Upgrade to Premium
Reply
  #1
Old 07-15-2018, 07:55 AM
GoBigParts's Avatar
GoBigParts GoBigParts is online now
Currently: Not set.
GoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond repute
Arrow Polaris RMK Carbon Fiber Tunnel Covers (Bottom)
Patrick Custom Carbon Tunnel bottom.
Interior/underneath Carbon Fiber tunnel cover will fit between the 2 heat exchangers covering the aluminum tunnel. This will give you huge weight savings (10-40 Lbs or more depending on the conditions) as the snow and ice that builds up on the underside of the tunnel are due to the heat exchanger. The reason for the weight savings is carbon fiber does not conduct cold, it will not freeze like the stock aluminum tunnel that allows ice and slush to build up. All you need to do is drill out the existing steel rivets,(approx. 30) including the rear bumper. Place the Patrick Custom Carbon 9 5/8" X 66" piece in place and pop rivet. Easy to install too!
Top Carbon Fiber Tunnel cover will lay over the top of the existing tunnel. This is more for looks than being effective as far as snow/slush build up, but it will look really cool!! Top tunnel cover anchors over the top of the stock aluminum tunnel and gets pop riveted thru the existing tail light wiring holes for easy installation.
Both carbon fiber tunnel covers are .054 thick. They come with pop rivets and aluminum washers needed to do each job. You will need to remove the fuel tank for either of these parts to be attached.
MSRP is $450. I have one I never used ready to sell for $300
__________________
http://www.gobigparts.com
randy@gobigparts.com
We Offer Skinz, Slydog, 509, WRP, SLP, Boss, True Adventures Gear, Powermadd, Sportech, VForce, Holtzman Eng, HMK, ROX and much more.
Rate this post: Yes | No
  #2
Old 08-24-2018, 04:56 AM
GoBigParts's Avatar
Currently: Not set.
Default
Someone make me an offer on this thing.
Sent from my Pixel XL using Tapatalk
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — New P 85 with carbon fiber covers Thread Starter — carbontj Forum — Polaris Replies — 7 Last Post — 12-27-2013 06:47 AM
Thread — New Clutches/with carbon fiber covers Thread Starter — carbontj Forum — Polaris: Pro-Ride Replies — 1 Last Post — 12-05-2013 06:40 AM
Thread — 03 POLARIS VERTICAL ESCAPE! $20K BUILD! SLP 903 CARBON FIBER TUNNEL! MUST SEE! Thread Starter — stu Forum — Polaris (Swapmeet) Replies — 3 Last Post — 01-18-2013 01:24 PM
Thread — Polaris RMK carbon fiber tunnel covers Thread Starter — carbontj Forum — Chassis/Tunnel (Swapmeet) Replies — 0 Last Post — 09-24-2012 07:36 PM
