Upgrade to Premium
Polaris: AXYS 2016 AXYS chassis
Reply
  #1
Old 06-16-2018, 05:20 PM
firecat225 firecat225 is offline
Currently: Not set.
Basic Member
firecat225 has much to be proud offirecat225 has much to be proud offirecat225 has much to be proud offirecat225 has much to be proud offirecat225 has much to be proud offirecat225 has much to be proud offirecat225 has much to be proud offirecat225 has much to be proud offirecat225 has much to be proud offirecat225 has much to be proud offirecat225 has much to be proud of
Default Best weights for the 800
Hi. My brother has a 17 sks 155 with the 2.4 i believe, looking for best adjustable weights. He likes to climb when he is out west, i suggested mds weights since i run them in a proclimb and like them.
Im not sure which weights Polaris guys tend to like the most.
Thanks for any info.
Jeff
Rate this post: Yes | No
  #2
Old 06-16-2018, 09:24 PM
Sheetmetalfab's Avatar
Sheetmetalfab Sheetmetalfab is online now
Currently: Getting the R6 snowbike ready......
Sheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond repute
Default
The slp magnum force weights are working great for me.
Adjustable from outside the clutch.
Less than a minute on the hill.
__________________
Try again
  #3
Old 06-16-2018, 10:12 PM
BILTIT's Avatar
BILTIT BILTIT is offline
Currently: Never enough snow!!!
BILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond repute
Default
I second slp magnum weights.
Sent from my SM-G925W8 using Tapatalk
__________________
Derek B.
2000 440 xc sp 136 (EDGE)
2003 800 RMK 162
2004 910 PRO-XR 121x1.75", Wheelie Machine!!!
2011 LRod 13.6 800 ProRMK 3"PC KMOD/Raptors kmod 37" arms Ti can
  #4
Old 06-19-2018, 10:01 AM
xmk1080 xmk1080 is online now
Currently: Not set.
xmk1080 has a reputation beyond reputexmk1080 has a reputation beyond reputexmk1080 has a reputation beyond reputexmk1080 has a reputation beyond reputexmk1080 has a reputation beyond reputexmk1080 has a reputation beyond reputexmk1080 has a reputation beyond reputexmk1080 has a reputation beyond reputexmk1080 has a reputation beyond reputexmk1080 has a reputation beyond reputexmk1080 has a reputation beyond repute
Default
I also really like my slp magnum force weights!
  #5
Old 06-24-2018, 09:01 AM
Ratchit Ratchit is offline
Currently: just going with the flo
Basic Member
Ratchit has a reputation beyond reputeRatchit has a reputation beyond reputeRatchit has a reputation beyond reputeRatchit has a reputation beyond reputeRatchit has a reputation beyond reputeRatchit has a reputation beyond reputeRatchit has a reputation beyond reputeRatchit has a reputation beyond reputeRatchit has a reputation beyond reputeRatchit has a reputation beyond reputeRatchit has a reputation beyond repute
Default
CPC’s turbo mags or I T’s
Dalton’s
Both are set screw style and easiest to change without taking belt off or moving clutch sheave in . Just my experience
  #6
Old 06-24-2018, 01:55 PM
BILTIT's Avatar
Default
I think the slp magnums are better than daltons, both setscrew adjustable style.
__________________
Derek B.
2003 800 RMK 162
  #7
Old 07-22-2018, 01:35 PM
BD-Xtreme's Avatar
BD-Xtreme BD-Xtreme is offline
Currently: Not set.
BD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond repute
Default PRO-MAG WEIGHTS
our PRO-MAG weights are adjustable from 52-68 grams. The have the 10 series profile. We make them right here in Minnesota, the work great and have an excellent price too at only $129.95 per set.
Each magnet weights 1.3 grams for easy tuning.
We also have them available 64-80 and 78-90 gram.
http://www.bd-xtreme.com/index.php?i...roller=product
Click image for larger version
  #8
Old 07-30-2018, 09:45 AM
Currently: Not set.
Basic Member
Default
Thanks for the replys, will he need to change springs as well? Or does polaris set them up with good springs and helix from factory?
I had been considering the pro mags, not sure what weight is used outwest mostly?
If we could run the middle range ones that would be great so they could be used at low elevation as well
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #9
Old 07-31-2018, 05:57 AM
Currently: Not set.
Basic Member
Default
Im really tempted to run mds weights. Have them on a 15 cat and like them
  #10
Old 08-05-2018, 12:29 PM
BD-Xtreme's Avatar
Currently: Not set.
Default
We suggest our 125-310 green primary spring or our 140-310 red if you want the engagement to be above 4000 rpm.
You can use the 52-68 gram versions and run them full at 68 grams at low elevations. Then lighten up to about 60 grams in the mtns depending on the elevation.
__________________
www.BD-XREME.com
http://www.speedshopinc.com
www.SPEEDSHOPINC.com
  #11
Old 09-12-2018, 07:33 AM
indydan's Avatar
indydan indydan is offline
Currently: Building Cat Alph Clutch Weights
indydan has a reputation beyond reputeindydan has a reputation beyond reputeindydan has a reputation beyond reputeindydan has a reputation beyond reputeindydan has a reputation beyond reputeindydan has a reputation beyond reputeindydan has a reputation beyond reputeindydan has a reputation beyond reputeindydan has a reputation beyond reputeindydan has a reputation beyond reputeindydan has a reputation beyond repute
Click Here to Register
  #12
Old 09-12-2018, 08:36 AM
damx damx is offline
Currently: Not set.
damx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond reputedamx has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — weights to use in Revy on pro 800 Thread Starter — tree-magnet Forum — Polaris: Pro-Ride Replies — 2 Last Post — 12-13-2015 06:57 PM
Thread — Adjustable weights for 800 pro Thread Starter — nm2708 Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 1 Last Post — 11-17-2013 10:55 AM
Thread — WEIGHTS OF ALL 2013 800'S Thread Starter — MBlabey Forum — Arctic Cat: Proclimb M Replies — 5 Last Post — 02-06-2013 07:32 AM
Thread — 2011 etec 800 weights Thread Starter — jhurkot Forum — Ski-Doo: XP Sleds Replies — 1 Last Post — 11-05-2010 02:56 PM
Thread — Weights for '02 Mt Cat 800 Thread Starter — hhhs08 Forum — Arctic Cat Replies — 2 Last Post — 01-03-2008 12:25 PM
no new posts
