Upgrade to Premium
Reply
  #1
Old 07-17-2018, 10:05 AM
Iowa__Freeriders's Avatar
Iowa__Freeriders Iowa__Freeriders is offline
Currently: getting the '18 ready for POW season!
Iowa__Freeriders has a reputation beyond reputeIowa__Freeriders has a reputation beyond reputeIowa__Freeriders has a reputation beyond reputeIowa__Freeriders has a reputation beyond reputeIowa__Freeriders has a reputation beyond reputeIowa__Freeriders has a reputation beyond reputeIowa__Freeriders has a reputation beyond reputeIowa__Freeriders has a reputation beyond reputeIowa__Freeriders has a reputation beyond reputeIowa__Freeriders has a reputation beyond reputeIowa__Freeriders has a reputation beyond repute
Default SSI head for Ctec. Any experience?
http://www.bd-xtreme.com/index.php?i...roller=product
wondering if anyone has tried the SSI mountain Billet head (or any head for that matter) on a Ctec? Pros, Cons, worth it? i currently have SLP Stage II on my sled. but am wondering if the head will really gain me more power combined with the SLP Stage II. thanks in advance!
__________________
'18 M8000 153" SLP stage II
'13 Pro Rmk 800 155" PAR Head, MDS Clutching, RKT Pistons.
'10 Sno Pro 500
'14 Honda Grom with TS Sno Ripper
Rate this post: Yes | No
  #2
Old 07-17-2018, 11:08 AM
BD-Xtreme's Avatar
BD-Xtreme BD-Xtreme is offline
Currently: Not set.
BD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond repute
Default ssi billet head
There billet heads kits work excellent on that motor. And they do work well with Slp components as well.
If you think about it, a stock motor is designed for low elevations, and can be run at higher elevations. Our Speed Shop billet head is designed for higher elevations. It has an improved dome design with a different squishband angle and width. It also has a hemi style pocket, instead of the top hat style that stock is.
The compression ratio is increased to 14:1, which increases the compression ratio. This compression ratio make the motor more of a mountain motor. Get a lot of power back that you lost because so much compression is lost when you go up in elevation, plus gain even more with the improved combustion chamber design.
Even on a bone stock machine, our Speed Shop billet heads really bring the motors to life! No fuel controller is needed because there is plenty of fuel flow. We feel the heads are so often overlooked, when in reality its one of the easiest ways to bolt on awesome horsepower gains that you really feel and notice. They work!
Click image for larger version
Name:	billet head arctic cat 800.jpg
2 out of 2 members found this post helpful. Rate this post: Yes | No
The Following 2 Users Say Thank You to BD-Xtreme For This Useful Post:
DDECKER (07-18-2018), Iowa__Freeriders (07-17-2018)
  #3
Old 07-17-2018, 11:26 AM
Default
SO, if i added the head even combined with the SLP stage II i would not need to adjust anything with my Power commander? because if so im all game to try one!
__________________
'10 Sno Pro 500
  #4
Old 07-17-2018, 03:17 PM
BD-Xtreme's Avatar
Currently: Not set.
Default
Normally I would say bump the power commander map 1 point from 4000 rpm to full throttle when you add the head. But the slp maps seem to be a little on the safe or richer side for consumer use. So more than likely you will be able to pull that 1 number back out later. The good thing on those motors is the Det sensor works really well and keeps the motor safe. Often when I have tuned a sled without a egt gauge, I lean it out until it hits the det sensor, and then bump up back up the fuel numbers 2 points. But I'm guessing that as long as you run above 6000 feet elevation with 91-93 octane fuel, you should be fine. You might want to add about 2 grams of weight to each clutch arm with the head installed depending on how your clutched now. There is no doubt the motor will put more weight with the head installed.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to BD-Xtreme For This Useful Post:
  #5
Old 07-18-2018, 02:32 PM
Default
What clutch springs do you suggest to run? im running 200/280 in my secondary with stock helix
__________________
'10 Sno Pro 500
  #6
Old 07-19-2018, 01:51 PM
BD-Xtreme's Avatar
Currently: Not set.
Default clutching
The way the stock clutch is shimmed with such a low engagement, I would use our 145-290 gold primary spring, and our 190-260 driven spring.
We developed a partial progressive helix for them that has very strong low end power and still extremely quick and crisp throttle response in deep snow. It really works well. It's the one we use in our clutch kits.
Iowa__Freeriders (07-19-2018)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Flutter ctec Thread Starter — powder79 Forum — 2018 Ascender Replies — 16 Last Post — 05-09-2018 09:06 PM
Thread — SSI Head Thread Starter — armey37 Forum — Arctic Cat: Proclimb M Replies — 21 Last Post — 12-23-2017 02:28 PM
Thread — SSI Axys Billet Head Thread Starter — m7ben Forum — Engine/Engine Parts (Swapmeet) Replies — 0 Last Post — 04-08-2017 08:55 AM
Thread — SSI BILLET HEAD, BOLT ON POWER Thread Starter — Speed Shop Inc. Forum — Ski-Doo: XM Sleds Replies — 6 Last Post — 02-18-2016 06:02 PM
Thread — engine tech head>any real world experience Thread Starter — lightening800 Forum — Ski-Doo: XP Sleds Replies — 25 Last Post — 12-14-2009 03:17 PM
