Upgrade to Premium
Polaris: AXYS 2016 AXYS chassis
Reply
  #1
Old 06-26-2018, 02:25 PM
Texasron Texasron is online now
Currently: Exploring 'til my bones can't take it anymore.
Texasron has a reputation beyond reputeTexasron has a reputation beyond reputeTexasron has a reputation beyond reputeTexasron has a reputation beyond reputeTexasron has a reputation beyond reputeTexasron has a reputation beyond reputeTexasron has a reputation beyond reputeTexasron has a reputation beyond reputeTexasron has a reputation beyond reputeTexasron has a reputation beyond reputeTexasron has a reputation beyond repute
Default HOW WOULD YOU BULLET PROOF AXYS ENGINE?
Change rod length? Ring gap? Number of rings? Balance piston /engine/clutch/ ? Oil settings? Somebody knows!
Rate this post: Yes | No
  #2
Old 06-26-2018, 09:41 PM
Spaarky's Avatar
Spaarky Spaarky is online now
Currently: Moved Into Maximum Security Cell
Spaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond repute
Default
Pretty simple. I call Indy Specialties. Throw the motor in a tote and ship
It to Minnesota. IMO the Indy Specialties TM3 motor is the most bomb proof motor out there.
3 out of 3 members found this post helpful. Rate this post: Yes | No
The Following 3 Users Say Thank You to Spaarky For This Useful Post:
Cerialsledder (07-03-2018), Sheetmetalfab (06-27-2018), wellfed777 (06-28-2018)
  #3
Old 06-27-2018, 06:23 AM
TRS's Avatar
TRS TRS is online now
Currently: Waiting for winter
TRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond repute
Default
  #4
Old 06-27-2018, 08:53 AM
Sheetmetalfab's Avatar
Sheetmetalfab Sheetmetalfab is online now
Currently: Getting the R6 snowbike ready......
Sheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond repute
Default
Quote:
Originally Posted by TRS View Post
__________________
Try again
  #5
Old 06-27-2018, 10:11 AM
GoBigParts's Avatar
GoBigParts GoBigParts is online now
Currently: Not set.
GoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond reputeGoBigParts has a reputation beyond repute
Default
Add gas and oil and ride.
__________________
http://www.gobigparts.com
randy@gobigparts.com
We Offer Skinz, Slydog, 509, WRP, SLP, Boss, True Adventures Gear, Powermadd, Sportech, VForce, Holtzman Eng, HMK, ROX and much more.
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #6
Old 06-27-2018, 11:35 AM
willjogervais willjogervais is online now
Currently: patiently waiting on a patriot....
willjogervais has a reputation beyond reputewilljogervais has a reputation beyond reputewilljogervais has a reputation beyond reputewilljogervais has a reputation beyond reputewilljogervais has a reputation beyond reputewilljogervais has a reputation beyond reputewilljogervais has a reputation beyond reputewilljogervais has a reputation beyond reputewilljogervais has a reputation beyond reputewilljogervais has a reputation beyond reputewilljogervais has a reputation beyond repute
Default
Quote:
This^^^
  #7
Old 06-27-2018, 12:05 PM
TRS's Avatar
Default
If you have warranty.
My ‘18 is on its 4th engine. Piston ring locating pins.
The Following User Says Thank You to TRS For This Useful Post:
Sheetmetalfab (06-28-2018)
  #8
Old 06-27-2018, 12:09 PM
Default
This is what i’m currently doing.
If I keep the sled out of warranty....... Dan will probably see it.
__________________
Try again
  #9
Old 06-28-2018, 10:20 AM
Teth-Air's Avatar
Teth-Air Teth-Air is offline
Currently: sourceinnovations.ca
Teth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond repute
Default
They are pretty bullet proof already, The failures I have seen are mostly from ingesting reeds and that is because they have been revving too high. If you run stock RPM they seem pretty solid. They do however start to lose some compression as they get a lot of hours on them. BUT if mine is an average example after 4000 kms, the pistons and cylinders still look like new.
__________________
Home of the "Cordless Teth-Air" and NEW "Phantom Teth-Air"
http://www.sourceinnovations.ca
We also have TKI Belt Drives, Arm Candy A-Arm Braces, Oil Tank Inserts, Reversible Scratchers, Polaris Suspension Couplers, Track Clips, Clutching and more.
  #10
Old 06-28-2018, 10:55 PM
wellfed777 wellfed777 is online now
Currently: Not set.
wellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond repute
Default
wow 4! Tony dang that sucks are seen those kind of failures
a lot in you group ?
how are stock motors holding up ?
thanks
  #11
Old 06-29-2018, 06:50 AM
TRS's Avatar
Click Here to Register
The Following 3 Users Say Thank You to TRS For This Useful Post:
mountainhorse (07-01-2018), Sage Crusher (07-03-2018), wellfed777 (07-03-2018)
  #12
Old 06-29-2018, 11:17 AM
snoballssnoglory's Avatar
snoballssnoglory snoballssnoglory is offline
Currently: Not set.
snoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond repute
  #13
Old 06-29-2018, 11:39 AM
Teth-Air's Avatar
  #14
Old 06-29-2018, 11:50 AM
richracer1's Avatar
richracer1 richracer1 is online now
Currently: Loving my BMP 860
richracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond repute
  #15
Old 06-29-2018, 12:31 PM
Murph's Avatar
Murph Murph is online now
Currently: Back in the mountains
Murph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond repute
The Following User Says Thank You to Murph For This Useful Post:
  #16
Old 07-01-2018, 12:59 PM
  #17
Old 07-01-2018, 01:56 PM
TRS's Avatar
  #18
Old 07-02-2018, 10:47 AM
JJ_0909 JJ_0909 is offline
Currently: Not set.
JJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond repute
  #19
Old 07-02-2018, 11:23 AM
sno*jet sno*jet is online now
Currently: Not set.
sno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond repute
  #20
Old 07-02-2018, 12:27 PM
BeartoothBaron BeartoothBaron is online now
Currently: Not set.
BeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond repute
The Following User Says Thank You to BeartoothBaron For This Useful Post:
neden (07-02-2018)
  #21
Old 07-02-2018, 12:44 PM
TRS's Avatar
  #22
Old 07-02-2018, 08:55 PM
tuneman's Avatar
tuneman tuneman is online now
Currently: is a long track addict
tuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond repute
The Following 2 Users Say Thank You to tuneman For This Useful Post:
Snowman.PRO. (08-23-2018), Teth-Air (07-03-2018)
  #23
Old 07-03-2018, 12:55 AM
Currently: Not set.
  #24
Old 07-03-2018, 05:44 AM
TRS's Avatar
wellfed777 (07-05-2018)
  #25
Old 07-03-2018, 04:23 PM
mountainhorse's Avatar
mountainhorse mountainhorse is offline
Currently: CONTEMPLATING: "Laughter is gods hand on a troubled world.".
mountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond repute
The Following User Says Thank You to mountainhorse For This Useful Post:
tlm700 (09-13-2018)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Bullet Proof 2010 M8 H.O. took at bullet!!!! Thread Starter — cat4ever72 Forum — Arctic Cat: M Series Replies — 25 Last Post — 02-16-2012 08:18 AM
Thread — how bullet proof are the unionbay 900kits Thread Starter — bigb55 Forum — Arctic Cat: M Series Replies — 0 Last Post — 02-05-2011 01:09 AM
Thread — A bullet proof dragon? Thread Starter — thefullmonte Forum — Polaris: IQ Replies — 41 Last Post — 02-02-2011 02:09 PM
Thread — How bullet proof are M8's Thread Starter — Grey44 Forum — Arctic Cat: M Series Replies — 24 Last Post — 05-24-2009 03:24 PM
Thread — bullet proof vest test Thread Starter — Freak Forum — Fouled Plug Replies — 20 Last Post — 04-10-2009 05:29 PM
no new posts
