Upgrade to Premium
Reply
  #1
Old 07-17-2018, 09:58 PM
2006sigouin 2006sigouin is offline
Currently: Not set.
Basic Member
2006sigouin has a reputation beyond repute2006sigouin has a reputation beyond repute2006sigouin has a reputation beyond repute2006sigouin has a reputation beyond repute2006sigouin has a reputation beyond repute2006sigouin has a reputation beyond repute2006sigouin has a reputation beyond repute2006sigouin has a reputation beyond repute2006sigouin has a reputation beyond repute2006sigouin has a reputation beyond repute2006sigouin has a reputation beyond repute
Default Alpha one drive sprocket measurement
Hi everyone !
Just Pick up some alpha one 2019 sprocket drivers 7t 3.5 pitch for a new project i am building with a alpha one track and suspension.
I am searching the distance between the two ifax slide on the mono rail and also the distance between the two drivers sprocket.
Thank you very much !
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to 2006sigouin For This Useful Post:
DDECKER (07-18-2018)
  #2
Old 07-17-2018, 10:00 PM
Currently: Not set.
Basic Member
Default Picture
Drive sprocket 7t 3.5 pitch
Click image for larger version
  #3
Old 07-18-2018, 05:15 PM
summ8rmk's Avatar
summ8rmk summ8rmk is online now
Currently: Stirring pots
summ8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond repute
Default
Could u measure the diameter and circumference and post please.
  #4
Old 07-23-2018, 03:06 PM
Currently: Not set.
Basic Member
Default
7.125 inch diameter
summ8rmk (07-23-2018)
  #5
Old 07-23-2018, 06:22 PM
summ8rmk's Avatar
Default
Quote:
Originally Posted by 2006sigouin View Post
7.125 inch diameter
Thats pretty close to the 8tooth 3in drivers, still a bit smaller than i expected. Circumference of 22.38in =drive pitch of 3.2, i thought it would be closer to 3.5in
  #6
Old 07-24-2018, 07:03 PM
kanedog kanedog is offline
Currently: Undefeated Mountain Clutching Champ of the World!
kanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond repute
Garage
Default
What's the diameter of the shaft? Tia
Sent from my SM-G920W8 using Tapatalk
  #7
Old 07-25-2018, 10:42 AM
Currently: Not set.
Basic Member
Default
Hexagonal 1.750 inch
  #8
Old 07-26-2018, 11:40 PM
Garage
Default
Thx. It's an 1 3/4" ?
  #9
Old 07-27-2018, 08:11 AM
madmax's Avatar
madmax madmax is online now
Currently: Not set.
madmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond repute
Default
The space between the slide rails and space between the drivers are pretty close to the same. Unfortunately the last alpha I looked at before I built my single rail, I didn’t have a dial caliper with me to get an exact measurement. I spaced my rails and drivers about 3/8” apart. Just enough room to let the track clips space to move and not bind when the track tilts from side to side.
__________________
19’ Alpha 800 turbo
18, MC 153 stock
18’ axys 155 stock
17’ Cat 800 snow pro 153 alpha skid
The Following User Says Thank You to madmax For This Useful Post:
DDECKER (07-27-2018)
  #10
Old 07-27-2018, 10:34 AM
Garage
Default
Quote:
Thx for the pic. I couldn't wrap my head around a big thick 1.75 trackshaft diameter but now I see how they did. Only that big where the drivers are and less diameter otherwise. A cool weight savings.
  #11
Old 08-06-2018, 06:37 AM
Currently: Not set.
Basic Member
Click Here to Register
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — drive sprocket Thread Starter — caillou04 Forum — Racing Replies — 1 Last Post — 01-23-2014 06:06 PM
Thread — Drive sprocket Thread Starter — caillou04 Forum — Racing Replies — 1 Last Post — 11-01-2012 08:50 PM
Thread — Drive shaft measurement Thread Starter — sledr4life Forum — Ski-Doo: ZX Sleds Replies — 0 Last Post — 03-04-2012 06:05 PM
Thread — SPROCKET,DRIVE Thread Starter — caillou04 Forum — Racing Replies — 0 Last Post — 11-27-2011 09:42 PM
Thread — mc drive sprocket interference Thread Starter — 69charged Forum — Arctic Cat Replies — 13 Last Post — 12-03-2007 03:50 PM
no new posts
