Upgrade to Premium
General Snowmobiling Snowmobile related topics only
Reply
  #1
Old 06-09-2018, 10:42 PM
Pow-Shredder's Avatar
Pow-Shredder Pow-Shredder is online now
Currently: Waiting for the pow
Pow-Shredder has a reputation beyond reputePow-Shredder has a reputation beyond reputePow-Shredder has a reputation beyond reputePow-Shredder has a reputation beyond reputePow-Shredder has a reputation beyond reputePow-Shredder has a reputation beyond reputePow-Shredder has a reputation beyond reputePow-Shredder has a reputation beyond reputePow-Shredder has a reputation beyond reputePow-Shredder has a reputation beyond reputePow-Shredder has a reputation beyond repute
Default Broken Parts on Trips
Wondering what parts you guys have broken while on trips and had to call it a day going to the closest dealer to fix your sled!
Thanks guys
__________________
18 Arctic Cat Mountain Cat, TKI Belt Drive, SLP Exhaust, Grippers
Rate this post: Yes | No
  #2
Old 06-10-2018, 08:52 AM
joshkoltes's Avatar
joshkoltes joshkoltes is offline
Currently: TOO MANY PROJECTS!
joshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond repute
Garage
Default
Polaris' break a arms and engines, usually whole engines too. Rear rail twist on pros
Skidoos break chassis
Cats have to have a real good impact to break an a arm. They don't like tail landing, the rear suspension rails fold up
Yammis don't break
I plan to keep an inventory of all these things if other parts of my life didn't keep failing
__________________
Snow
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #3
Old 06-10-2018, 09:47 PM
SRXSRULE SRXSRULE is online now
Currently: Not set.
SRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond repute
Default
Ive never broke a seat..... Everything else is fair game!
Seriously though, if you do this long enough you will see it all. Some of the odd stuff that can end your day is a broken...
Throttle cable, Brake lever, steering post, handle bars, tie rod end, Bolts breaking, or falling out. Ive seen shock bolts fall out and cause the shock to stab the track, the screw come out of the Hy-fax and cause the hy-fax to wad up at the rear axle. Broken idler wheel on the rear axle and the track getting into the rail.
All of the common stuff is broken suspension or chassis parts, blown chain case or belt drive, blown engines (I once broke a rod in a yamaha triple at 9,000rpm!), failed clutches, countless electrical failures, Blown belts and the damage caused from them (ski-doos like to wrap all the cords around the crank).
After 28 years of this I've replaced an engine on the mountain (800 poo broken crank), replaced pistons on the mountain (800 doo), air lifted out wrecked sleds, hiked back in to get buried sleds out. And replaced countless other broken/failed parts in the back country or parking lot.
The joys of sledding
  #4
Old 06-11-2018, 04:11 PM
boondocker97 boondocker97 is online now
Currently: working for the man
boondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond repute
Default
^I'm with him. Seen most of these things on various brands of sleds. Never had to airlift or fix a major issue in the woods. We've been lucky enough to be able to get them all pulled out one way or another and back to the truck. Only way to be safe on a big trip is bring a spare sled or two.
__________________
Current Sleds:
2014-2018ish BDX Pro-Lite 900, 2005 M7 with upgrades - Ol' Reliable, 1974 Cheetah
Still in the Family:
2009 M1300, 2001 Mountain Cat 800 LE, 1972 Kitty Cat
Gone but not Forgotten:
1999 Powder Special 600 LE, 1998 Powder Special 600, 1993 EXT 550, 1980 JAG 340
  #5
Old 06-12-2018, 09:15 AM
Wheel House Motorsports's Avatar
Wheel House Motorsports Wheel House Motorsports is online now
Currently: is it winter yet?
Wheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond repute
Default
Buckled 2 tunnels now on axy's doing dumb things. One was bailing off a jump and sled flipped into a tree. the other was come up short, bail and sled tomohawked in spring snow. Otherwise mechanically I have had pretty good luck. 1 Upper a-arm, power valve cable, power valve itself and a whole lot of belts.
Riding new sleds has its perks as they just tend to be less likely to have dumb issues. Also I think the biggest gains are how easy they are to ride so I find myself crashing into things a lot less then sleds of old.
All my sleds get rails and or rail braces before they touch the snow and I have some elka shocks I keep moving forward to new sleds. This seems to help keep things from exploding too easily by not bottoming out off of every whoop i hit.
__________________
Wheelhousemotorsports@gmail.com
406-871-0955 Bozeman, MT
  #6
Old 06-12-2018, 09:33 AM
donbrown's Avatar
donbrown donbrown is online now
Currently: Let it snow !!!
donbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond repute
Default
Quote:
Thanks guys
Pretty much every major part on a sled , suspension , chassis , motor , drive train etc. That's why there are BACK UP SLEDS.
__________________
www.CNSA.NET lifetime member
  #7
Old 07-26-2018, 09:14 AM
Blk88GT's Avatar
Blk88GT Blk88GT is online now
Currently: THE CHASE IS ON!!
Blk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond repute
Default
There isn't too much you can't fix in a hotel or cabin parking lot. We've only had 2 that weren't fixable. One was a brand new Axys that hung the throttle open down a gulley into a pine and the other was an overheated XP that simply got replaced with an XM.
I've blown up a recoil, numerous rear suspension components (axles, anti stab wheels, shock crossbars) and a set of A arms and a ski shock. This was all in my Arctic Cat days.
I have bent a few rails on my Doos but they've never ended my day, or trip.
__________________
2019 Freeride 154x3 w/SHOT
2016 Summit X T3 154
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Who all has had broken parts already this season? Thread Starter — live2ride Forum — Powder Room Replies — 18 Last Post — 04-05-2013 09:51 AM
Thread — 2012 Etec X broken parts Thread Starter — Cheynespub Forum — Ski-Doo: XP Sleds Replies — 0 Last Post — 02-05-2012 01:16 PM
Thread — OUCH, broken parts Thread Starter — triple650 Forum — Polaris: 900 Replies — 21 Last Post — 10-29-2010 03:17 PM
Thread — What's going on with all the broken body parts??? Thread Starter — Gromit Forum — General Snowmobiling Replies — 9 Last Post — 03-20-2008 05:31 PM
no new posts
