20 Alpha who knows, AC is due for a chassis update when is that coming ??? With the addition of the Alpha they may sit on the Ascender chassis for a bit as it is updated from the Pro climb. Not sure what direction there heading but standing still is not a option. I believe the Alpha will be the leading sled for the deep snow crowd.
  #3
Old 07-24-2018, 10:11 AM
boondocker97 boondocker97 is offline
Currently: working for the man
boondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond repute
Default
The drive itself should be the same. The oil tank setup will be different.
__________________
Current Sleds:
2014-2018ish BDX Pro-Lite 900, 2005 M7 with upgrades - Ol' Reliable, 1974 Cheetah
Still in the Family:
2009 M1300, 2001 Mountain Cat 800 LE, 1972 Kitty Cat
Gone but not Forgotten:
1999 Powder Special 600 LE, 1998 Powder Special 600, 1993 EXT 550, 1980 JAG 340
  #4
Old 07-24-2018, 11:56 AM
Wheel House Motorsports's Avatar
Wheel House Motorsports Wheel House Motorsports is online now
Currently: is it winter yet?
Wheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond repute
Default
Gears/belt are the same. the cover/oil tank are different so not much of it transfers over. Just call TOM at TKI, he can give you an exact list of what will work and walk you through if it makes $$ sense for you.
__________________
Wheelhousemotorsports@gmail.com
406-871-0955 Bozeman, MT
  #5
Old 07-24-2018, 01:46 PM
Currently: Not set.
Basic Member
Default
Okey, will the 19 oil tank work on the 17 maybe? Feels like it should be slimmer than 17 so if it has the same connector for the oil hose and level sensor it should work
  #6
Old 07-24-2018, 03:17 PM
Default
Quote:
No, the 18's and 19's both have the electric oil pump built into it where the 17's still had the mechanical pump on the motor. So the cover/tank assemblies is very different.
__________________
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #7
Old 07-24-2018, 05:59 PM
runner runner is offline
Currently: Not set.
runner has a reputation beyond reputerunner has a reputation beyond reputerunner has a reputation beyond reputerunner has a reputation beyond reputerunner has a reputation beyond reputerunner has a reputation beyond reputerunner has a reputation beyond reputerunner has a reputation beyond reputerunner has a reputation beyond reputerunner has a reputation beyond reputerunner has a reputation beyond repute
Default
Is not the jackshaft different on the 18/19's Its now hollow and is a bigger diameter at the top gear.
  #8
Old 07-24-2018, 06:34 PM
summ8rmk's Avatar
summ8rmk summ8rmk is online now
Currently: Stirring pots
summ8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond repute
Default
What about the bottom gear on the aluminum drive shaft? Is it not different than the steel drive shaft?
  #9
Old 07-29-2018, 10:08 PM
sno*jet sno*jet is online now
Currently: Not set.
sno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond repute
Default
im in the same boat. id likely just sell my sled with the belt drive tho.
what im wondering is why people talk of drilling/tapping the jackshaft when TKI website says NO Moification of any stock parts nessessary? on older proclimbs as well..?
  #10
Old 07-30-2018, 08:02 AM
kiliki kiliki is online now
Currently: Not set.
kiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond repute
Garage
  #11
Old 07-30-2018, 10:32 AM
Click Here to Register
The Following User Says Thank You to boondocker97 For This Useful Post:
sno*jet (07-30-2018)
  #12
Old 07-30-2018, 10:33 AM
  #13
Old 07-30-2018, 10:38 AM
summ8rmk (07-30-2018)
  #14
Old 07-30-2018, 03:04 PM
Currently: Not set.
  #15
Old 07-30-2018, 08:53 PM
summ8rmk's Avatar
  #16
Old 07-31-2018, 06:18 PM
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — C3 beltdrive ski doo T3 Thread Starter — grich8888 Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 2 Last Post — 12-02-2017 08:37 AM
Thread — c3 beltdrive Thread Starter — graffs970 Forum — Arctic Cat: Proclimb M Replies — 18 Last Post — 03-05-2014 08:48 PM
Thread — Good way to keep snow out of the beltdrive? Thread Starter — Braaap12 Forum — Polaris: Pro-Ride Replies — 18 Last Post — 12-07-2013 05:57 PM
Thread — Looking for some info , c3 powersports beltdrive?? or cmx?? Thread Starter — Daniel475 Forum — Polaris: Pro-Ride Replies — 3 Last Post — 06-28-2013 12:06 AM
Thread — kingcat beltdrive mountaincat Thread Starter — pride0810 Forum — Chassis/Tunnel (Swapmeet) Replies — 0 Last Post — 08-30-2010 09:47 PM
no new posts
