Upgrade to Premium
Arctic Cat: Proclimb M 2012 and beyond
Reply
  #1
Old 07-15-2018, 03:59 PM
Scherps Scherps is offline
Currently: Not set.
Basic Member
Scherps is an unknown quantity at this point
Default Question on torque specs for steering
Does anyone know the torque specs for the bolt that connects the whole steering swivel to the chassis? Thank you!
Click image for larger version
Rate this post: Yes | No
  #2
Old 07-15-2018, 07:53 PM
kiliki kiliki is online now
Currently: Not set.
kiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond repute
Garage
Default
Youhttps://support.countrycat.com/?feed=recent
Just tighten to the point the steering starts to get tight with all the front end of the ground
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #3
Old 07-24-2018, 06:26 AM
Old & slow Old & slow is offline
Currently: Not set.
Old & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond repute
Default
Quote:
35 ft lbs
  #4
Old 07-27-2018, 10:17 AM
sno*jet sno*jet is online now
Currently: Not set.
sno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond repute
Default
if its the 10mm, i could not get mine tight enough to get rid of the slop. that needs attention cat.
  #5
Old 07-28-2018, 05:58 AM
Currently: Not set.
Default
Quote:
Your right it does need attention, you can tighten that bolt all you want but the movement is still in there. I built shims and that got rid of the play. I found that all my steering play was originating at the bell crank, (after replacing the upper bushings). I am going to take the bell crank out this fall and make it right, so I don't need shims and possibly add a grease zerk.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — new torque specs ? Thread Starter — Rprecision Forum — Polaris: Pro-Ride Replies — 4 Last Post — 11-06-2013 06:29 PM
Thread — Torque Specs Thread Starter — wjl Forum — Polaris: Pro-Ride Replies — 0 Last Post — 01-28-2013 12:54 PM
Thread — Looking for torque specs Thread Starter — traveler Forum — Polaris: Pro-Ride Replies — 2 Last Post — 12-11-2012 06:40 PM
Thread — M7 Torque Specs Thread Starter — JROD Forum — Arctic Cat: M Series Replies — 1 Last Post — 10-30-2010 10:04 AM
Thread — torque specs Thread Starter — Tmann Forum — Arctic Cat: 1M Replies — 2 Last Post — 11-07-2009 10:39 AM
