Upgrade to Premium
Ski-Doo: REV Gen 4 For the 2017 and newer REV Gen 4 Sleds
Reply
  #1
Old 07-21-2018, 04:13 PM
Dynamo^Joe's Avatar
Dynamo^Joe Dynamo^Joe is offline
Currently: talking about clutching
Dynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond repute
Default 2019 G4 Summit clutch settings - Dynamo Joe
Sorry im a bit late. Usually have these stock clutch settings by 2nd week of June, but i've been out of town working on my garage pad.
FR 146, Summit 146 x 850
990 ramps low, 965 ramps high
bl / yl primary spring low, bl / pl high
38mm pivot to 4000
33mm pivot 4k~8k
26mm pivot 8k+
Black secondary spring to 4000 feet
Blue secondary spring 4000+
42/38 helix
21-49 @ 114p chain
FR 154~165, Summit 154~165
38mm pivot to 4000
33mm pivot 4k~8k
26mm pivot 8k+
40 helix
FR (Euro) 154 @ 21-49 @ 114p chain
Summit 154 @ 21-51 @ 116p chain
165's @ 21-53 @ 116p chain
Summit 175 x 850
38mm pivot to 4000
33mm pivot 4k~8k
26mm pivot 8k+
40 helix
21-53 @ 116p chain
Clutch kits that are really great; quick and easy to tune available - About 3mph more track speed, repeatable. Engine braking really really strong, declutching at a low track speed.
https://www.ibackshift.com/comersus/...?idCategory=14
850 Blog (My ramblings)
https://www.ibackshift.com/article/8...summit-196.asp
I think I get to put together a 2019-850 x 154 x 3.0 next week some time; and get my head in there to see what's new under the hood.
__________________
Really good G4-850 and XM summit clutch kits
850 G4 Summit clutch kit index
Online Gear Calculator @ iBackshift
3 out of 3 members found this post helpful. Rate this post: Yes | No
The Following 12 Users Say Thank You to Dynamo^Joe For This Useful Post:
Adam12 (07-21-2018), caper11 (07-26-2018), DITCHBANGER (07-21-2018), donbrown (07-25-2018), Motorbreath_ (07-24-2018), nickPSD (07-25-2018), PaulAnd (07-22-2018), rabidsnowmobiler (07-22-2018), Ski-doo#1 (07-22-2018), sledhead_24_7 (07-22-2018), turbonium (07-25-2018), winter brew (07-23-2018)
  #2
Old 07-23-2018, 08:28 AM
el__gato el__gato is online now
Currently: Not set.
Basic Member
el__gato has a reputation beyond reputeel__gato has a reputation beyond reputeel__gato has a reputation beyond reputeel__gato has a reputation beyond reputeel__gato has a reputation beyond reputeel__gato has a reputation beyond reputeel__gato has a reputation beyond reputeel__gato has a reputation beyond reputeel__gato has a reputation beyond reputeel__gato has a reputation beyond reputeel__gato has a reputation beyond repute
Default
keep us posted on what you're seeing on the 2019
  #3
Old 07-24-2018, 05:44 PM
Motorbreath_ Motorbreath_ is offline
Currently: Loving my Summit 850!!
Basic Member
Motorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond repute
Default
Pardon my ignorance, but do these set ups differ from previous years?
  #4
Old 07-25-2018, 06:36 PM
ak ak is online now
Currently: Nothing
ak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond repute
Default
Only thing I see different is a lighter finish rate on the primary spring for the high altitude setup. It’s 50 lbs lighter than the 2018 models.
  #5
Old 07-25-2018, 07:25 PM
GSPLewie's Avatar
GSPLewie GSPLewie is offline
Currently: Not set.
GSPLewie has a reputation beyond reputeGSPLewie has a reputation beyond reputeGSPLewie has a reputation beyond reputeGSPLewie has a reputation beyond reputeGSPLewie has a reputation beyond reputeGSPLewie has a reputation beyond reputeGSPLewie has a reputation beyond reputeGSPLewie has a reputation beyond reputeGSPLewie has a reputation beyond reputeGSPLewie has a reputation beyond reputeGSPLewie has a reputation beyond repute
Garage
Default
Not knocking this work, but is it really worth the extra $400 to upgrade a brand new sled?
  #6
Old 07-25-2018, 09:31 PM
Dynamo^Joe's Avatar
Default
Primary clutch springs
Bl/Yl = 150/250 lbs
BL/PL = 150/350 lbs (2019 H.E. Spring)
PL/PL = 170/350 lbs (2017 H.E. Spring)
PL/WH = 170/400 lbs (2018 H.E. Spring)
I was experimenting with some new parts I made for the primary clutch, causing lower engagement speed to 27~2800 rpms using 965 ramps (at low elevation) and I love it. 31~3200 rpms at high elevation (pivot weight for 7500 feet)
2018
FR 146, Summit 146
FR 154, Summit 154, 165
Same settings as 2019 except 2018 has High elevation primary spring PL/WH = 170/400 lbs
2017
Summit 154, 165
951 ramps low, 967 high
bl / yl primary spring low, pl / pl high
38mm pivot to 4000
33mm pivot 4k~8k
26mm pivot 8k+
40 helix
19:45 @ 112p chain (154)
21:51 @ 116p chain (165)
2017 high elevation spring was 170/350
2018 high elevation spring was 170/400
2019 high elevation spring now 150/350
__________________
The Following 4 Users Say Thank You to Dynamo^Joe For This Useful Post:
donbrown (07-26-2018), kanedog (07-26-2018), Motorbreath_ (08-08-2018), sledhead_24_7 (07-26-2018)
  #7
Old 07-26-2018, 05:38 PM
IcutMetl IcutMetl is offline
Currently: Not set.
Basic Member
IcutMetl has a reputation beyond reputeIcutMetl has a reputation beyond reputeIcutMetl has a reputation beyond reputeIcutMetl has a reputation beyond reputeIcutMetl has a reputation beyond reputeIcutMetl has a reputation beyond reputeIcutMetl has a reputation beyond reputeIcutMetl has a reputation beyond reputeIcutMetl has a reputation beyond reputeIcutMetl has a reputation beyond reputeIcutMetl has a reputation beyond repute
Default
Quote:
Yes.
The Following User Says Thank You to IcutMetl For This Useful Post:
  #8
Old 07-26-2018, 11:37 PM
kanedog kanedog is offline
Currently: Undefeated Mountain Clutching Champ of the World!
kanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond repute
Garage
Default
38mm pivot to 4000
33mm pivot 4k~8k
26mm pivot 8k+
42/38 helix
21-49 @ 114p chain
38mm pivot to 4000
33mm pivot 4k~8k
26mm pivot 8k+
40 helix
Summit 175 x 850
38mm pivot to 4000
33mm pivot 4k~8k
26mm pivot 8k+
40 helix
21-53 @ 116p chain
But you have a big head. Not gonna fit.
Sent from my SM-G920W8 using Tapatalk
0 out of 1 members found this post helpful. Rate this post: Yes | No
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 800 HO Summit Dynamo Joe Clutch Kit....Complete Thread Starter — Rx1Mountain Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 12 Last Post — 01-19-2011 01:10 PM
Thread — My Dynamo Joe clutch kit review '06 Summit Thread Starter — chrispy Forum — Ski-Doo: REV Sleds Replies — 1 Last Post — 02-15-2010 02:32 PM
Thread — clutch kit from dynamo joe Thread Starter — sledder325 Forum — Ski-Doo Replies — 5 Last Post — 12-18-2008 03:20 PM
Thread — Dynamo joe clutch kit Thread Starter — snowrider 151 Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 2 Last Post — 07-21-2008 08:12 PM
no new posts
