Upgrade to Premium
Arctic Cat: Proclimb M 2012 and beyond
Reply
  #1
Old 07-18-2018, 12:35 PM
sno*jet sno*jet is offline
Currently: Not set.
sno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond repute
Default belt drives, lower bearing
i seen the MVM belt drives replace the top bearing with a sealed unit, and then simply pack the lower driveshaft bearing with grease and block it off with a seal.
Is this how TKI and c3 does it?
how are the bearings holding up over the years?
maybe this is covered in another post, its summer, im flirting with this idea again.
Rate this post: Yes | No
  #2
Old 07-18-2018, 01:13 PM
boondocker97 boondocker97 is offline
Currently: working for the man
boondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond repute
Default
That is how TKI does it too. If you've been running your chain case for an extended time with the aluminum lower gear then you want to make sure you flush that lower bearing out pretty good. Could always replace it with a new sealed one if it makes you feel better. I'd probably only do that if you planned to pull the driveshaft and take the track out for some reason.
__________________
Current Sleds:
2014-2018ish BDX Pro-Lite 900, 2005 M7 with upgrades - Ol' Reliable, 1974 Cheetah
Still in the Family:
2009 M1300, 2001 Mountain Cat 800 LE, 1972 Kitty Cat
Gone but not Forgotten:
1999 Powder Special 600 LE, 1998 Powder Special 600, 1993 EXT 550, 1980 JAG 340
The Following User Says Thank You to boondocker97 For This Useful Post:
sno*jet (07-18-2018)
  #3
Old 07-18-2018, 01:55 PM
kiliki kiliki is online now
Currently: Not set.
kiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond repute
Garage
Default
3600 miles on a tki 2016 proclimb all bearing are still in good shape. I do take the seal off and re pack it about 1500 miles. easy on and just use a pick on the outer edge to pull it off. sealed or un sealed are the same bearing other than the seal.
The Following 2 Users Say Thank You to kiliki For This Useful Post:
sno*jet (07-18-2018), Teth-Air (07-18-2018)
  #4
Old 07-19-2018, 07:18 PM
Currently: Not set.
Default
pretty easy to swap a new belt on if i had to on the mountain? not sure why else i would order the spare belt with it...
  #5
Old 07-22-2018, 01:04 PM
BD-Xtreme's Avatar
BD-Xtreme BD-Xtreme is offline
Currently: Not set.
BD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond repute
Default
Yes they last a very long time, and worst case scenario, a replacement bearing is really inexpensive.
We have 10% off going with our July special on belt drive too!!
use code BDX4J-2018
http://www.bd-xtreme.com/index.php?i...oller=category
Click image for larger version
Name:	belt drive cat with oil 2016-17.jpg
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Belt Drives Thread Starter — tchriste Forum — Ski-Doo: REV Gen 4 Replies — 21 Last Post — 04-18-2018 01:30 PM
Thread — C3 BELT DRIVES IN THE U.S. Thread Starter — Speed Shop Inc. Forum — Ski-Doo: XM Sleds Replies — 0 Last Post — 10-26-2015 03:52 PM
Thread — Belt drives Thread Starter — 9 Iron Forum — Ski-Doo: XM Sleds Replies — 59 Last Post — 01-26-2014 12:04 AM
Thread — C3 belt drives anyone. Thread Starter — INKEDRIDER Forum — Ski-Doo: XP Sleds Replies — 13 Last Post — 03-05-2011 10:19 PM
